Question about Konica Minolta bizhub C450P Laser Printer
CANNOT GET COMPLIMENT SLIPS TO PRINT
HAVE SET UP DETAIL FOR COMPLIMENTS SLIPS BUT WHEN i SEND THEM FROM MY COMPUTER THEY ASK ME TO FEED THROUGH THE BYPASS TRAY BUT THEY WILL NOT FEED. IS THERE ANY OTHER WAY I CAN PRINT THEM THROUGH USING ONE OF THE PAPER DRAWERS.
  • 44 Answers
SOURCE: Can't print onto thick card
In your print driver, you need to go to the Printer Features -> Media 1 window and specify "Thick 2" and then go back to the main print window and specify Paper Feed "Tray 2" Then go to the copier,, place the stock into tray 2 and match the paper setup for that tray on the copier to "Thick 2" for tray 2.
Basically, both the Mac and the copier need to match paper types and feed tray.
Posted on Nov 17, 2008
SOURCE: Printing on thick paper (thick 3)
You can print thick 3 only from bypass tray.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
jrcamp
  • 20 Answers
SOURCE: Tray 4 paper feed won't feed my 80 gloss text anymore.
Having owned a copy center I can tell you most copiers will not take glossy stock. It's too slick. Worse yet - the (clay) coating on the glossy paper will transfer to the rollers and cause the pinch rollers to get slick then they will not be able to work properly on any paper.
You will need to first clean the rollers with a damp cloth or isopropyl alcohol. If you still want to use a glossy stock you'll need to use a special stock made for copiers. Go to a specialty paper store (or call JC Paper, Xpedex, etc.). You probably won't find this paper in a retail office supply store. Good luck.
Posted on Mar 26, 2010
SOURCE: keeps coming up with a paper feed problem, both
I did at one time work for Konica a few year back and my teritory was th naval Acadamy for years.I. notice alot of damp paper prolems when the offices were closer to to water they always had miss feed prolems' I would put a fesh **** of paper in the try and t would feed fine.then keep running until I went throu half that **** with no problems.slill check those charge wire and make sure they are clean.K! Hope it helps.
Moose
Posted on Apr 15, 2010
saxmansaxman
  • 177 Answers
SOURCE: My office has the bizhub
Hi the machine could be defaulted to print from the main trays if you have the same type paper being fed from the manual feed same size paper then it will automatically take it from the default trays
IF you take the paper out of the trays and put it only in the manual feed will it print and take it from the manual feed also you have to tell the machine when you use the manual feed what size and type of paper is in the manual feed once you tell it what paper and type of paper like card stock you then need to make sure when you go to print that it is set on your computer with manual feed and type of paper must match what is set on machine
Posted on Mar 12, 2011
How to print onto smaller paper
Under printer setup select your print, then change the paper size in the settings to the paper you're using.
Change the alignment of the paper feed on printer to the size of the new paper
Feb 21, 2012 | Konica Minolta bizhub C250 All-In-One...
Up to what weight paper can I use in my HP Color Laserjet 2600n
Usually you can print up to about 60lb paper. You may be able to go as high as 90-110 (card stock) if the paper print path is straight thorugh. If you printer has a rear paper door then you can try heavier paper. Usually 40-60 is safe for printer without a rear door/heavy paper path.
The problem is that the heavier paper cannot bend around the rollers inside. So if it is setup to allow heavy paper it runs through flat and out the back instead of curling around and out the top as normal.
Apr 17, 2010 | HP Color LaserJet 2600n Printer
What does load mpf mean
It does stand for Manual Paper Feed.
On this printer, that's on the front of the unit, above the paper trays.
Once your PC has sent a print job with the paper-select set to "Manual Paper Feed" the printer will not do anything until it's processed this job.
The easiest way to do this is to put paper into the MPF and let it print, but at some point you're going to want to fix your PC so it doesn't send MPF print jobs anymore.
To do this, open your Printer Properties and select the default paper tray instead of the Manual Feed.
Sep 25, 2009 | Dell 3010cn Laser Printer
Hp 4250 manuall feed heavy paper message
You'll have to set up the paper settings within the copier to reflect heavy paper for the bypass tray. You'll need to make this a default setting. Then when you print out with heavy paper via the print drivers it should pick up automatically at the printer.
Aug 28, 2009 | HP LaserJet 4250n Printer
Trying to print but it ask me to load paper or form feed. also got a bypass tray message.
Sound like the computer printer preferences "paper source" is set to bypass if set to "auto select" select the tray you want. Also make sure type of paper matches what is in printer.
-Carl
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Konica Minolta bizhub C450P Laser Printer Logo
63 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
