Question about Nolo Dealing with Problem Employees: A L (1260150SF)
LOCK CODE PLEASE ON 29"TRUSLIM
The screen displays the message "LOCK CODE PLEASE" for all channels including the AV1 AV2 ... The menu key is not functional ...None of the buttons on the remote/TV seem to work?! How do I release the LOCK code?
Do Help .... Am in dire need of a quick solution....
Try zoom and then vol - and disable program lock from the menu.
Posted on Mar 28, 2009
Olevia 537-B11. Why is there a blue screen with a "no signal" message?
try main menu look for input should be Air (antenna) ,cable, av1, av2, hdmi1, hdmi2 and perhaps more. do an automatic channel scan if you have an antenna hooked up. will take several minutes scanning
Oct 09, 2015 | Televison & Video
How to unlock a jcv s1465 screen
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
Feb 26, 2013 | Insignia Televison & Video
How to turn off child lock without remote control jvc lt-32sh6
OR
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger.
Nov 01, 2012 | Televison & Video
Hi there, I am getting some problem in connecting my DVD player to LCD TV on AV2 port. If I connect the same to AV1 port,it works fine but that port is already in use for my set top box so if I want to...
I expect if you look at the menu you will find that AV2 is set up as S-Video or Component etc. etc. Set it up as composite or RGB. The same as AV1.
Jan 20, 2011 | Televison & Video
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Problem of Audio in Philips TV, Model - 21RF VardanSL
check option bites find it on crt or back cover to enter serv mode coll following comands
062596 menu or display the data will appear select options and set by vol and ch keys
Jul 10, 2009 | Philips 32PW6506 32" TV
Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
Mar 20, 2009 | Sanyo DS13204 TV
Lost the remote
that one is easy just press menu the channel button up till you get to av1 or av2 then press the volume to change it.
Dec 12, 2008 | XO Vision GX1042 10.4 in. Car Monitor
AV1 AV2 DVD Connectivity
Just click below for more information;
http://www.fixya.com/support/t997470-hooking_up_sony_sa_wm20_audiophile
Hope this may help you;
Regards,
VOTIT
DON'T FORGET TO RATE;
Sep 03, 2008 | Sansui Televison & Video
Panasonic TV - want to remove on screen message
its an input message i dont have your remote in front of me but im going to say when you hit the input av1 av2 there should be a button on remote for display or info one of these buttons should deactivate that message
May 13, 2008 | Televison & Video
Nolo Dealing with Problem Employees: A L (1260150SF) Logo
385 people viewed this question
Top Nolo Computers & Internet Experts
ali_zulfikar
ali_zulfikar
Andrew Taylor
Andrew Taylor
richie46
Are you a Nolo Computer and Internet Expert? Answer questions, earn points and help others
