Question about Keurig B60 Coffee Maker
I lost the little orange foam that is over the puncture needle. Any suggestions?
  • 1,511 Answers
Get a new orange foam dingee.
Posted on Feb 06, 2014
The bottom needle is not able to puncture th K Cup...seems to be bent. What to do?
It sounds like you need the K-Cup holder.
This parts holds the K-cups and has a needle at the bottom.
You can find many replacement parts on eBay.
I have attached a link to one that fits your machine.
Good Luck.
KEURIG GENUINE CUP HOLDER For B77 B70 B66 B60 B40 B30 REPLACEMENT PART
Feb 16, 2015 | Keurig B60 Coffee Maker
Does the needle used in electrolysis puncture the skin?
The needle goes into each hair follicle and does not puncture the skin.
Feb 25, 2013 | Health & Beauty
Gasket - coffee grounds in coffee
hi! It goes on the top and surrounds the pin that pops the hole in the kcup....the problem I'm having is how do you stick it on? Should we use crazy glue?
Apr 03, 2010 | Keurig B70 Coffee Maker
I have a kicker 05cvr122 and the rubber around the outside got punctured how could i get that fixed?
The foam suspension often goes bad and turns to powder with age. There are kits to REPLACE the suspension but it requires some skill to do it. Often the center dome must be removed to allow shimmming the voice coil for centering while replacing the suspension foam. If you are not skilled in this, best take it to a speaker reconing service. Most pro speakers do NOT use the foam, but a fabric flex material.
Feb 18, 2010 | Car Audio & Video
My brewer keeps tearing the top fo the k-cups. Is there a replacement to the orange foam cover?
Yes there is! This top needle seal is the revised part used for your brewer. Keurig did away with the orange seals. This part will fit yours...
http://iwantsweetdeals.com/Top-Needle-and-Seal-Replacement-B40-B50-B60-B66-B70-B77-P1227669.aspx
Jan 31, 2010 | Keurig B50 Coffee Maker
I need the little rubber part that goes over the neddle
I lost the little rubber gasket that goes over the top needle. WHere can I get a new oone. THanks
Sep 21, 2009 | Keurig B50 Coffee Maker
Needle holder fell off of machine
there should be an allen screw on the back side of the needle bar clamp push it up and on and make sure its as stright as you can get it and tighten down on the allen screw
Jul 08, 2009 | Brother XL-6562 Mechanical Sewing Machine
REPAIR or REPLACE?
OMG ROFL!!!
Well... here's an idea.
Drill a 1/2 inch hole where you punctured the wall of the freezer, make sure you don't hit the coils. Then goto lowes/home depot and get that expansion foam that is used to insulate windows and holes in houses. Grab a razor blade and scalp off the excess after it's dried. Now cover the foam on the inside of the freezer with 2 part epoxy or "shoe goo" or e6000 (these are the toughest glues I have ever used) which is available at a hobby shop. Make sure you do a test with the foam and the glue on cardboard first to make sure the glue won't eat at the foam.
Are you sure you punctured the coil? If you did you can goto an auto part place and ask for a compression fitting (most commonly used to repair brake lines on cars) for what ever tube size the coil is, use a fine ruler is the best. Then you can repair the coil by using a pipe cutter to cut the coil and put it back together with the compression fitting. Now call the appliance service guys and have them come out and recharge the system.
Fixed, total cost... about $50 bucks
Other solution, replace entire fridge, total cost $$$$$
Sep 04, 2008 | Thetford Norcold® Model DE0061
B-50
the needle in your k-cup holder is broken and over presure built up in the k-cup, and create security stop. Change our k-kup holder. if the needle is still in place the k-cup must be puncture on both side on top and bottom. if is right our needle can be block. clean with a little rod of stainless steel.
Nov 03, 2007 | Keurig B50 Coffee Maker
Keurig B60 Coffee Maker Logo
62 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
