Question about MB Quart WR1-CD Nautic Marine AM/FM/CD/MP3/WMA Radio Receiver
I need a wireing diagram for a mbquart wr1-cd
What does the mute wire do i cant get any sound out of the speakers
Need a stereo wiring diagram
Hiya,
Here's the wiring connections for the Kenwood KDC-3025.
Black: Car chassis (-) ground wire
Yellow: Battery (+) wire (must connect to retain memory settings)
Red: Ignition/Accessory wire
White (w/black stripe): Front Left speaker (-)
White: Front Left speaker (+)
Gray (w/black): Front Right speaker (-)
Gray: Front Right speaker (+)
Green (w/black): Rear Left speaker (-)
Green: Rear Left speaker (+)
Purple (w/black): Rear Right speaker (-)
Purple: Rear Right speaker (+)
Blue (w/white): Power Control wire (used with ext. amp only). Do not expose this wire, if no amp is used.
Blue: Antenna Control wire
Brown: Telephone Mute wire (used with handsfree carkits).
Hope this helps,
Cheers,
Scott
Feb 01, 2013 | Kenwood Sirius KDC-3025 CD Player
I am installing the CD Reciever in a Vintage Airstream Travel Trailer. The power wire, ground wire and speaker wires, should be no problem. (Neg ground) do I need the Mute, Illumination and remote? I...
1)The mute cable is to mute your CD Receiver when you get a call on your mobile phone. You will have to buy a car mobile dock for your phone and it will have a mute wire on it, which you will have to connect to your CD Receivers mute wire.
2) The illumination wire is to be connected to the headlight switch of your car. In some CD Receivers it will turn on the display at night along with the headlight. On some models it dims the back light at night along with headlight so that the bright light which is needed during the day does not distract your driving at night.
3) Remote wire is for triggering another device along with the CD Receiver,like an additional power amplifier or a Sub woofer etc.
Mar 21, 2011 | Car Audio & Video
INSTALLED CD PLAYER BUT NO SOUND!
the brown wire is a cell phone mute . you ;may want to check your speakers and speaker wires for any shorts to ground.
Dec 02, 2009 | Clarion DXZ555MP CD Player
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
Radio: replacing radio,not stock,have adapter connector, when hooked up radio pwrs up,but NO SOUND,somehow in mute,took to the"radio doctor", radio tests fine,& he saw how I had it hooked up, extra...
YOU WILL HAVE TO TRACE THE WIRES OUT, DO U HAVE A SEPERATE AMPLFIER? MANY OF THESE VANS DO, IF SO THAT IS THE PROBLEM.
HERE IS THE WIRING COLOR DIAGRAM FOR YOUR VAN
1998 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amplifier Location: N/A
Left Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue/Red
Right Rear Speaker Positive Wire (+): Blue/Orange
Right Rear Speaker Negative Wire (-): Blue/White
Aug 06, 2009 | 1998 Dodge Grand Caravan
Clarion vrx 485 vd.tuner works with amp but cant get dvd or cd to play with amp.screen works cd an dvd are playing but no sound.an with key off tuners playing till i open door?what have i hooked up wrong?
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
it sounds like you have hooked the power wires up wrong try trace back your wires with this diagram
Mar 29, 2009 | Clarion VRX485VD Car DVD Player
Audio wiring diagram for an irish corolla verso
2005 Toyota Corolla Car Stereo Wiring Diagram
Radio Constant 12V+ Wire: Blue/White
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Power Antenna Wire: Black
Front Speaker Size: n/a
Front Speaker Location: n/a
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speaker Size: n/a
Rear Speaker Location: n/a
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
pls rate
Dec 10, 2008 | 2005 Toyota Corolla
I cant install Computer Speakers can someone help me? I have taken speaker wire out of port over and over again and nothing happens.
First of all check your wiring is right. If you have a pair of speakers they need power so they should have a wire which goes into the electrical supply. Then they need to be connected to each other and thirdly they need to be connected via a wire probably green-tipped into a port on your computer. Probably green also. Once all these wires are in you can test them.
Find a CD or something and see if it will play. If not you need to go into control panel. Click start and find the control panel. You can type the word "control" in the "run" or "search" option if you want to(depends on whether you have XP or Vista) Look for your sound options. They may be set to mute or no-sounds. Enable them and your speakers should work. Also check that your volume is up......obviously :)
Mar 19, 2008 | Audio Players & Recorders
Volume
follow the below checklist :
Check1 : Is power for speakers on
Check2 : Are speakers connected correctly to laptop (fixcables)
Check3 : nothing on volume control is muted
Check 4 : try to check with other pc or laptop if speakers are working.
If speakers are working with other computer , then all you need to do is instal audio drivers from mother board CD which you get from hardware manufacturer....
If the speaker is not working with other PC
check 5: if all the wires are in good condtion
If yes.. then contact hardware manufacturer
If no.... fix wires correctly ......
Hope this anwwers your problem.... thanks..Robosoft.
Dec 16, 2007 | Computers & Internet
VRX755VD "triggered audio mute for cellular telephones"
Well, it sounds like you need a new output IC, which is what produces sound to the speakers.
Aug 05, 2007 | Clarion VRX755VD Car DVD Player
MB Quart WR1-CD Nautic Marine AM/FM/CD/MP3/WMA Radio Receiver Logo
24 people viewed this question
Top MB Quart Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MB Quart Audio Player and Recorder Expert? Answer questions, earn points and help others
