Question about Canon NP 6035 Copier
Problem with my copier
E212 Switch the power off and on the type is canon 6035
  • 1 more comment
  • rmoore Feb 15, 2008
    Canon 6050 copier, E- 210 turn off start again, tried moving lens to home position, still same massage
  • Anonymous Dec 30, 2008
    error 212
  • Anonymous Jan 23, 2009
    Can you help me ...
    My Canon copier NP 6035 LCD will not turn (ON).
    Switch the power OFF and ON again
    Email: peternzala@gmail.com
Mesin Saya 6035 Error 224 gimana atasinya
Posted on May 05, 2010
  • 432 Answers
E212 - lens home position not found. Scanner Lens Error. You'll need a technician for this one.
Posted on Jun 27, 2007
Unplug copier remove 2 screws that hold down the copy glass on the right side of glass.most of the time the black belt that moves the lens has popped off the white gear that moves it. carefully move the scanner (the thing with mirrors and lamp to the right out of the way.Now if you look down where the scanner was blocking you should see a loose black belt and a white gear it came off of,the black belt has a spring idler move it to provide the slack you will need to replace the belt on to the white gear. If the gear is loose from its base you need a new lens motor
Posted on Jul 27, 2007
Change lens drive motor or scanner home sensor
Posted on Jul 18, 2007
HOW CAN I SOLVE E212 ERROR CODE FOR NP 6035
E0212. The lens does not return to the home position within a specific time. (In the direction of drum shaft)
Some cases :
- Loose the vanbelt of lens
- Loose/broken the Gear of motor lens unit (connect with the vanbelt)
- The motor of lens is broken.
please chek it out. (locations are under the flat glasses/scanner)
if you need that part, I have all of that
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Mar 01, 2013 | Canon NP 6035 Copier
Tip
ERROR codes Canon 6035
Canon 6035 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controller
on Jan 19, 2010 | Office Equipment & Supplies
Canon NP 6035 Error code &switch on and off
What is the error code is displayed on the control panel???
Oct 01, 2011 | Canon NP 6035 Copier
Code e800 for canon 6035
Replace Main On/Off Switch of ur machine...Check the DC Controller PCB (In The Back Side Of Machine)Connector on DC PCB J712.check Is Proper connected
or replace DC Controller PCB....
Aug 25, 2011 | Canon NP 6035 Copier
Price of Canon NP 6035 Copier
Hey!To be honest and talking from experience,dont buy the machine!Its a old model and spares are all ready a problem to get hold of!!Rather see if u can not get something like a IR type machine!!
Good Luck!
Dec 24, 2010 | Canon NP 6035 Copier
E212 Error code
"E212" Lens problem (sensor, motor)lift document feeder and look inside. is the lens stuck? when turned on it goes back and forth to check where it is
Aug 11, 2008 | Canon NP 6545 Copier
Cannon NP6035
check here for the code: just look for the code, doesn't matter what machine type, they use the same code for different types of models
http://www.copier-help.com/copier-help/ecs/canon/eccgp200.html
Jul 23, 2008 | Canon NP 6035 Copier
Error code E212
sorry I have'it only in italian
Jul 11, 2008 | Canon NP 6035 Copier
Printing on Canon NP 6035
I check www.usa.canon.com and couldn't find anything that came close to that model number. You should contact them directly. It may require a copier dealer in your area to get one for you.
Jun 26, 2008 | Canon NP 6035 Copier
Canon NP-6035 persistent E002
There is a heating problem connected to the fuser. It could be the heater lamp or thermal switches. Lamp is most likely.
Aug 27, 2007 | Canon NP 6035 Copier
Canon NP 6035 Copier Logo
651 people viewed this question
Clive
Clive
old marine
old marine
