Getting black lines down the page when sending faxes, or copying how can I sove this
  • 1 more comment
  • lynnaloha Mar 20, 2009
    I have the same problem - I have an old Brother Fax machine that works very well - sends and receives OK - however, when copying or sending it produces two parallel black vertical lines on everything I submit. I have checked and cleaned it (myself) but they persist. I don't want to buy a new fax at this time nor send it to be repaired - any further suggestions?
  • Anonymous Mar 31, 2009
    scanner window is clean. Any other ideas?
  • Anonymous May 01, 2009
    when sending faxes there are two black lines down the pages when the person receives it
    what do i do? I am cleaning the glass all the time
    Champion:
  • 320 Answers
Clean the scanner window
Posted on Jan 20, 2009
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
Bizhub C250 using to much toner. Images are very dark. Ink can even be rubbed off pages. How do you adjust?
Check that the fuser is not in enevople mode. two green handle up not down. check the files
Oct 28, 2016 | Konica Minolta bizhub C250 All-In-One...
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
How do I dived 9 dived by -1 5/7
1and 5/7 ==1.7142 (5/7 to get decimal point=.7142)
+ 9 divided by minus 1.7142= minus 5.1688
using the maths laws of multiplication and division of numbers where + and - indicies are used +X+ =+ and + X - = - and - X- = +
you will find answers on the web maths pages
Oct 06, 2014 | Office Equipment & Supplies
Why is print quality poor after inserting new ink. Copies are faint and have lines
the cartridge is clogged with ink that has dried and reduced the slit. you need to replace the cartridge with a new one. it happens usually if you recharge the cartridge 3 or 4 times with compatible ink.
May 07, 2014 | Office Equipment & Supplies
Prinnter not printing but showing 'put custom in manual tray'
There is still a print job in the queue. Place a sheet so it prints or kill the job.
Open Printers and Faxes. Open printer. Highlight jobs and Right click > Cancel, or Documents > Cancel.
For those stubborn jobs, Right click My Computer > Manage. Choose Services and Applications > Services > Print Spooler. Right click and stop. Then start. This may have to be done from the Print Server if it's network printer. Contact IT to kill.
Nov 09, 2012 | Office Equipment & Supplies
My fax wont work in my ricoh aficio 1515 mf??
Using the 1515 as a fax machine is a pretty simple procedure if everything works right. All you have to do is hook a working phone line up to the phone jack on the back of the copier (the one labeled LINE, not TEL).
Why won't the fax work? If it is giving you an error message, what is the message?
If you are not getting a dial tone when faxing, unplug the fax from the phone line and plug a working phone in, and see if the phone gets a dial tone. If it doesn't, there is a problem with your phone line.
You can also try plugging the fax machine into another phone line. If the fax works on that line, then there may be a problem with the first line.
Are you having problems sending faxes or receiving them, or both?
Jan 05, 2010 | Office Equipment & Supplies
HP printer psc 2210 all in one
Chances are that you didn't lock down the scanner when you moved the unit. You can attempt to open the unit and move the scanner bar manually to reset it. HPs are very difficult beasts when it comes to their power up check out. It must be fully functional...including all cartridges...to work in most cases. Good luck.
Dec 20, 2007 | Office Equipment & Supplies
413 people viewed this question
k24674
