Question about Electrolux Dishwashers
My seimens dishwasher is not draining at all. Please help. Thanks
I have tried cleaning the drain propeller and have checked the drain hose. What more can I try?
    Sergeant:
    Champion:
  • 249 Answers
What is your model number is then we can get started then
Posted on Jan 04, 2013
  • 351 Answers
SOURCE: Whirlpool dishwasher not draining
blockage in the drain hose somewhere
Posted on Mar 20, 2008
  • 171 Answers
SOURCE: Water won't drain
Hi fixitfran,
I'm Harvey the Master Plumber.
Your problem is: You have pulled the dishwasher out and checked hose. No kink in line. You have taken cleaned out dishwasher and no clog. You poored water into dishwasher and it drains from the bottom not throught drain hose. You have checked the drain hose on the bottom of the dishwasher and to no avail....you don't know what is causing this issue....can I help you out with this? LG-14AW3 Dishwasher does not drain properly and then powers itself off mid cycle. Filters are clean and there are no kinks in the drain hose. How do you fix this and will it be very expensive.
Have you recently replaced the garbage disposal? Sometimes the installer forgets to remove the knockout plug. All of the disposal manufacturers plug the d/w connection in case it is installed where there is no d/w. If there is a d/w, the plug must be removed.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
SOURCE: my danby countertop dishwasher won't drain
the problem has not been resolved. does not drain.
Posted on Jan 18, 2009
  • 10865 Answers
SOURCE: Jenn Air Dishwasher won't drain out water. I have checked basket and hose for clog
The problem is most likely that there is a chunk of glass or bone etc. in the small drain pump. this is an easy fix. remove the lower front panel of the dishwasher, you will see the drain line which goes through the cabinet wall into the sink drain and at the lower end is attached to a small pump. Disconnect the hose clamp and the hose by the pump then unscrew the little pump from the frame of the dishwasher so u can look in it. Remove the blockage. Now reassemble everything and u will be back up and running
Posted on Apr 28, 2009
SOURCE: dishwasher stops after 10 minutes inlet/drain light flashing
I had the same problem on a 5 year old model. It was the main pump leaking from a perished seal causing the water protection microswitch to trip. This gives the symptoms you describe exactly. Parts cost from Miele was about £60 for a new seal. Fairly easy to fit.
Posted on Jul 21, 2009
My dishwasher will not drain
It can bequite common for a dishwasher to not drain because either the drain hose or theair gap (if the unit has one) is clogged up. Drain hose clogs commonly occurwhere the hose is attached to the main household drain line, or where the hoseconnects with the garbage disposer. Turn mainswater off and disconnect mains power Tryremoving the drain hose to unclog any debris. Don't forget to reattach the hosebefore you start your dishwasher again.The drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hotrunning waterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.
Apr 07, 2012 | Maytag 24 in. MDB5600A Jetclean II...
My Whrilpool dishwasher--DU8505SWPQ3, there is always water left on the walls of the dishwasher after a complete cycle is done??? Thanks
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Feb 08, 2011 | Whirlpool Dishwashers
My dishwasher cleans ,but does not drain the watr fully. Please help. Thanks
Hi
Oct 20, 2010 | Maytag Dishwashers
Is there a filter on seimens dishwashers as i seem to have a blockage and the water wont flow away
Yes there are filters, and also it is easy to pinch the drain hose. If drain goes into disposal, be sure teh plug is removed from disposer port. The filters require surgery to find and clean.
Oct 13, 2010 | Siemens Dishwashers
Bosch SGS43E02 will not drain - otherwise seems fine Any help? Thanks
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn't overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn't working properly, the drain pump isn't working correctly, or possibly there is a plumbing problem in your home's drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can't locate the problem, then it is an issue with the drain pump of the dishwasher. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 07, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwasher will not drain
normally you have a restriction in the hose. once you check that and if is clear then listen to see if the drain pumps is humming. if it is humming then there is something stuckin the drain pump propeller. if this helpyou help me by posting a 4 thumbs up post. thanks!
Feb 23, 2010 | Kenmore Dishwashers
My LG model LD-12AS1 dishwasher will not drain, please help
Hi
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 08, 2009 | LG 24 in. LD-12BW5 Free-standing...
My Maytag dishwasher Model # MDB-3 will not drain. Please help. Thanks! Anna Giacobbe
Hi
Thanks
Rylee
Nov 03, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Dishwaher wont drain-checked drain hose and its clean
The problem is most likely the drain valve. It is electrically operated and with your problem it is the most common cause.
If you need more help, post a comment.
Thanks,
Tim
May 29, 2009 | Kenmore 16719 Dishwasher
Water won't drain
Hi fixitfran,
Thank you,
Sep 27, 2008 | Dishwashers
Dishwashers Logo
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
