Question about Cakewalk Music Creator 4
AKEWALK SOUND Using Cakewalk Music Creator 4 I get no sound. am running Windows Vista pro on HP Compaq 6715s. HELP!!
  • mikewalsh77 Feb 22, 2009
    Hi I went through all you said but to no avail. Any other ideas?
  • 22 Answers
You have to check your driver node. Change to MME, run wave profiler and restart application. Also check playback timing master and record timing master and be sure that your sound card is listed under both. That will do it
Posted on Feb 13, 2009
  • KC R
    KC R Mar 05, 2009
    Yes, check the MIDI devices and make sure that you have the "wavetable synth' as your choice. somehow it's not seeing your choices or the wave profiler is not running completely. Also you must shut everything down before any global changes will take place. If you want to give me your email, I'm willing to try a few more things. It can be hard to get configured- but once u do- your all set
I just installed my copy of music creator 4 onto my 64-bit windows 7 computer, but I cannot get the audio to play although I've set up speakers which work fine for all other programs.
This link should be helpful they have an update for the audio. It's a patch that corrected the no sound.
http://forum.cakewalk.com/tt.aspx?forumid=18
Jul 21, 2011 | Cakewalk Music Creator 4
Im trying to download music creator 4 into my comp and when i put it in nothin happens. what am i doing wrong?
Well, this is a simple problem.
You probably have auto-run disabled. So, go to "computer" and you should see your hard disk drives, and anything else connected or inside your computer. Once Music Creator 4 appears, double click it and it should run. Hope I helped in some way. :)
Matt P, Computer/Gaming Relations Team.
Jan 24, 2010 | Cakewalk Music Creator 4
After i downloaded windows 7 my creator wont work
Cakewalk 4, is not compatible with Windows 7. I got this information from this page.
Jan 03, 2010 | Cakewalk Music Creator 4
I just installed cakewalk music creator 4.all of the effects and the studiodevil bvc amp simulator are greyed out.i can't figure out how to turn them on.need help!
You first of all have to check your driver mode to make sure that you have sound. If you do, then just highlite a track so that it knows which "thing" you want to apply said FX to-
That should do it.........
Hope this hleps
L/A
Feb 24, 2009 | Cakewalk Music Creator 4
Cakewalk software: Midi vs. Sound
You can get a music keyboard for around $200 and up.
http://www.zzounds.com/cat--2684
Or use it as is, with your computer keyboard. There should be a printable template on the disk, if not in the package.
Feb 02, 2009 | Cakewalk Music Creator 2 for PC
Midi keyboard sound quality bad
you are likely running it thru a soft synth. Check the help files there is a section in there on "using soft synths" that will explain it more fully. Plus a usb connection can sometimes be problematic (not always). But the tutorial in the help files will tell u how to use the sounds from the piano instead of the MIDI sounds
Dec 17, 2008 | Cakewalk Music Creator 4
Scratchy sound
Yeah, many others have the same problem try reading the solution to one of the other ones of these with the same device. I'll try and find it to put the link in to the answer.
Feb 27, 2008 | Tascam US-122 USB Audio/MIDI Interface...
Cakewalk Music Creator 4 Logo
143 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Anbes
Anbes
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
