Question about Onkyo TX-SR875 Receiver
Screen problem between Onkyo amp and Ninentdo Wii
I have had Onkyo Amp since 2007 and all fine. It is connected to Panasonic Plasma Panel (not TV) and all fine with that. Had a Nintendo Wii for 3/4 years and all fine until about 6 months ago and picture in top part of screen started to show lots of flicker / coloured lines. Should have connected to another TV but didn't - got another Wii - tried the cables that connect into Aux 2 input on the front (Red, Yellow, White) with each Wii and had same problem, though it was a 2nd hand Wii. The first old Wii was cutting out, so we got hold of a new Wii and we have the same problem - I've connected it to my spare TV and all is fine, so I am pretty sure it is not the Wii. Is there anything known about issues with Onkyo Amp, presumably through the Aux input having a problem? I am going to try to connect PS2 same way and see if i get same problems. Can anything cause interference with it - we have Wireless router in the room, a good 4 metres away and close by (about a metre) we have a wireless picture frame. Any thoughts / ideas appreciated - reluctant to get a new amp when it is fine for TV / DVD etc!
  • 151 Answers
SOURCE: DVD signal received in wrong aspect
PRESS SETUP GO TO MISCELLANEOUS PRESS ENTER THEN DOWN TO OSD SETUP PRESS ENTER AGAIN AND DOWN TO MONITOR AND CHANGE TO 16.9.
HOPE THIS HELPS.
CABLE GUY.
Posted on Jun 04, 2008
SOURCE: Audio Problems
See www.avforums.com/forums/onkyo-owners-forum/696423-faq-setting-up-ps3-onkyo-amp.html
This should give you the info to set up the ps3.
Posted on Jan 04, 2009
taran_2005
  • 10515 Answers
SOURCE: No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Posted on Jan 24, 2009
smarthome2
  • 1114 Answers
SOURCE: 1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
Posted on May 23, 2009
SOURCE: Onkyo SR606 video upconversion problem.
Pressed and held cable/sat button on front of unit until "Attenuate" came up. Changed setting from 0 to 2
Posted on Oct 20, 2009
Testimonial: "Found this answer hidden in the Owners manual."
Panasonic plasma tv
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 22, 2016 | Panasonic TC-P54G10 54 in. HDTV Plasma TV
My wii is showing colored line bars when I try to get on
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 29, 2016 | Westinghouse Televison & Video
Why does my panasonic plasma tv have a vertical line down the center?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to Plasma & LCD screen are given with illustrations.
Aug 11, 2014 | Panasonic TH-42PD50U 42 in. Plasma EDTV
How to connect a wii to Onkyo TX-SR608 receiver & TV
SAME AS ANY TV,,RCA JACKS,,,OR HDMI,,OR COPONENT JACK,,,SHOULD HAVE ONE OF THOSE ON THAT TV,,GOOD LUCK
Dec 23, 2011 | Nintendo Wii Black Console
How do I connect my Wii to my Panasonic plasma tv?
the wii leads are colour coded look for the colours on tv then switch tv into that input mode e.g ( common or EXT ) make sure wii is on
Nov 29, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Amp turns off after about 20 mins of bluray playback
Your amp is overheating. Provide better ventilation or rig up some fans. Onkyo amplifiers are known for getting hot.
Peace.
Marco
Feb 05, 2009 | Onkyo TX-SR606 Receiver
I have a Panasonic TH-42PZ700A High Def TV and a Panasonic 160gig DVD Recorder. They both have 1 optical audio output each. I have an Onkyo amp which has 1 optical input for audio. How can I have 5.1 dolby...
Dear ritchiewayne,
Please connect optical out of the DVD recorder to the input of panasonic TV. Next connect TV's optical out to the input of Onkyo amplifier. connect speakers to the out put of Onkyo amplifier.
ramesh22
Jun 15, 2008 | Panasonic Televison & Video
Onkyo TX-SR875 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
