Machine sticks and 'timer saver' flashes. When turned off and onto 'drain' the lights shown on the video flash.
  • Washing Mach... Master
  • 17,130 Answers
Switch off machine for an hour, press down all the panel buttons to drain any residual voltage to the board. Now when the power is reconnected and the machine is switched on, press down Start/Stop/Pause buttons.
If the fault does not clear, then check for dirt in the inlet and outlet , check flow and drain without water accumulating within. If not the control board is a suspect
Posted on Jan 24, 2013
  • 86 Answers
SOURCE: Hotpoint Aquarious WF210. Machine stops mid
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Posted on Mar 06, 2010
SOURCE: hoover vision hd 1400 washing
I had the same problem. The machine would wash but not drain and the time savers button would blink. Turned out to an eye from a teddy blocking the pipe that enters the drain. I hope this helps.
Posted on Mar 16, 2009
SOURCE: My Hoover VHD8142 stops whilst
I've just had exactly the same problem with the same model. Unlikely as it may sound, it's the heating element. Mine has just been replaced and everything is now working perfectly.
Posted on Jul 22, 2009
SOURCE: Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
Posted on Jan 18, 2010
SOURCE: Hotpoint Aquarius WD420 washing machine won't spin and drain
same thing happened to me called engineer over flow pipe was blocked hope this helps anyone with this problem
Posted on Mar 13, 2010
How do I turn off the time saver option?
You should just be able to press the button. Has the machine stopped working with the START light flashing and the time saver light on? If so, this is an error code indicating a motor fault. Please describe any other lights that are on and if they are flashing or solid
Sep 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
Will not complete wash cycle.when emptying first fill pump continues long after water is out then spin light and timer saver lights start flashing
It is taking too long to drain. This could be from plugged filters bue to debris or from a piece of clothing. If this is a front load machine, you can take the front kick panel off. Then you can see the drain plug and unscrew it to clean it out. Be advised that if you do this, you will get all the water that is left in the machine coming out through this opening. Get ready for it with a wet and dry vacuum etc. If this is a top loader you can still do the same thing, the problem is that you have to tip the machine to get to the filter.
May 08, 2015 | Washing Machines
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
regards
shaun
Mar 13, 2011 | Indesit W 123 Front Load Washer
Hoover VHD842- About 10 mins into the wash, the washer stopped and the 'timer saver' light and 1200 spin speed lights start flashing at the same time, approximately flashes five times then goes blank, then...
I'm interested in how you manage to drain the water away- is it by the filter cover? If not may I suggest carrying out the following- if you have not done so already ;-0)
(If you have -sorry. This will not help)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 26, 2011 | Hoover Washing Machines
My hoover washing machine 1400 spin 8kg hd vision hd
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!
Mar 02, 2009 | Washing Machines
Timer light keeps flashing
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up, the drain pump is humming, causeit cant pump any water
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Can't open the door timers saver & 1200 spin lights flash
There is a known problem with these washers whereby a small electrical current 'leak' from the heater element causes the machine to think it still has water in it.
Disconnect the wires on the heater (tape them up or otherwise make safe) then run a cycle to verify that part as the problem.
Jan 31, 2018 | Hoover H130E Front Load Washer
Water wont drain from Machine or go onto spin cycle
either the level control switch has become blocked or faulty or the drain pump has become stuck.
disconnect from the mains and gain access to the rear look for a circular unit with two or three electrical connections and a plastic tube. this is the level control.follow the tube to its start and you will find a plastic connection that goes into the wash drum, remove the plastic tube from the switch end and blow into it. if there is no restistance then the system is OK at the drum end. next reconnect the tube to the switch and remove the opposite end, very gently blow down the tube and you should hear the switch operate. Test wether the switch is working by putting a meter across the switch and blow into the tube. if all of this is OK then the drain pump is at fault. locate the drain pump. it is connected to the outlet tube, try turning by hand. if it does not rotate smoothly remove the clips holding the pump body together and clear the obstruction.
Dec 27, 2008 | Hotpoint Aquarius WF210 Front Load Washer
My Hoover VHD8142 stops whilst draining then the timer saver light and the 1200 lights flash. The machine does not drain away all the water. I cannot find what these lights flashing means in the manual,...
Jun 05, 2008 | Hoover Washing Machines
Mar 04, 2008 | Washing Machines
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
