Question about Chevrolet Chevy Silverado Extended Cab
Heater not blowin chevy silverado 2000 - Chevrolet Chevy Silverado Extended Cab
    New Friend:
Check blower motor fuse....if fuse is good.....replace blower motor.
Posted on Jan 04, 2013
Blows air thru defrost vents only on a 2002 chey silverado 1500
The actuator that changes positions is bad located on heater box it is on drivers side in the middle up best to steering g column
Nov 20, 2017 | Chevrolet Silverado Cars & Trucks
2000 chevy malidu overheats after a few minutes, heater starts blowing clod,
if white smoke is blowin out the tailpipe its a blown headgasket
Jan 06, 2013 | Cars & Trucks
On my sons 2000 chevy silverado 4.8 liter....the heater works fine....but when i switch control to defrost....only cold air blows out defrost vents....any help would be appreciated.
the heater & defroster baffles are controlled by electic motors that open and close the baffle (doors) to let the air to the heater and defroster vents. the motor must be bad
Jan 12, 2010 | 2001 Chevrolet Silverado
I have a 2000 Chevy Silverado pickup, and the heater will not blow hot air. I replaced the thermostat, and nothing changed. The radiator was flushed and filled in the last two months as well. I have all...
once truck is warm check both heater core hoses to make sure they are both warm if not then check the cold water valve could be stuck shut not allowing coolant to travel in to heater core.
Jan 05, 2010 | 2000 Chevrolet Silverado 1500
I have a heater core leak on my 2000 chevy silverado V6, is there an easy fix?
You can bypass the heater core, you just wont have heat anymore. On the firewall of the truck, behind the engine, you will see 2 rubber heater hoses that go into the firewall. They attach to the heater core. Disconnect them and get a plastic connector, and connect the 2 hoses together with clamps to hold them down. This will stop coolant from going into the heater core, and no more leak.
Sep 26, 2009 | 2000 Chevrolet Silverado 1500
2000 Chevy Silverado 1500 The heater does not
Had the same thing happen to my truck, the blen door actuator is under the console on passenger side, but the heater core is going to be clogged if you dont have any heat coming through, but a/c works..
Sep 08, 2009 | 2000 Chevrolet Silverado 1500
Need to know where the heater core and heater control valve are for a 2000 chevy silverado 1500 v8. not sure if it has a heater control valve
The heater core is on the passenger side under the dash within the heater airflow contoller box. If you had Xray vision and could look straight through the glovebox, then you would see it. The heater control vale for the water flow is on the passenger side top of the engine near the firewall. It will have a domed top with a vacuum line to it and it is placed into the heater core supply hose.
Sep 07, 2009 | 2000 Chevrolet Silverado 1500
Heater fuse
On the inside of the panel that you take off to get to the fusebox there should be a diagram listing what each fuse controls. Try that and see if it works. If not a chevy dealer can always help you
Oct 29, 2008 | 2000 Chevrolet Silverado
Chevrolet Chevy Silverado Extended Cab Logo
52 people viewed this question
Top Chevrolet Toys Experts
Electric Dime
Electric Dime
jogp98
tony wahlman
tony wahlman
Are you a Chevrolet Toy Expert? Answer questions, earn points and help others
