Question about Denon AVR-3310CI 7.1-Channel Network Home Theater Receiver
Denon AVR 3310 power button flashes green nine times and does not switch on, possible due to overheating. How do I reset?
    Genius:
  • Denon Master
  • 1,054 Answers
Could be a bad power transformer. Would have to be serviced
Posted on Jan 04, 2013
SOURCE: denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Posted on Jul 06, 2008
SOURCE: my denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Posted on Jul 17, 2008
Foxyjay
  • 13 Answers
SOURCE: Denon AVR-1508
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
Gurudristi
  • 98 Answers
SOURCE: denon avr 885 it automaticallyshuts off when i try to power it up
Its possible that the Receiver is going into protection mode and possible some speaker cable might have touched the body or with each other.
Remove all inputs and outputs and then restart the receiver. If it starts then you are lucky. Connect all cable and wiring properly and ensure that they do not touch each other. You might have to reset the microprocessor also.
If the problem persist then let me know to further the trobleshooting.
Please do rate this solution and thanks for using FixYa.
Posted on Mar 06, 2009
  • 569 Answers
SOURCE: Denon avr 788 power switches
Could be a short on one or more of the speaker outputs. Try disconnecting all speakers and turning the unit on. If that works without a power-down then you have a short in one of the speaker connections. Re-connect them one at a time to detarmine which one it is, and then you should be able to correct the problem.
If that is not the cause then you have an internal problem with the avr which would be difficult to diagnose here.
Posted on Jan 17, 2011
Denon AVR1603 RESET
Starzy, to reset on a Denon AVR-1603
  • power off the unit using the front panel Pwr switch
  • press and hold SPEAKER A and B buttons;
  • keep pressing on the speaker buttons, switch on the AVR
  • when the display is blinking release buttons Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/90-receivers-amps-processors/1386123-help-denon-avr-1603-shuts-down.html
Denon AVR 1603 Operating Instructions Manual Last Function Memory...
Jul 24, 2016 | Denon Audio Players & Recorders
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Denon avr 1312 green power flashing green 7 times
Sounds like a bad power transformer. Would need to go in for repairs.
Jan 09, 2013 | Denon AVR 1312
The green light flashes when power is turned on and then flashes red and turns off. Can this be reset ?
what do i do when my DENON AVR-1506 turns on then flashes red and turns off?
Mar 08, 2011 | Denon AVR-1506 Receiver
I have a denon avr 2802. the remote powers the
Try doing a factory reset by turning off main power switch.hold down speaker a and b buttons while turning on main power switch ,display will flash 3 time s then release buttons,this then returns unit to factory default settings.
Apr 13, 2010 | Denon AVR-2802
Denon avr -1709 how do i get it reset to factory specs
SWITCH OFF THE UNIT..PUSH AND HOLD DOWN BOTH SPEAKER A AND SPEAKER B BUTTON WHILE HOLDING DOWN BUTTONS TURN ON MAIN POWER THE DISPLAY WILL FLASH WAIT FOR 3 FLASHES THEN RELEASE. THIS WILL RETURN EVERYTHING BACK TO RFACTORY DEFAULT
Mar 21, 2010 | Denon AVR-1708 Receiver
How do i reset my denon avr 4802
Switch off the unit and remove the AC cord from the wall
outlet.
Press and hold the DIRECT buttons and STEREO buttons, and
at the same time, plug in the AC cord.
Check that the entire display is flashing with an interval of
about 1 second, and release your fingers from the 2 buttons
That will default the unit
Jul 08, 2009 | Denon AVR-4806 Receiver
Denon avr 885 it automaticallyshuts off when i try to power it up
Mar 06, 2009 | Denon AVR-885 Receiver
My denon reciever display wont't work
Jun 23, 2008 | Denon AVR-2805 Receiver
Denon avr-2106 problem!!!
Mar 06, 2008 | Denon AVR-2106 Receiver
Denon AVR-3310CI 7.1-Channel Network Home Theater Receiver Logo
247 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
