Question about Quinny Buzz Three Wheel Stroller
My quinny buzz seat moves not sure if it sould or should b solid or does it need move ment for bumps etc?
  • Quinny Master
  • 1,629 Answers
Hi
There should be a small amount of movement - the seat unit should not be rigid on the chassis - but if you feel it is excessive movement pop into a retailer and view their display model. If yours appears to have more movement contact us to discuss booking it in for inspection / repair.
www.quinny.com
Posted on Feb 16, 2013
  • 4 Answers
SOURCE: how do you close quinny buzz
you need to stand at the front of the pushchair, push in the left grey button and then push the right one down and towards you all at the same time!! whilst doing this push the frame down towards the front wheel! when i first got mine had real problems figuring it out once you do its easy!! remember to hook on the safety catch though cause one touch of the handle and it pops open. i did read that in cold weather it can be a little stiff. not sure on the car seat though as didnt have one! sorry
Posted on May 12, 2008
bunnydawg
  • 5158 Answers
SOURCE: quinny buzz replacement seat
try here for part sources
http://www.quinny.com/quinny/productdetail.aspx?id=3
Robert
Please rate the solution thanks
Posted on Sep 08, 2008
SOURCE: Quinny Buzz Seat Unit 2008
i contacted quinny because the straps on my quinny had become too tight for my 1year old. Quinny responded informing me that it has come to their attention that the 07/08 quinny buzz was made with smaller straps and that the seat padding was much thicker, causing them to quickly become too small. Second stage seats are now sold as standard to give extra room, but if you purchased your pushchair before this, to contact the retailer to recieve your free second stage seat cover. The result being that my 1yr old now fits in quinny.
Posted on Feb 22, 2009
SOURCE: i need an adapter for quinny buzz to greco car
Hi will the graco car seat fit ? if you know that it will then you would just need the normal buzz adaptors that are used for the maxicosi carseat, they only made the one set of adaptors for the buzz/carseats
Posted on Sep 06, 2009
  • 419 Answers
SOURCE: problem with the front wheel Quinny buzz 3
This does sound like you have got a build up of dirt within the wheel assembly unit. I would suggest that you remove the entire wheel (push the two black buttons either side of the axle and pull) then clean the entire wheel in warm water. Lubricate the moving parts with a thick lubricant (something like vaseline, not DW40 as this attracts dust) then pop it back on, that should sort it out.
If the wheel is still not working, then contact your retailier if still within warranty (two years chassis and one year fabrics). If this is out of warranty, contact www.quinny.com who will be able to sell you a replacement wheel assembly.
I hope this helps.
Posted on Oct 11, 2009
Testimonial: "Thanks for your help, he will is much better"
Do i need to replace the full quinny seat when moving up to the xl or just the fabric
Hi
If your Quinny Buzz is a 2007 - 2010 model you need to remove the infant stage seat fabric and replace with the 2nd stage seat fabric. The sub seat (seat frame) remains the same.
Feb 23, 2013 | Quinny Buzz Baby Gear
How do you put the cover on the seat?
If it's the new model then you need to follow this in reverse order for Cleaning the Quinny Buzz seats (comfort cushion and XL seat)
1. Open safety harness
2. Unfasten the shoulder belt snap and hook and remove the belt pad.
3. Loosen all snaps on the bottom of the seat
4. Loosen the Velcro straps on the bottom of the seat. Remove the belt buckle through the opening of the seat
5. Slide the cord of the seats out of the edges of the Quinny Buzz seat. Start with the foot section and work towards the head section
6. Pull the lap belt of the Quinny Buzz seat through the holes of the seats and remove the loops from the shoulder belts from the openings of the seat
May 19, 2010 | Quinny Buzz 3 - Juice Travel System...
Can a buzz seat fit speedi frame
No unfortunately not. The Quinny Dreami carrycot can be fitted as can a maxi cosi car seat using adaptors but not the buzz seat unit.
Mar 06, 2010 | Quinny Buzz Three Wheel Stroller
Wobbly seat!?!?
Hi did it click into place when you put it on? Also take the seat out & just check the holes it fits into, if the 2 grooves match up then you need to put your finger inside it & move it forwards very slightly say 1" now try to attatch the seat.
Apr 15, 2009 | Quinny BUZZ 3 Jogger
Can i lay quinny buzz back or sit it up with out having to take seat of
hi yes you can there are two gray buttons near to where the bumper bar clips in you just push these down and move the seat either front or back as you wish!! hope this helps
Oct 27, 2008 | Quinny Buzz Jogger
How to fold a quinny buzz
Hi, you can download the manual from the quinny website, but as a quick guide, the best I found was - first stand with your foot against the front wheel (so it doesnt move forward) then press the grey buttons on either side of the chassis and at the same time draw the frame downwards towards your foot, please remember you can only fold down with the seat in place if the seat is facing forward (ie baby facing outwards) it wont fold down with the seat facing mum, there are also demos on you tube, hope ive helped and not been too complicated :)
Oct 08, 2008 | Quinny Buzz Jogger
Quinny Buzz stroller
The base fits into the two adapters on the chassis, then once fitted you can chage seat position by pushing down the two buttons on either side of the seat unit you can move the seat up and down as you want. Also to unfold you simply push the button in the middle of the handlebar (the same button you use to adjust the height of the handlebar) you hold this button in and sort of give it a little shake and the chassis should unfold pretty much by itself and sort of 'pops up.'
Apr 25, 2008 | Quinny Buzz Jogger
How to change seat covers on a quinny buzz stroller
Try this link
http://www.quinny.com/media/producthandleidingen/Quinny/08.08%20win1299_Buzz4_UK.pdf
The instructions & diagram are in section 6.2 on page 5 of this 7 page pdf document.
Hope it helps!
Nov 26, 2007 | Baby Gear
Quinny Buzz Three Wheel Stroller Logo
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
