Question about Exabyte 220 MAMMOTH (2700061150) 8mm Tape
Exabyte-220 Tape Library with a 8900 Mammoth drive. Tape cartridge is stuck in the drive - had a power failure during boot of the library. Can press the eject button and hear the tape rewind but the cartridge will not eject. Is there a means for a user to get the tape cartridge out?
    Scholar:
  • 74 Answers
These drives are a right pain in the neck!
There is no easy way for an end user to remove the tapes and they are a terrible drive (certainly unless you are using a unix/linux server with all data on this server and not on another networked machine)
My suggestion would be to buy a new drive/library!
Failing that try sending the drive to www.tape-drive-repair.com who should be able to help - but these Mammoth drives are so awful they almost sent exabyte bust so i wouldnt invest too much money in keeping it going. Better to upgrade to an HP LTO4 desktop and cut your losses - Again these guys should be able to help with an upgrade
Posted on Aug 24, 2009
Servo init failure stalled xy
Hi Edouard
This sounds like the picker has failed to complete the power on self test (POST).
This may be due to a damaged library or simply due to a tape blocking the picker movement.
POWER OFF!
Try opening the library to make sure your tapes are all properly located in the magazines and have not fallen out.
Also try gently moving the picker to see if you can locate any other obstructions. Be very careful as you obviously do not want to break the picker or anything else accidentally.
If you are in the UK and are still having trouble, click the link below and we will do what we can to help.
LTO Repair service UK Based All manufacturers of LTO drives repaired
Feb 28, 2014 | Quantum SCALAR 50E LIBRARY LTO3HH TAPE...
Is there a setting to change tape drive from singe ended narrow to wide
When you are taking about Single-Ended, there is also
HVD = High Voltage Differential and
LVD = Low Voltage Differential
And if your tapedrive is single ended there is no setting in the drive to change that. Exabytes can't be changed easy. You just buy the HVD or LVD wham you need it.
try a mail to
e-mail
service@exabyte.com
Jan 28, 2014 | Exabyte Mammoth EXB-8900 8mm Tape
Error 30??
Power off the unit and make sure the picker and arm move freely. Often a stuck tape can cause this. Also try cleaning the Tacho in case the arm cannot tell that it is trying to move.
This issue is often more about fluff blocking a sensor than about an actual hardware failure.
If you need to send it for repair though try going to http://tape-drive-repair.com and seeing if they can help you directly
Oct 01, 2013 | Exabyte EXB-210 MAMMOTH (270012) 8mm Tape
Robotic hardware error and I/O station status shows open
A physical obstruction in the path of the robot's motion. Examples
include tape cartridges that are extending from the picker assembly or
from a storage location, as well as tape cartridges or debris that may
have collected on the floor of the library.
2. A large number of electrical hardware failures. Firmware or hardware
detects that motion control is not occurring properly (encoder issues,
motor driving circuits, motor winding issues, etc.)
3. A relatively small number of mechanical hardware failures that do not
result in the detection of a complete obstruction, but where motion
control generates robotics firmware error codes (contamination or damage
to encoder wheel, high friction, etc.).
Possible FRUs is Robot Assembly
Sep 01, 2013 | IBM System Storage TS3200 Tape Library...
8D 00 00
When I switch-on "Mammoth" tape drive, the following error appears on the mammoth display " ERR: 8D 00 00". What is the problem and how to resolve ?
Thanks in advance.
Feb 11, 2013 | Tandberg Data Exabyte Exatape Mammoth 8mm...
How can i remove a disk in the cd rom
Look for the small button in front of your CD-ROM and press that one. Your CD-ROM should now open.
Thanks & Regards,
(-_-)
Mar 23, 2011 | Exabyte Refurbished 200 SLOTS 1 MAMMOTH...
Unit in-op
When you first power the unit on, it performs its power-on self-test for about 30 seconds. When the tape drive is ready, the top LED turns off.
If you attempt to insert a cartridge into the
tape drive during the power-on self-test, the tape drive will eject the cartridge.
So, as long as it works after a few minutes, the unit is fine.
Mar 16, 2009 | Exabyte Eliant 820 Tape Drive
Lib 81-AIT4 LCD message initizalizing Drive
tape drives is failure or the library can't find the tape drives. regards
Dec 04, 2008 | Sony (LIB81A3BB) AIT-3 Tape Drive
StorageTek L40- Service required Led Blinking always.
Remove the server connection from the library.
power on the library, follow the display in the front panel. The library will do some checks. Note where it fails. Press the select button, it will display the some code message. With the error code refer the manual.
Sep 18, 2007 | Storagetek L40 DLT Tape Drive
Exabyte 220 MAMMOTH (2700061150) 8mm Tape Logo
153 people viewed this question
Top Exabyte Computers & Internet Experts
David Payne
David Payne
Are you an Exabyte Computer and Internet Expert? Answer questions, earn points and help others
