Question about Hotpoint WMA76 Front Load Washer
Washing Machine I have just tried to use my washing machine which is a Hotpoint Ultima WMA76, and it will not start because the RED SAFE LIGHT has illuminated, have you any ideas.
  • 432 Answers
Which symbol is illuminated? Red keyhole? Child safety? Red tap? End status?
Posted on Jun 27, 2007
Leaking hotpoint ultima washing machine
Hotpoint ultima wt965 washing machine This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 16, 2012 | Hotpoint Washing Machines
Light of a red tap
This is indicating a problem with the water supply, check the inlet hose/s for a restriction or kink in the hose/s.
Make sure the tap/s are fully turned on, and that there is a good water prerssure.
May 27, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima wma76 water level switch loaction?
Should be located under the lid near the top edge, round shape with a tube going to the bottom of it and wires in the front. To remove from the frame turn the whole thing 90 degrees as fitted with with rectangular fitting on rear.
Jan 21, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima wma76 stopped spinning is the motor /brushes in top or bottom of casing had other hotpoints and the brushes seem to go evry 5 yrs or so? are they as easy to change as the older models?
it is as easy as the older modles but the motor is at the bottom and you have to take out the motor to replace the carbon brushes hope this helped.
Aug 29, 2009 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima
The filter is located in the sump hose at the rear bottom of the m/c.
You need to remove the large clip that holds the hose on
Access is gained by removing the lower rear panel.
Oct 25, 2008 | Hotpoint WMA76 Front Load Washer
Test on washing machine
yes try pressing the on/off button and start/cancel button at the same time
May 26, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Faulty Hotpoint WMA76 washing machine
it may be 1) a connection loose at the motor 2) motor brushes are worn out 3) a pcb fault check in that order.
Feb 16, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint WMA76 Leaking door and soap tray
you may be using too much detergent, or you have a blockage in the outlet.try putting it on to spin to drain out the water, if it does not drain then check the filter or sump hose for a blockage
Jan 23, 2008 | Hotpoint WMA76 Front Load Washer
Hotpoint WMA76 Front Load Washer Logo
333 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
