Electrolux EWW 1273 fabric softener not draining
barkencoa
  • 3463 Answers
SOURCE: Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Posted on Nov 25, 2008
MNTECH
  • 1543 Answers
SOURCE: Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
Posted on May 23, 2009
farr64
  • 121 Answers
SOURCE: bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Posted on Sep 14, 2009
57 varieties
  • 1653 Answers
SOURCE: My bosch nexxt washer will not drain the fabric
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Posted on Oct 23, 2009
beltronic205
  • 1474 Answers
SOURCE: fabric softener will not drain
Try cleaning out ..this should cure . the other thing that can cause this is a faulty solonoid valve as some machines have a seperate valve for this action....
Posted on Nov 25, 2009
After wash was completed, there are water sitting in fabric softener tray up to the full line
Hello Warren, thank you for your post!
From what you have described there is water filling up the fabric softener tray in your Electrolux washer, EWFLS70JSS. At times water will fill into your fabric softener due to draining and siphoning action however, this is a normal operation within your washer. Hopefully this information is helpful to you. -Matt
Feb 26, 2016 | Electrolux EWFLS70JSS Washer
Why does water collect in bleach and fabric softener drawer?
Hello friend, thank you for your post!
This is a normal part of the siphoning action of your drawer. You would just remove the dispenser and discard the water. Hopefully this is helpful. -Matt
Sep 08, 2014 | Electrolux Washing Machines
Why wont it take fabric softener?
What kind of washing machine you have, top or front loader?
Sep 04, 2014 | Electrolux Washing Machines
Electrolux Washer dryer EWW 1273 banging
I think a sensor is being faulty when you load and go to use the unit. Also might want someone to check out the timer on the unit just in case it is going out on you.
Aug 08, 2012 | Washing Machines
I have an Aqualux 1200 washer/dryer. After the wash cycle the fabric conditioner compartment of the tray is full of water and the fabric conditioner appears not to have been flushed into the machine
If the dispensers are in their proper spot it is normal for some water to be left in the fabric softener dispenser. When you add your softener add water to dilute it as some softeners are very thick and don't dissolve well especially in cold water
Nov 18, 2010 | Electrolux EW1200i Front Load Washer /...
The fabric softener dispenser does not drain. I have diluted the softener with warm water every time, still the fabric softener will not drain out. In the spin cycle the softener is thrown around the top...
The softener dispenser is supposed to get flushed during the cycle to prevent clogging. The flushing may not be happening in your machine and some residue could be clogging the discharge.
Nov 12, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Electrolux front loader, softner dispenser doesn't empty
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Sep 02, 2010 | Electrolux Washing Machines
Just finished 2 washes with my Electrolux (eifl55IRR) washer and both times there were still soap suds in the machine after final rinse and final spin. I used just the right amount of HE detergent as...
Use a compatible fabric softener. The fabric softener not only softens fabric and makes clothes smell nice, but they break down and neutralizes detergents.
Mar 14, 2010 | Electrolux EW1000i Front Load Washer
Fabric softener is not dispensing
drain tube stopped up with softener needs cleaning
Feb 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bosch nexxt washer fabric softener not draining
Sep 14, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
