OCE TCS 500 SCENER ERROR CODE 10831-4
When scaning orig black line in plot
  • 141 Answers
SOURCE: adriatik
can't find home position. either the scanner assembly needs to be replaced, or the engine control board is defective. my guess is scanner assembly. good luck!
Posted on Sep 20, 2008
SOURCE: Error in Oce 9400 Plot Director Win 2000
There are a few possible solutions.
First, only the last version of Plot Director (3.4.3) works in Windows 2000, so make sure that is the version being installed.
Secondly, once PD is installed and uninstalled all registry references must be removed before attempting to reinstall or you will encounter errors.
Third, make sure you have Administrator privileges when installing or editing the program.
Last, because there has been no development on PD since 2001 it may be having issues with security, such as the ability to edit files that are in a protected zone or communicating thru a firewall.
As a test make sure that none of these programs are active during installation or configuration.
Posted on Mar 03, 2009
SOURCE: Oce tcs 500; system administrator passwork
Old post but will print for future ref - the system administrator password is SysAdm
Posted on Jun 22, 2009
SOURCE: OCE TDS600 Error Codes
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC.
Posted on Aug 31, 2009
SOURCE: I forgot the password for key operator oce
The Key operator password: KeyOp
The System administrator password: SysAdm
The Service operator password is: Please send an e-mail for me!
diplomamunka (at) citromail.hu
Posted on Mar 27, 2011
Is there a quick set up instruction for an OCE TCS 500 if so where could I get it.
Go to downloads.oce.com and put in your machine type. Go to manuals and download what you need.
Sep 22, 2017 | OCE Office Equipment & Supplies
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8507,i want A Solution
Turn off the printer, and let it cool for an hour. The problem will return, but you may have the ability to get some emergency plots out in the mean time. The error code has to do with a thermistor in the fuser section. These thermistors are made out of a delicate ceramic and are easily broken or cracked if installed incorrectly. I would recommend that you call an authorized Oce/Canon service representative unless you want to spend several hundred dollars on incorrect, or broken thermistors you may get via other official channels. Each Oce model may have a different rating of thermistor, so just putting any thermistor in most likely will not solve your problem and may cause others.
Mar 10, 2017 | OCE Office Equipment & Supplies
Hi i have a problem with oce plan printer 500 it gives me error code 03504 please help me what i need to do
Oce (Canon) makes 3 different types of "500" plan printers. The ColorWave 500, the PlotWave 500 and the old TCS 500. If you mention the proper model number you might get a faster answer. If you have the TCS500 this is a head calibration error. Was a printhead recently replaced? If so it is more that likely that either the plastic seal was not completely removed from the new printhead, or there may be some ink on the contacts on the inside of the printhead socket. Reinsert the printhead in question, and see if this solves the error. Power down the printer and unplug it from the wall. Clean the inside of the printhead socket with a long swab and some isopropyl alcohol. Plug in and power on the printer after replacing all printheads. On extremely rare occasions brand new printhead do fail, so if you have determined you might have a faulty printhead, replace it with another.
Feb 08, 2017 | OCE Office Equipment & Supplies
Oce 500 plan printer error code 03504
Why am I getting the error code 22550
It would be helpful to know the exact model number of your printer and the software level. If this is a PW300, it is an Initialization Error. Something is out of place that is not allowing the printer to start up properly. Opening and closing the lids may temporarily solve the issue but if it keeps on returning without having jams, there is either a sensor problem or the code level may need to get upgraded. New code levels have fixes that prevent false jam indications.
Jun 24, 2014 | OCE Check Plot Bond Paper, 20 lbs., 34" x...
Oce tds320 plot leaves 3/4 wide black lines across print
Several things may be wrong, but first this unit needs to be cleaned and inspected. The drum, and cleaning blade may need changing and so will the corona/charge wires.
Feb 06, 2014 | OCE Office Equipment & Supplies
I have plotter HP designjet 500 24" but when plotting from autocad do not plot in gray color, even though layers as assigned in light colors on the plot style.
You need to set up your pen assignments in Autocad, have you done this? ie, Pen1 is 0,25 black, pen2 is 0,35 blue etc,etc. If this is not done you will have problems with colours and line thickness's.
Jun 25, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
I forgot the password for key operator oce password, in order to configure the scanner for the Oce tcs 500 i cannot put any path for the scanner unless i log in . please i need help asap. thanks.....
Apr 22, 2010 | OCE Office Equipment & Supplies
I am guessing this is a Windows XP system that it is connected to. Reboot the computer and as it is booting press the F8 key. It should bring up a menu for boot options. Select Safe Mode and at the log in screen select Administrator with no password. In a lot of cases this will get you in so you can go to the control panel and remove or reset the password.
If that doesn't work you can also search on google for XP Administrator Password Reset CD.
Cheers
Jan 03, 2009 | Office Equipment & Supplies
Adriatik
Aug 22, 2008 | HP LaserJet 3330 All-In-One Printer
213 people viewed this question
k24674
jasbo
jasbo
