Question about Electrolux Zb2803 Unirapido Rechargeable Stick Vacuum Cleaner, Fresh Yellow
ZB2803, charging light on, then it goes off but there is no power. What is the problem
When I plug it in to charge, the light goes on indicating it is fully charged, but when i use it, it last about two seconds and then goes dead.
5 Suggested Answers
  • 3 Answers
SOURCE: Not charging. Lights up momentarily, then goes out
i have the same problem with 3 of my vacuums, fixed it by using my rc charger.
Posted on Aug 15, 2009
  • 3 Answers
SOURCE: Vacum cleaner flashes lights and goes dead.
Do you put it down before you turn it on? some vacs wont turn on in the upright position. Happened to me once til I stepped on the button to bed it back then powered right up.
Posted on Jan 15, 2010
SOURCE: My Electrolux Pronto is not charging. When I put
Call electrolux there was a battery recall
Posted on Apr 17, 2010
  • 2418 Answers
SOURCE: When I place the entire
Take the small vac. out of the main unit. Check the contacts on the inside of the main unit and also on the back side of the small vac. Be sure they are all clean and that none are bent. Check also the back of the main unit to the base contacts; same here make sure they are clean and free of dirt. Check the transformer wire from the wall to the base fell for hot spots or kinks. If all these things are in good shape, last ditch is to put the small vac. in a zip lock freezer bag and put it in the freezer over night and then try to re-charge it. It that does not help. It should have some warranty left. I think it has a year of warranty. See web site >>>> Warranty Info. Hope this helps.
Posted on Jan 27, 2011
When I plug it in to charge the blue charging light comes on for 2 or 3 minutes then goes out and charging stops. Have I blown the charger by constantly leaving it plugged in? Please help!
Hi Alvina, it's Jack at Dyson.
DC59 will display a blue indicator light at the base of the hand grip while the machine is taking in power. The light will go out when the machine is fully charged. DC59 will take 3.5 hours to charge fully when the charge is completely depleted, but it will take less time than this if there is still some charge remaining on the battery after use.
Please note, the machine's intelligent control software is designed to ensure the battery only takes in enough power to recharge, and to keep itself topped up. It's safe to leave the machine connected to the charger at all times when not in use - the machine is designed to be stored in this way, so it's always ready to go when you need it.
From the information you've provided, I'm not clear on whether or not you're finding your DC59 works as normal once the blue charging light goes out, or whether it's not working at all. To make sure everything is correct, please get in touch with our experts directly. We'll be happy to talk you through some simple diagnostic checks when you have your machine easily to hand.
You can reach the Dyson Customer Helpline by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
We'll look forward to speaking with you.
Feb 27, 2016 | Dyson DC59 Animal Bagless Cordless Stick...
Brand new first charge The green light on the charger plug goes off after a short time. Is the unit still charging?
Once the green light goes off, it's done charging. Since it was first charge I know they say to charge it 8? hours (or 4? don't recall right offhand) but it does come charged (that's part of how they make the batteries). What you do want to do is remember not to always recharge it when your done using it. Use it till the battery goes flat, then recharge it; it will give you a longer battery life that way.
Jan 09, 2015 | Dyson DC34 Bagless Cordless Hand Vac -...
Batteries are dead will not recharge
I do believe the company sells their own batteries for your product and even if they dont, you can always buy them yourself.First look on the back of your product and see what size you will need.
Nov 26, 2013 | Electrolux Zb2803 Unirapido Rechargeable...
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
The unit won't charge after plugging in to outlet.
Its the battery cell, its dead and unable to hold a charge. you will need to purchase another cell.
Feb 16, 2009 | Scunci 52033 Canister Wet/Dry Vacuum
ROOMBA 415
It could be the power button itself. If you have a Roomba remote, try using that to power on the robot.
Sep 28, 2008 | iRobot 4150 Roomba Vacuum
Electrolux Zb2803 Unirapido Rechargeable Stick Vacuum Cleaner, Fresh Yellow Logo
213 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
