Question about Ovens
EOB 68200 ovens glass touch problems, button "+" is not working.
4 Suggested Answers
amgm
  • 32 Answers
SOURCE: Electrolux EOB 966 stuck in auto mode
Hi, try to switch it off at the main switch. Wait for 10 seconds, then switch the power back on, reset the clock, and you should be fine.
Cheers
Posted on Feb 12, 2009
  • 174 Answers
SOURCE: I have an electrolux EOB 945 fan oven that is not
fan element round the fan has failed
Posted on Jul 23, 2010
SOURCE: Resealing Inner Oven Glass
I guess you worked this out already as posted a while ago....but for others like me I thought adding a solution might help..........Open the door fully and on the hinges there is a clasp, flick that back on itself on both hinges. Close the door carefully and it will stop half way....now lift the door off the hinges. Lay the front of the door on the floor and there are 4 screws on the bottom of the door...unscrew the middle 2 (the outter 2 attach the hinges). then lift off the back of the door....you now have the access you need!
Now i have done this I need to get the sealant....is there a shop you can get this from B
Posted on Oct 09, 2010
Need a manual for an Electrolux built in oven - model EOB 944
Try going to Electrolux web site and look up all manuels then find the one you need. Order or possibly download.
Jul 15, 2012 | Ovens
HOW TO RESET CLOCK
Hi there
i have found the userguide of the EOB 53011 , poortuguese , italian and spanish on :http://www.electrolux-ui.com/2011/397/214301ES.pdf
There is stated on page 23 ( will translate ) :
By connecting the unit to power supply
or in case of power failure, the function indicator Time flashes automatically.
To adjust the current time, use the
"+" Or "-".
After about 5 seconds, the indicator stops flashing and the display shows time set.
Ihop this information will help you
Feb 17, 2012 | Electrolux Ovens
F1 ERR message on EOB
What is the make of your oven?
Dec 29, 2011 | Ovens
I have a Kenwood MW750 microwave oven and the problem of this unit is when I switch "ON" it will have a display of G90d and all the operator's button were disabled.
the code is a touch pad error. This usually means that the touch pad has failed. Have it replaced and this should take care of the problem. Hope this helps. Good luck.
Jan 09, 2011 | Ovens
The Bosch Evolution 700 Series Model HDS7282U control board functions do not appear to work properly for the "time" and "off" functions. You can turn the oven on, however, cannot turn...
What this simply indicate from the statement you have posted to me is that the the oven has develop a wiring problem on the control unit(panel).
What you are to solve the problem , first of all put of the oven from the main power power supply(i.e from the wall) remove the plug from the wall for some time then put it on again, after this then make sure that the oven is reprogram from the timing and also from the and hold on to clear or council for some seconds to allow the button to respond to power control.
Good luck and thanks for you fixya.
Nov 27, 2010 | Ovens
Displays an F5 fault code on kenmore wall oven model 911-47469
HI. This is a touch pad issue. You will need to inspect for binding of the push-buttons and control panel glass. If OK, replace the touch panel board.
Oct 06, 2009 | Kenmore Ovens
Jul 16, 2009 | Electrolux Ovens
Kenwood elite glass top range shows error code F7 for all burners.
F7 indicates a stuck touch pad key. Try pressing all teh buttons on the key pad to see if one is stuck. If you don't have a stuck key, there may be a problem with the key pad module itself
Mar 07, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Cheers
Feb 12, 2009 | Electrolux EOB6696X Electric Single Oven
Ovens Logo
23 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
