Question about Balance Computers & Internet
I need a manual for the Balance EZ17J Monitor
I am looking for a manual for the Balance EZ17J Monitor
Where can I find usage instructions for the New Balance 52534 wrist monitor?
Hi Bonnie....call Neobits at 1 866 636 2487. I think
they will help you with a manual.
Regards,
Dennis
Nov 05, 2014 | New Balance 52531NB Calorie Tracker
Looking for new balance duo sport manual
Your answer is simple. You cannot shut the unit off. It stays on all the time - it has a clock built into it that is always running and it also has memory of your stride and your preference as to miles or kilometers. You can remove the battery and really power it down but then you lose all your settings and will have to re-enter your stride, the current time, etc.
Good Luck
John from Port Jefferson Long Island NY
Aug 01, 2013 | New Balance Balance Duo Sport Watch Heart...
Missing adapter or plug in connection to 15 balance mointor model 2015
The Balance CM2015 monitor uses a VGA connector,
http://www.ebay.com/ctg/Balance-CM2015-15-LCD-Monitor-Black-/52125929
(The above is for reference only. Not advertising)
A VGA connector is also referred to as a 15-pin D-Sub connector,
http://en.wikipedia.org/wiki/VGA_connector
This is information on a DVI cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If this is the monitor cable you have, you need this type of adapter,
http://www.directron.com/dviadapter.html
Now LOOK closely.
This adapter has male pins that stick out, and go into a female VGA connector on the monitor. The DVI side of this adapter has socket holes, for a male DVI cable.
IF, your monitor has a male VGA connector on it, and the DVI cable you have has socket holes, you need this adapter,
http://www.directron.com/dvitovga.html
If your monitor cable is not a DVI cable, post back with the style it is.
If nothing else post how many pins are in the connector on the cable, and how they are arranged.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 27, 2012 | Computers & Internet
I need the drivers. or the web site can not find it on the web
Hi
The .inf drivers for almost any computer monitor is already built into ALL operating systems.
There are, generally, no drivers necessary or available for monitors.
This is the way it works. A computer's Graphics Card (which is, effectively dedicated a mini Motherboard with its own dedicated RAM Memory, Heatsink and/or Cooling Fan and Microprocessor - GPU), purely to power and manage the overall graphics capability of the computer. The Graphics Card does most of the work involved in taking encoded or decoded image files from your computer, from a DVD or VCD, from the internet or from a typical, external imaging source like a Smart Phone, Webcam, Digital Camera, Camcorder or a Media Player and then and interprets these image files into the analogue or digital signal (depending on monitor type) it sends to the monitor for it to resolve into an image.
A monitor has a range of Resolutions it can operate within, and if the Graphics Card or Graphics Chip Setting are set too high or too low, outside this range, the next time the computer is restarted or shut down and powered up again, the monitor might be incapable of resolving the image and therefore remain blank, as the computer boots, leaving the user blind to its Desktop.
Other faults preventing monitors from displaying images include foreign metal objects or bent, touching, pins shorting in the connectors at each end of the VGA (Analogue) and DVI (Digital) Video cables that link the Monitor to the computer. The cable may also have a failure or a fault somewhere along its length or a failed connection at the junction of cable and connector.
The quality of the image displayed on the Monitor is mainly governed by the resolution of the image, which is controlled by the software governed settings of the Graphics Card
If none of the above is preventing the Monitor from functioning then the Monitor might have an internal fault. The inside of Monitors and TVs are a hostile, non User Repair Friendly working environment, with lots of capacitors storing relatively high charges even when the monitor in not connected to the mains electricity, that can seriously injure or even kill an inexperienced repairer.
Internal monitor repairs are rarely economical because a successful repair often requires the replacement of a faulty internal component, the cost of which, when added to the labour cost involved in the repair, is unsustainable, given the widespread availability (due to the rapid uptake of HD technology) and relatively low cost of Warrantied new and 2nd user models in the marketplace.
If your Monitor is powered by an AC/DC Power Adapter, check for any faults with the Adapter that might be preventing the power from reaching the Monitor and if, found, consider a replacement adapter from here or from similar sources to this:
http://www.ebay.com/itm/NEW-AC-Adapter-Balance-Digital-Technology-EZ17J-LCD-/320744475938?pt=LH_DefaultDomain_0&hash=item4aaddc4d22
If the monitor proves to be faulty and none of the above solutions remedies the fault, it may be time to consider buying a new Monitor.
Definitely do not waste any more time looking for Monitor Drivers.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. This helps Answerers, like me, better understand the needs and the point of view of the Asker and guides us in exploring the best ways to provide useful, high quality Responses.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Sep 03, 2011 | Balance CM2019 19" LCD Monitor
I am not getting the correct colors from my SLR camera. Is this due to my computer monitor?
Yes, the monitor need to be calibrated using an optical attachment (looks like hockey puck) that is placed on the screen using software, but the monitor must support automate software calibration. You can google for LCD monitor color/white balance calibration tools.
Apr 07, 2010 | Balance CM2019 19" LCD Monitor
I need to know if there is still some were to purchase and Ac Adapter for a Balance LCD Monitor CM2019?????????
All you need to know is:
- The output voltage (usually 12V)
- The rated output current (usually above 5A)
- The plug polarity (usually plus on the inside)
Then just purchase any replacement AC adapter that has the same voltage, same plug polarity and rated current preferrably more (at least 120%) of the original.
That's it.
You can buy them online, for example at http://www.12vadapters.com/
Dec 24, 2009 | Balance CM2019 19" LCD Monitor
Power supply cord
Any power supply providing 19V DC at 3 Amp with a positive tip connector will do.
Hope that helps.
Jun 13, 2008 | Balance CM2017 17" Monitor
Lost the power cable
If this is a non standard type of power cord that cannot be localy purchased, look up the manufacture name using Google or Yahoo. Find their support page, and enquire about how to order a new cable.
Jerry G.
May 25, 2008 | Balance CM2019 19" LCD Monitor
Easy
If anyone is still looking for this power cord I have one for sale. Product No. CM2019 MODEL: F192
This goes to a Balance LCD Monitor (Balance Digital Technology). 15 V , 4 A ( 15 Volt , 4 Amp )
I realize this post thread is old.
Oct 18, 2007 | Balance CM2019 19" LCD Monitor
Computers & Internet Logo
61 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
