Question about Miele Premier-Plus Built-in Dishwasher
Naples. I have a dishwasher Miele G 1222 SCU. MI appeared in mid wash F 70. It is locked and acts as a continuous exhaust noise even when switched off. I had to turn off the main power.
5 Suggested Answers
  • 9 Answers
SOURCE: Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Posted on Apr 20, 2008
  • 122 Answers
SOURCE: MIELE DISHWASHER PARTS
We would have to order one -
Mike
Posted on Jan 04, 2009
  • 2920 Answers
SOURCE: looking for a steam deflector.
go to a used appliance store they can help you with what you need..they may have one on hand they can sell you
Posted on Jan 29, 2009
caroldon
  • 17130 Answers
SOURCE: I have a Miele SCU 648. The "start" and "end"(or
It is possible that a low water pressure can increase the time for the program and so this can lead to the program contrroller hanging up to show the flashing.
So remove the inlet and the water line to the inlet, check the filter and the inlet valve. If the pressure seems good , check the flow when the program starts.
Also counter check on the water level sensor, the drain pump/valve. finally check the winding on the heater using a multimeter, check the power to the heater during the program.
Posted on May 03, 2011
Miele Dishwasher stuck in drain mode, lights don't work, makes rattling sound from door. Model: G 2243 SCU
Anti flood switch has activated , check regeneration valve on right hand side of dishwasher , o ring may need hanging
Apr 08, 2017 | Miele Dishwashers
May 03, 2011 | Miele Dishwashers
I have a G 892 SCU Plus dishwasher and the intake /drain light has gone on
I removed filter basket and under it there was a small chrome rod prodruding horizontally by about 3cm. I pushed this in and restarted the machine. Although the light flashed when I first switched on it went out when I started the prograamme. It is working fine now.
Sep 20, 2010 | Miele 24 in. G892SCU Plus Built-in...
Fault 11 - inlet or outlet blockage
THIS TYPE OF M/C PERMIT WATER TO FILL IN LONG TIME IF THE PRESSUR IS LOW
I THINK AFTER ABOUT 3 MINUIT YOU CAN OPEN THE DOOR AND CHECK OF LEVEL OF WATER TO ASSURE IS LEVEL OF WATER IS SUFFISUNT OR NOT
Jun 14, 2009 | Miele Incognito G658 SCVi Built-in...
Looking for a steam deflector.
Jan 29, 2009 | Miele 24 in. G643Vi Plus Built-In...
Miele Premier-Plus Built-in Dishwasher Logo
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
