Question about Balance Computers & Internet
I have a balance EZ17J monitor and cant find the sound jack
I need a manual for the monitor
How do you hook up sound from surface rt to acer monitor 2014
To connect anything to the speakers on your acer monitor you need to use an audio patch cable that has 1/8 inch or mini headphone jacks on each end. Like this one.
5mm Male to Male Stereo Audio Cable...
You connect one end to the headphone jack on your Surface RT and the other to the audio in jack on the monitor. Make sure the power is on for the monitor and that the volume on both is a third or half way up and you should be able to hear the sound.
This is for the monitors user manual.
Acer AL1715 User Manual Amazon com C2G Cables to Go 27413 3
Jun 13, 2014 | Acer 22" X223w LCD Monitor
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    How do I activate the sound for my monitor (CM2019). Our old speakers broke and I want to use the speakers in the monitor.
    On the back of the monitor, look for a small jack with green color with the 'AUDIO INPUT', 'AUDIO LINE INPUT', then you will need an audio cable with mini stereo phone plug at each end (get it from Radio Shack). One end of the plug will go into the monitor AUDIO input (green), and another end will go into the PC AUDIO line out (Green jack) just like where your old PC speaker cable was plugged into. You need to set the volume level on your monitor to about mid point first and redjaut it later on.
    Picture of the audio cable with pugs.
    Aug 22, 2010 | Balance CM2019 19" LCD Monitor
    Hi, I have a Samsung SyncMaster215tw, I've been using speakers to hear music and movies but recently gave them away, how can i get sound directly from the monitor?
    The manual (you can download it here if you need a copy) shows an audio input jack right next to the VGA input connector. This jack takes a 1/8-inch stereo plug the same as the output jack on the computer. You can use the same cable that is usually supplied with computer speakers. Just plug the cable into the computer's sound output jack and the monitor input. I'd recommend setting the volume on the computer to maximum, and using the monitor volume control to adjust your sound.
    Apr 01, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
    Need power cord for CM2017 Balance monitor 19Vdc 3A , connector is one single post Nothing comes up online, no one has heard of Balance Brand
    As a workaround, simply get yourself a switchmode power supply that has the spec's 19 V DC @ 3 Amps, now, carefully cut of the end of the "Old" Power Jack, and the end off the "New" power jack, and Join up the wires, usually the "Inner" one is Positive, +, and the "Outer", or shield, is Usually negative, -, If you have a meter this should be used to check, connections. Otherwise just ensure you are correct. That should get you going, even if you cannot find an original, in fact, you may even find, that the PSU, you get has "Multi-way" changeable ends.
    Feb 26, 2010 | Balance CM2017 17" Monitor
    I have a HP 1755 flatscreen monitor but i cant get it to work
    There should be a 3.5mm stereo phone jack on the monitor. You need a 3.5 male to 3.5 male cable to plug the monitor into the speaker out from your PC. Cable can be purchased at Radio Shack for under $10.
    Sep 03, 2009 | Computers & Internet
    Audio problems
    To use the integrated speakers on this monitor you will need the audio cable. Most monitors with built in speakers has a single cable with a green jack on both ends. It would plug into the audio jack on the back of your monitor and connect the monitor to your soundcard jack on the back of your pc. Cable should be able to be purchased at any electronics/computer store. Hope this helps.
    Jul 08, 2009 | AOpen F75PS 17" Flat Panel LCD Monitor
    Lost manual for hp compact.
    The speakers wires are normally color coded if the computer isn't ancient, the Speaker PLUG is green, if you are using the speakers in the monitor, then plug the green one from monitor to green jack on back of PC, (Microphone plug and jack is pink/Red).
    If you are using other speakers 3rd party, 4.1,5.1, the hookup is different usually, But I think you need green to green, there should only be one green plug on back of PC, It may be labled sound out. but yours is probably green.
    PS you also need to kake sure the monitor speakers dont require their own Power Supply/ AC adapter, Most of them do, while some desktop and monitor speakers do not just connect the cord ffrom monitor to green jack, "sound out". If this helps, thanks for the feedback
    Mar 31, 2009 | HP Pavilion F1703 17" LCD Monitor
    I have acer al1917w A monitor but no sound
    There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
    Jan 09, 2009 | Acer AL1917W LCD Monitor
    Computers & Internet Logo
    Top Balance Computers & Internet Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Jaime Hernandez
    Jerry Greenberg
    Jerry Greenberg
    Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
