Question about Whirlpool Duet GHW9150P Front Load Washer
Ring somehow got through to drum mechanism
Somehow a ring got past the rubber seal when the maching was on high speed spin. The machine made a noise consistent with something getting jammed in the mechanism - i thought it was the bearings seizing. By the time i got upstairs the noise had stopped. I opened the door and could see nothing wrong, i re-started and it worked fine. I've done several loads since with no problems.
The ring must be somewhere under the drum.
If I run the machine am I risking the ring doing damage?
How difficult is it for a repairman or for me to get at the area where the ring is to remove it?
Allan
    Genius:
  • 2,920 Answers
It shouldnt take much to get it out.call them in and have them pull it out so it cant do any other damage to the machine
Posted on Jan 19, 2009
  • Ronnie Houston Jan 19, 2009
    it shouldnt take much to get it out.call them in and have them pull it out so it cant do any other damage to the machine
My front loader LG washing machine noisy on spin.
i am guessing the rubber is from the door seal gasket and i am guessing that the clicking and noise and shaking is from the bearing that the drum spins on being worn out. not an unheard of issue. there are some very good videos on taking the washer apart and replacing the bearings if you are up for it. check out repairclinic.com or appliancepartspros.com. enter your model number and look for the corresponding videos. lots of steps, but really not all that hard. just label the parts/screws so they go back where they came from. all you may need is the bearing(2) and the seal. (get a homedepot 5 gallon bucket as a support for your drum as you work on it). i am pretty handy and a bit of a risk taker(its is already broken so how can i break it more?) and did this from the videos having never worked on a washer of this type before. good luck.
Jul 14, 2015 | LG Washing Machines
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual.
relevant info pasted below: --
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
Jan 10, 2012 | LG WM3987HW Front Load Washer / Dryer
Noisy drum bearing also play on drum
Apr 30, 2011 | Washing Machines
My Hoover wasing machine 800RL is making a very loud winding noise on the spin cycle. could you please advise me what it is
hello ,
from what you described there could be a few things going on ..:
1..one of the rubber rings that balance the drum is either loose or broken ..
2 the bearing from the drive shift is defective ..
3 the counterweight is loose from the screws ..
4 the position on the horizontal plan is not perfectly
5 one of the screws ...is loose somewhere and is vibrating only on high speed spinning ..
But usually is either the suspension rubbers or the counterweight being loose
Mar 17, 2011 | Washing Machines
The washing machine is working alright but when its spinning, theres a noise that sounds like its something broken inside... But u cant hear the noise when its on fast spin.
Can be front the drive at the bottom of the washer. I assume this has a high speed spinning and so there is a gear box which can be having less lubrication. So make sure that the motor drive section of the drum shaft assembly is well lubricated so that the noise at high speed reduces.
if you can do a mechanical job , it will be good to remove and reset with good lubrication and maybe replacement of the bearings.
Jan 20, 2011 | LG WD-16115FD Front Load Washer
Smoking washing machine
Switch it off before you burn your house down
The drum support sounds to have either cracked or come loose allowing the drum to run on the door gasket
The friction will cause the rubber to melt and burn hence the smoke.
Get a service person out to it asap
Jun 14, 2009 | Whirlpool GSC9455 Top Load Washer
I have a GE Profile Harmony Washing Machine WPGT9350. The problem I am having is one I believe somehow related to balance resulting in a noise of the inner drum rubbing/banging against the outer drum. This...
GO TO www.repairclinic.com ENTER MODEL NUMBER, SCROLL ALL THE WAY DOWN AND CLICK THE RED 100 NOW LOOK FOR PART1089518 THIS IS THE BALANCE ASSEMBLY. IT IS SUPPOSE TO HAVE WATER IN IT. CLICK THE PIC AND LOOK AT ADDITIONAL. THE PROBLEM YOU ARE HAVING IS EITHER THE SUSPENSION ASSEMBLY OR SPRINGS BUT NO YOU SHOULD NOT HAVE DRILLED THOSE HOLES. YOU MAY CALL REPAIRCLINIC AT 800-269-2609
May 01, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Oct 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Load remains wet after full cycle (including spin @ 1400 rpm)
Hi Paul, Assuming it is pumping out ok, Unplug the machine tip it back at an angle, underneath you will see a black hose that is attached to the bottom of the drum, remove this, take out the ball and discard it and remove anything that may be in the filter, replace the hose and try the machine.
Nov 30, 2007 | Hotpoint WMA64 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
139 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
