Question about Epson Powerlite Home Cinema 8350 Eh-tw3600 Lcd 1080p Projector
HDMI not supported Message - It doesn't recognize Signal-Inputs from HDMI-Cables (neither HDMI1 nor HDMI2)
In my old place it was working perfecly fine. After moving to a new location and making all connections it doesn't recognize any HDM-Source (with VGA it works fine). But other thang that I don't receive any error-message.
dixibabe82
  • 54 Answers
SOURCE: replaced all ink cartridges after low ink warning.
First, are you absolutely sure you have the correct cartridges? Next, have you tried replacing the old cartridges that were originally there, or were they completely empty? Next thought is that your print heads might be dried up. Sometimes regular users can fix this with alcohol wipes depending on your specific model.
Posted on Mar 24, 2009
  • 240 Answers
SOURCE: printer errer message wont go away
try to reset it ..by unplug the printer while it is in on state..
Posted on May 17, 2009
SOURCE: Unable to load printer drivers.
I had this probem the other day with a backup computer, that I use only with photoshop.
Bad News is that I seemed to not be able to uninstall all epson little bits and pieces.
SO I totaly reinstalled the windows XP OS.
Now it works fine.
I know its a pain in the ***, but you might have to do just that.
Al C
OH YEAH, after you reinstall the OS,... Go to, my computer /files and take out the stuff you dont want ( EPSON). Otherwise you will still have the program in your hidden files
Posted on Jul 31, 2009
Soulvisitor
  • 1113 Answers
SOURCE: Get this Error message:
Ensure that directory is delete when you uninstall and there mates ie........ /EPSON/......whatevers.
Use a new set of downloaded drivers from elsewhere, not the same ones if you can help it and if you cant it is because they dont really exist, ones that work will be many places....... ensure full compatability to your mac OS, I can't help you much there but I can assure you it isn't a problem with the printer it is a mac/driver issue. Hope thaty helps a little cheers
Posted on Nov 06, 2009
Softwarrez
  • 67 Answers
SOURCE: i am trying to scan and i get the message
To work around this problem, you must create a Windows Firewall exception for TCP port 21. To do this, follow these steps:
  1. Click Start, click Run, type firewall.cpl, and then click OK.
  2. In the Windows Firewall dialog box, click the Exceptions tab, and then click Add Port.
  3. In the Add a Port dialog box, type Scanner and Camera Wizard in the Name: text box.
  4. In the Port number: text box, type 21.
  5. Click TCP, and then click OK.
Restart the computer and now you should be able to scan.
Cheers.!!!
Posted on May 18, 2011
Switching HDMI inputs
Plug all cables in the ports in the back of your television, the use the remote of the television select Source scroll up or down for required hdmi channel select buy stopping it on the channel then press ok
Jan 08, 2014 | Televison & Video
We have a Polaroid 4241-TLXB television. This evening we turned on the TV and the Video6 (HDMI1) is not accepting sound. The picture is fine when that input is selected. We had our STB attached to HDMI1...
I am having a somewhat similar experience. The HDMI 2 is a little flaky on these TVs, try turning the input device that is attached to HDMI 1 OFF then reboot the TV. For some reason, if there is a signal going to both HDMI inputs at the same time there are major problems. I also found that if I input L/R audio into the HDMI 2 analog jacks, that sound also goes to HDMI 1(if no digital sound signal is going there).
Feb 16, 2011 | Televison & Video
My ps3 is hooked up though HDMI to my emerson lc195emx. but the tv says its an unsupported format. why? is it because the tv only has 720p out put??
Try turning off the power to your console using the power switch in the back (first shut it down properly). Unplug the AV cables (if applicable) and the plug in the HDMI cable. Turn on the system and switch your input on your Television to HDMI. (Keep in mind that there may be a few inputs; HDMI1, HDMI2, etc.) The HDMI connection takes a few seconds so be patient. If that doesn't work, re post or ask to chat.
Feb 05, 2011 | Sony Playstation 3 (PS3) Console
Give me properly installation of stand alone dvr with computer all window how sport the dvr send me properly anstallation of standalone dvr
Take one co-axial cable, and connect the "input" port to your cable-company's wall-port.
Look at the connectors on the back of your TV. You could have:
* coaxial input (lowest video-quality)
* S-Video input (better video-quality)
* component input - three cables for video, two cables for audio (better video-quality)
* HDMI input (highest video-quality)
Look at the connectors on the "output" side of the PVR. You could have:
* coaxial output (lowest video-quality)
* S-Video output (better video-quality)
* component output - three cables for video, two cables for audio (better video-quality)
* HDMI output (highest video-quality)
Connect the "outputs" to the "inputs", using appropriate cables.
Turn the PVR on. Turn the TV on.
Use the "source" button on the TV's remote-control to select from the various inputs
(Coax, S-Video, Component, HDMI1, HDMI2).
If your TV has 'PIP' ("Picture-In-Picture") capability, connect more than one output to a second input, so that both tuners inside your TV will receive a signal.
Feb 03, 2011 | Computers & Internet
We finished watching a dvd movie with the sony surond sound dvd player and tried to go back to satalite and all i could get was no sig changed to all inputs and still nothing . I finally changed the cable...
Unplug,replug the tv about an hour later let the tv reset itself.Go into the tv menu,go to PICTURE go down to reset,this to reset ur tv Tuner signal board back to the factory setting.Those HDMI ports 1 and 2 should work again.Not than,ur Tuner signal board is defective,or the HDMI port 1 is shorted and dead.
May 31, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
No signal on HDMI1. Had to switch to HDMI2
Ur HDMI/1 might be shorted,will not work again.But u can tries unplug,replug the tv an hour later,let it reset it self back to factory setting.Who know might get lucky,it work again.
Apr 24, 2010 | LG 50PC5DC 50 in. Plasma HDTV
No picture when tv powered on
When power on and input set to hdmi1, there is no image appears
Dec 31, 2009 | Toshiba 32AV502R LCD TV
No picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Dec 06, 2007 | Panasonic TH-42PX60U Television
Epson Powerlite Home Cinema 8350 Eh-tw3600 Lcd 1080p Projector Logo
163 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
