Question about Kitchen Ranges
Need wiring diagram for Arietta Veneto Island range hood
5 Suggested Answers
hotuna
  • 288 Answers
SOURCE: wiring hookup
The 2 black wires on the hood go to the black from the wall. The 2 black on the hood is in case you want separate switches as 1 is for fan and 1 is for light. The green goes to the bare copper wire. Its the ground. And are you sure the wire is yellow? It should be white and connect to the other white. This is the neutral.
Posted on Mar 06, 2008
IbuyUSA
  • 9 Answers
SOURCE: Miele DA230-2
The latest DA230-3 hood is a 120V 15amp model and has a black/red wire to live, a white wire to neutral and a green to ground.
You may have a 220V model. I suggest to have a licensed electrician hard wire according to the voltage, load, and circuit rating listed on this data plate.
Posted on Oct 19, 2009
MNfisherman
  • 11896 Answers
SOURCE: My pacific hood range has only a black and white
ground wire goes to any metal surface for a ground. Hood, junction box, ect.
Posted on Nov 19, 2009
  • 11 Answers
SOURCE: can this be installed over an island?
Bring a focal point to your kitchen by having an island range hood, combining function and elegant form. A suspended hood is also an efficient way to vent
grease, odors and smoke to the outside from a island stovetop while you cook. You can install an island range hood in just a few hours with the right tools
and knowledge.
1.Wear safety glasses and work gloves. Turn off the electricity to your kitchen at the circuit panel. Cover the circuit breaker with a piece of electrical
tape to prevent people from turning the on switch while you are at work.
2.Lay work drop cloths on your cooktop and floor to catch dust and debris. Mark the duct opening with a pencil in the ceiling, where the island hood will be
installed. Be sure the opening is centered directly above your cooktop. Cut the opening using a hacksaw.
3.Go up to the roof, using a cat's claw and hammer to remove stucco, tiles, sheathing and insulation to make way for the steel venting duct. Drop a
plumb bob down the roof, making sure the line is straight down for the ductwork.
4.Follow the manufacturer's instructions for locations, installing 2-by-2 wooden blocks in the ceiling to hold the ductwork hangers.
5.Install the venting duct from the outside of the home, down to the location of the exhaust vents on the island hood. The ducts should easily slip into each
other. Secure all the duct sections with duct sealing putty, using a putty knife.
6.Screw a roof cap on the end of the duct at the roof. Seal any openings or gaps where the roof, ceiling and duct meet with silicon sealant. Let the sealant
dry, then paint with colors matched to the surrounds.
7.Place your hood upside-down on the floor, with the fan and filter facing upward. Locate and unscrew the metal electrical box cover on the island range
hood, to expose the wiring
8.Install the hood cover to the load-bearing ceiling frame with the package hardware through the four inside mounting corner flanges on the cover.
9.Measure what will be the distance from the bottom of your hood to the cooktop; it should not exceed 30 inches for exhaust efficiency. Have a helper hold
the hood in place while you attach the hood on the hood cover using the included screws. Use a level be sure the hood is level as mounted.
10.Connect the electrical wiring by consulting the manufacturer's suggestions or hire an electrician if you are not familiar with house wiring. Tuck the wires neatly in the hood electrical box and then replace the cover, after connecting the hood wires to the wall wiring.
11.Remove the electrical tape on the circuit breaker, turn on the electricity to your kitchen and test your island range hood.
Posted on Aug 09, 2012
Arietta hood model decor glass 30. When turning on motor hums. Fen does not working. What to do?
The motor is defective or the fan is jammed somehow, remove it and clean it first.
Jan 04, 2017 | Kitchen Ranges
Where is thermal fuse on arietta range hood model dk1001mk36
Likely it is mounted near where the hot-air would flow past it. If you don't have the tech info for the unit, follow the wires until you see a small device with two wires running to it... you will need a meter to test for continuity. Thermal Fuse 6930W1A003X it may look something like this one does, though this is for a microwave
May 13, 2016 | Kitchen Ranges
Is there an online maual
Arietta DKW001MX 30 Manuals
www.manualslib.com > Brands > arietta Manuals > Ventilation Hood
Arietta DKW001MX 30 Pdf User Manuals. ... We have 1 arietta DKW001MX 30 manualavailable for free PDF download: Use, Care And ... Arietta Range Hood.
Oct 15, 2015 | Arietta 30 in. Wall Mount Decorative Range...
How do i reset the grease filter indicator icon on the display on my arietta range hood
From the manual: To reset the grease filter saturation alarm the user must press the "+" key for 5 seconds, after this action the icon "grease filter" is not display [sic], and the hood has the normal display operation.
Feb 19, 2011 | Microwave Ovens
My hood keeps blowing the fuses for the rear lights.
There is a short in the wiring to the lights... probabbly a wire rubbed through...
Use an "OHM" meter to find the problem...
heatman101
Jan 12, 2011 | GE Monogram ZV1050SFSS 42" Island Chimney...
The wiring from the fan on my cooker hood has no earth is this ok
yes mam earthing is must and should be provided because of safety for the equipment and the operator,
Oct 06, 2009 | GE Monogram ZV1050SFSS 42" Island Chimney...
Can this be installed over an island?
and knowledge.
May 26, 2009 | KitchenAid KHVU781RSS Stainless Steel...
Wiring hookup
Mar 01, 2008 | Miele Designer DA230-2 Kitchen Hood
Miele DA230-2
Dec 26, 2007 | Miele Designer DA230-2 Kitchen Hood
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
