Panasonic G20 gives 13 blinks
I can't get my flatscreen to work. It's blinking 13 times a couple of times, and then it just shut down. The problem is that i can't find any discriptions on this error code. E.g. this site http://www.tv-forums.com/forum/TV_Equipment_C4/TV_Repair_Forum_F3/Looks_like_good_info_here_P151404/ dosen't tell what 13 blinks on a panasonic G20 is. Please help me. Thanks
3 Suggested Answers
  • 106 Answers
SOURCE: Sony FD Trinitron WEGA KV-34HS510 ... does not power up.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.This may help the solution or let no what is wrong!!
  • Posted on Mar 24, 2009
    snap101
    • 117 Answers
    SOURCE: Heater shuts down with C4-13 code
    your not getting enough fresh air to it. where is it located? you need 1 square inch per 1000 btu's. it's having irregular combusion.
    Posted on Aug 02, 2009
    Whydoes my Panasonic Plasma TV keeps shutting off every couple minutes with the red power button flashing continuously once it shuts off?
    These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
    http://electro-medical.blogspot.com/
    If blinks continue without any pause, the main board is faulty
    Mar 18, 2016 | Panasonic Televison & Video
    I was watching TV it shut off and the power button flashed a bunch. I unplugged it waited for a while plugged it back in. It did not turn back on until i held down the menu button on the set.
    I found the following blog on the web.
    Panasonic Viera Plasma Failure Page
    November 14, 2010 ·
    Blink Codes and what they mean (8-13):
    8 blinks Driver SOS 3 SS Board (SS energy recovery circuit)
    9 blinks Panel Config. SOS
    10 blinks Sub 5v SOS / Main 3v SOS DG BoardDTV 9v SOS / Tuner Power SOS
    11 blinks Fan SOS PB Board
    12 blinks Sound SOS H Board
    13 blinks Communication error DG Boardwith IC8001
    Make sure the inside of the TV is clear of DUST especially by the power supply and fins.
    May 02, 2015 | Panasonic Viera Tc-p42x5 42" Inch Flat...
    Panasonic TC P5G20 turns on but screen will not activate. It then clicks and the led blinks 13 times. I've turned it off and on a few times and once the light blinked 4 times, but it's now...
    These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
    Dec 16, 2014 | Panasonic Tc-p50g20 Viera G20 Series 50"...
    Tc-p50g20 4 blinks
    My panasonic TC-P50G20 does not power on, just I have 4 blinks on my powericon1.png indicator light. What error does that mean?
    Jul 24, 2013 | Panasonic Tc-p50g20 Viera G20 Series 50"...
    Panasonic Viera TH-42PV500A blinks 11 times after turning off by itself
    go to Menu, AND restore to the factory default. Read your owner manual or download from www.fitness.manualsonline.com +
    www.retrevo.com
    If the problem persist, you have problem with the power supply circuit. You must go to the repair shop TV for fix it.
    God bless you
    Jul 20, 2013 | Televison & Video
    Power button blinks red seven times on a 2007 Panasonic flatscreen VIERA.
    I had the same problem with my Viera. if you disconnect the power and ribbon cable from the YSUS board (check youtube for how), the light led will blink 6 times, indicating the YSUS is bad. Check ebay for TNPA5175 board (about $115-160). The "pop" is one of the DG402RP chips burnout. These are about $4, but only available from China. If you can wait a month for delivery, you can solder the new one to replace the bad one. You may want to purchase several in case more are bad or it happens again.
    Jan 15, 2013 | Panasonic VIERA Televison & Video
    Panasonic plasma red light blink 10 times
    DTV 9v SOS / Tuner Power SOS.
    These are the faulty boards and sections to be checked. Just visit the site named 'Electro-help'. Blinking codes and repair work with Panasonic plasma TVs are described in detail. Check this link, and select the site. Pull up older posts there.
    Jul 21, 2012 | Televison & Video
    Panasonic TH58PX60U TV comes on for 5 to 15 minuets and shuts down with 4 red flashes on trouble code light. Is this the power supply board?
    4 blinks Power SOS P Board
    Try opening it first look for some bad connections or so if they are none use a hair drier and heat the board looking for the place that creates the 4 blinking then use the hair drier on cool to cool the place and get this time little longer.
    Jun 02, 2011 | Panasonic TH58PX600U 58 in. Plasma HDTV
    My panasonic is not coming on,the power button is just flashing red(TH-42px50u)
    Count how many times it blinks. Sometimes the problem is coded in the amount of times it blinks. If you see a distiction between blinks, say like 13 then a pause then back to 13 more blinks, google solutions for a 13 blink standby for your tv and you might be able to find the soultion.
    Jun 14, 2010 | Panasonic TH-42PX50U 42 in. Plasma HDTV
    Televison & Video Logo
    54 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
