Question about OKI C5650n LED Laser Printer
Error 610: install toner
610: Y Toner missing
SOURCE: Oki C3530 MFP
Con el cartucho instalado en su posición, tiramos de él para arriba y sacamos todo el alojamiento del mismo. En la parte derecha del mismo hay un cuadradito con una ventanilla de plástico que debe estar totalmente liberada. El problema es que ésta a veces se queda medio tapada y el sensor no detecta el cartucho. Levantar ese plástico hacia arriba todo lo que se pueda ( con algo que tenga punta, un boli por ejemplo) y volver a poner todo el alojamiento en su sitio. Suele funcionar a la primera, y si no, apagar y encender de nuevo la impresora.
Posted on Sep 17, 2008
SOURCE: OKI C3400 printer keeps saying
Okay, I had the same problem with my C3300. I phoned the people i purchased from and this is what fixed it for me:
looking directly at the printer:
-open printer
-remove drum in question (the drum is what houses the toner cartridge) in my printer it is black.
-look on the right side of the drum & there is a little (approx 5mm x 5mm) hole that has a little panel that opens- push this up to open it.
-replace drum close the top and try printing.
I had to do this 2 times before it worked, but it worked.
Posted on Apr 16, 2009
  • 95 Answers
SOURCE: toner sensor problem k toner 543
Try reseating the toner cartridge, it might not be in good. Reseat the whole drum unit (the part the toner fits into).
Posted on May 03, 2009
LizBux820
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Posted on May 26, 2009
  • 1684 Answers
SOURCE: B4600, "Install Toner, Toner Missing" Error
I had a customer with that problem and the issue was the toner cartridge. If you take it out of the photoconductor unit and look on the end there should be a metal connector tab. If you look on the left side of the photo unit you will see metallic contact points that need to connect to the metal tab. Oki has several toners that will physically fit in the B4600 but they have to be the ones with the metal tab to work right or you get the error. The correct toner part numbers are: 43502301 or 43502001
Check your toner for the tab is that is not the problem, get back with me and we can go from there.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 07, 2009
I had newly replace the black color toner cartridge into my hp cp1515 printer but the LCD still shown re-install the toner cartridge and 10.1000 supply memory error. Please advice. Thanks.
The error says that the black cartridge e-label is missing.
Pull the black toner and make sure packing tape isn't covering it up.
Compare the black toner to one of the other ones to make sure that it isn't missing the e-label.
If you put the old black back in the printer, does the error go away?
Feb 14, 2011 | HP LaserJet CP1515n Printer
Toner sensor error
Hi
This error comes up when the printer detects that the toner of particular color is missing. This indicated that the indicated color toner is missing from the printer(eg-- C = Cyan, Y = Yellow, M = Magenta, K = Black).
C5150 may face a toner sensor error after installing used sets of toner cartridges and sometimes even after installing new toner cartridges as well. This error can be bypassed. This can be disabled by following these steps---
1. Turn machine on while pushing and holding the (+/-), menu buttons at same time.
2. Menu window will show OKI USER.
3. Scroll to Engine Dialog Mode is indicated Push Enter button.
4. Diagnostic Mode xx xx xx S Mode is indicated.
5. ( = 2 ) . Press (- or +) button until “ENGINE - PARAMETER SET =2” is displayed.
6. Push Enter button.
7. TONER SENSOR - ENABLE is displayed.
8. Push Enter button.
9. Press (- / +) TONER SENSOR = DISABLE is displayed.
10. Press ON LINE CANCEL buttons at same time.
11. (*) is displayed.
12. Restart the Printer.
Daniel Scott
Jun 22, 2010 | OKI C5150n Led Printer
I have attempted to install 3 different black toner cartridges in my OKI c3400. I keep getting an error: "Toner cartridge lock lever is improper, drum missing, or toner sensor error. OFFLINE." I first...
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Mar 16, 2010 | OKI C3400n Laser Printer
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Installed toner cartridge which came with new printer, now showing error message toner missing
check for tape covering toner 'dispenser'. also, that it's installed correctly!
good luck!
Oct 23, 2009 | OKI B4350 Laser Printer
Xerox Model 2515 Will not clear Toner Empty Stop Error
I had one today with a toner low light with new toner installed. Turns out they broke the green cartridge retainer clip.
The toner sensor pn# 130K45680 btw.
let us know if it was the sensor.
Aug 03, 2009 | Xerox Office Equipment & Supplies
Xerox phaser 6120 "magenta toner missing"
This problem may happen randomly with any toner.
Open the printer, the "missing toner" should be the one you see.
No need to uninstall it.
On the right side of the toner, above and to the right of the label, you will see a small green board with three contacts on it.
Just clean these contacts with a moderate cleaning solution (nail polish remover will do).
Apr 29, 2009 | Xerox Phaser 6120N Printer
Missing developer unit
Generally this printer can be separate into 4 major part: Printer body, Toner container, Developer unit and Drum unit. The developer unit is the unit where the toner container "mount" on it and it should be removed to allow cleaning task every time the toner container is replaced.
U may get this error message if the developer unit is not install properly after u replace a new toner container. Just lift the developer unit together with the toner container out of the printer and then insert back properly into the machine.
YBC (/\)
Jun 03, 2008 | Kyocera FS-920 Laser Printer
OKI C5650n LED Laser Printer Logo
70 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
