Question about Dell Latitude 110L Notebook
Bios no found - Dell Latitude 110L Notebook
  • 3 Answers
Bio file you can Download from Dell site that you can copy on USB Pendrive and and then make your laptop boot from USB then select the bios file which you download from site
Posted on Jan 04, 2013
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
How do you flash the BIOS
What happens when you turn the computer on?
If the bios is working enough to enable you to boot from a CD download the new bios from asus along with there AFUDOS.exe flash utility and make a bootable CD and copy both to it.
If the bios is completly none functional you should be getting this msg when you turn the computer on,
Boot Block Compatible Version Ver .010
Bad BIOS checksum. Starting BIOS Recovery
Checking for floppy . .
Floppy not found
Checking for CD rom . . .
CD not found
Floppy not found
CD not found
Repeat adinfinitum.
If this is the case you need download the most recent BIOS from compaq and either copy it to a bootable CD if you have this capability or buy a floppy drive for $5 and make a bootable floppy on a working computer and copy this BIOS file to it. Then rename the bios file to A8N32SLI.ROM.
You may not even need make the floppy bootable but I would just in case.
Stick the floppy in the drive turn the computer on and you will see
Checking for floppy . . .
Floppy found.
Reading file "A8N32SLI.ROM" . Completed.
Start Erasing...
Start programing . . ./
Please turn off your system and power on again to get system back.
and happy days will be here.
Jun 29, 2012 | Compaq Presario CQ61-310US Laptop
Asus k8v-mx bios problem
This is the result of a bad flash. There is nothing that you can do unless you reflash the bios to another version. In some cases you have to order a new bios
Aug 03, 2017 | ASUS K8V-X SE Motherboard
Operating sytem not found, what are the BIOS settings
Hi.
As the Computer is displaying an error message "Operating System not found", you may perform a BIOS reset and check if the issue is resolved.
1) To reset the BIOS, boot the Computer to the BIOS.
2) Once you are in the BIOS, please try pressing the F9 key.
3) The F9 key should be the shortcut key to reset the BIOS.
4) However, you will also have the option to reset the BIOS in any of the tabs in the BIOS main menu.
Please try performing the above steps which I have mentioned and let me know the results.
Hope this helps.
Please feel free to contact for further information and assistance.
Oct 02, 2010 | Twinhead SlimNote N12PI Notebook PC
No update bios found for p4i45d bios 1.20
Why do you need a bios upgrade. Unless there is a specific problem you don't need to update the bios. Updating the bios and be very dangerous if you don't know much about computers. Also unless there is a specific problem with the motherboard they won't make any bios updates.
Nov 27, 2009 | Asrock P4I45D Motherboard
P4S800D.ROM not found
check the the bios battery, it should be 3volt not less,and press dell to in the bios page setup set and set everything you need to do.and don't forget to save it,. good luck
May 10, 2009 | ASUS P4S800D Motherboard
Upgreid bios i810
I refused to deal with this problems
Thank you for your attention
               Vladimir
Mar 27, 2009 | Intel Computers & Internet
Bad bios checksum
You need to go to the website of whoever made the motherboard and get the BIOS flash utility and the BIOS binary file to update your BIOS. Make sure you get the right one, as using the wrong one can render your motherboard worthless. The BIOS file has to be the exact match. There is no such thing as close in this situation.
If you are not sure of the exact make and model, get te free Belarc Advisor from http://www.belarc.com
The BIOS chip holds information about your motherboard hardware. It is reprogrammable. It uses what is known electrically erasable read only memory. This is also called Flash memory. Reprogramming is called flashing. When you flash the BIOS, all data is erased, then the new data is written. The flash utility will most likely allow you to save the old contents, but you might have an extremely tough time recovering from an improper flash. You'll also probably need a couple of floppy disks, one of which may have to be bootable. If you need a bootable floppy disk, you can get an image file from http://www.bootdisk.com.
Jan 23, 2009 | Intel Motherboard
Download bios and flash
Try Asus update first, found here: http://dlsvr01.asus.com/pub/ASUS/mb/flash/Asusupdt60301.zip
It should check your current BIOS and download the newest one and install it automatically. If that doesn't work for you then you will need to update the BIOS from a bootable floppy disk using the two files found below:
The BIOS is here: http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5GD1/P5GD114.zip
You also need the BIOS update tool found here: http://dlsvr01.asus.com/pub/ASUS/mb/flash/AFUDOS221.zip
Jun 18, 2008 | ASUS P5GD1 Motherboard
Bios failure
you may have a flat cmos battery, but first try reseting the bios by the cmos reset terminals, refer to the manual
Sep 14, 2007 | ASUS A8V-VM Motherboard
Dell Latitude 110L Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
