M.2n68-cm repair will not boot
I need the repair manual for. Asus m2n68-cm the motherboard will not boot up. To bios settings. The front power light flashes at startup. What is the error code for this item? How do I get the technicians repair manual? Thanks.
  • 3,606 Answers
Hello you can download the manual here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68CM/#download
By selecting your windows system.
Open the manual folder and click on global for download.
You need to unzip the file and you also need adobe reader to read the content.
If the problem happened just over night the power supply could be dead.
Any beeb codes on startup ??
The ram module or the harddrive could also be failing.
These type of faults is not always the mainboard.
Good luck
Posted on Jan 04, 2013
  • 6 Answers
SOURCE: ASUS p5vdc-MX motherboard won't boot
The light is probably the power light which is ok, but from past experience it sounds like the board is dead for one reason or other. Is it still under warranty? If it is take it back to where you got it, with the purchase docket if you have it and talk to them about what you have tested and ask for a replacement. If it is out of warranty, try ebay or use www.staticice.com.au to search for the same motherboard if you want to rebuild the system without having to reload windows.
Posted on Feb 09, 2009
zohail
  • 1223 Answers
SOURCE: Bios for Asus M2N68-LA motherboard to run on Win
If this is an OEM HP motherboard, you most likely won't find support on the Asus website since they don't support OEM motherboards. Asus only supports retail motherboards. You need to determine which HP/Compaq pc system this motherboard came installed in, then check the OEM vendors website to see if XP drivers are available. You won't find them on the normal system driver page since it was only shipped from HP/Compaq with Windows Vista installed. One such pc system that used this motherboard is the Presario SR5019UK. I'm sure there were other pc models that used it as well.
Motherboard specs
A good place to start is the HP talk forums.
pls rate me FIXYA if u want more help
Posted on Mar 13, 2009
  • 300 Answers
SOURCE: Advanced BIOS setting
I would suggest using the set bios default option on the main screen. This should reset everything to factory defaults.
Be sure to exit saving settings. After that, assuming there's no hardware damage, it should start fine.
Hope this helps. Please remember to rate this information.
Thanks
Posted on May 13, 2009
Geekman
  • 32281 Answers
SOURCE: Bios ROM checksum error (Compaq SR5237CL with M2N68-LA MB)
A BIOS checksum error can be caused by a nearly flat BIOS battery.
I would replace the BIOS battery first before attempting to upgrading the BIOS.
Some motherboard BIOS firmware is upgraded by running a program that has been copy to a DOS boot disk or the upgrage maybe done from within the BIOS setup. These firmware upgrage and instructions are on the motherboard WEB site, in your case the Compaq/HP WEB site. Make sure you select the upgrade for your model motherboard.
NOTE it is possible that if you make a mistake you could ruin your motherboard, if you are not sure seek help from a computer savy friend.
Use this link :-
http://h18000.www1.hp.com/cpq-country/cpq_support.html
Posted on Sep 17, 2009
  • 91 Answers
SOURCE: I am using Asus M2N68-AM Plus motherboard and AMD
dude check out if any part is overheating using speedfan software
if not check if your PSU can take the load of your PCparts
Posted on Feb 01, 2010
Hi.I have a ASUS M2N68-AM SE2 Motherboard with AMD Athlon 64 X2 6000+ Processor.Whenever I boot,it says that the CPU is not supported.I have updated my BIOS to the latest version.Still doesn't help...The...
What bios are you using? Usually that error message can be disregarded since you can manually set the CPU clock, voltage, etc in the bios and it should work. Also, this might mean that the bios currently loaded is corrupted/broke. But since you did update the bios, to what version?
Also, are you using the integrated graphics for gaming? If so, that would not suffice for heavy gaming at high resolution. You should be using a dedicated video card for that.
As for system performance, how slow is it? What is your OS as well? can you try to download cpuid, and see if your processor is detected properly in windows.
Apr 27, 2011 | ASUS M2N68-AM SE2 Motherboard
I have M2N68-AM SE2 Motherboard using for my desktop. i have updated the BIOS using ASUS BIOS utility and restarted the PC after updation, but there is no loading/booting taking place...no video...i want...
http://majorgeeks.com/Bios_d235.html
Save, delete, and restore your BIOS settings
or http://majorgeeks.com/download.php?det=5710
you will have to burn it to a disk as an ISO
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
hope this helps
Mar 19, 2011 | ASUS M2N68-AM SE2 Motherboard
M2n68-cm asus ddr2 ram. the first boot was fine i turned it off 2nd boot starts to load then turns off stuck in this cycle
First you have to make sure all of the wires are plugged in properly. Many times this problem occur because a wire isn't properly secured. You can also try resetting the bios options to 'default settings'.
Mar 17, 2011 | ASUS M2N68-CM (90-MIB5K0-G0EAY0GZ)...
Ihave ASUS M2N68-AMSE2 nmotherboard- on starting up, my computer shows ASUS green screen for ages and nothing happens, I press reststart, motherboard boots up and starts windows
hardware related issue, check your bios settings to see if halt on errors in enabled, also disable
the ASUS splash screen, you should be able to see the initial boot error..
Feb 19, 2011 | ASUS M2N68-AM SE2 Motherboard
NO DISPLAY COMING. CONTINUE DOUBLE BIP SOUND. PROCESSOR FAN RUNNING.
Try removing your memory and than reseat it. One DIMM at a time and boot the system in-between each.
Still hear the double beeps? Its possible one DIMM may be defective. Continue.
Clear the bios. See page 1-7 in your manual. When the bios has been reset everything will revert to default settings. The onboard graphics will give you back video. Enter the bios and set the bios so the PCI-E card is used. Save and exit. (Most likely your PCI-E card also needs a power adapter connected).
If the system goes back to double beeps try removing the PCI-E card and than reseat it. (Possible loose connection).
Happy 4th!
Mike
Jul 04, 2010 | ASUS M2N68-AM SE2 Motherboard
ASUS P5KPL-CM Bios Problem with Core2Duo 2.8 Ghz Processor.
I recommend going to this site and getting the latest Bios for the board.
http://support.asus.com/download/download.aspx?SLanguage=en-us
I don't know your expertise with computers but it will require you downloading their Bios boot disk utility and creating a boot disk. then copy the Bios file to the same disk. When you boot it up it will guide you through the Bios flash process.
Be aware that you can completely kill the Bios if it has a problem during the flashing so only do it if you are positive you can get through it.
Alternately if you can push the F1 and get into the OS the Motherboard utility disk should have an updater you can use from inside windows.
May 04, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
