ERROR 0302 SHARP CD BA 1300 - Audio Players & Recorders
2 Suggested Answers
SOURCE: Sharp CD-BA 2650 Error code: ER-CD 11 - the CD tray will not open
I had the same problem but fixed it by replacing the cd belt which was broken and relined the main cd plate which holds cd to correct position . and god fixed it.
No more errors and now a great cd Hi Fi.
Make sure all s aligned and blow out all dust with an blower or air compressor.
I pull the top plates off blow air into them and replaced a broken belt for cd's and not it's new machine.
You want to fix it than fix at the source.
Posted on Jan 08, 2011
My 1996 honda accord lx did not pass smog due to
these codes indicate there is a miss fire on cylinders 1 and 2 hence the 0301 and 0302 code the 1300 just indicates multiple engine miss fires. so anything that can cause these cylinders to miss fire need to be attended to in order to fix your problem.
Sep 20, 2014 | 1996 Honda Accord
Sharp cd-bp1200w cd carriage will not open power is ok display ok . cds locked inside!
On my sharp CD-BA 1200 most cd's do not run. It is the problem that has recently occured. Kindly suggest solution.
Mar 14, 2010 | Sharp Multi-System Mini Component System...
CD CHANGER DOSE NOT OPEN AND AN ERROR CODE APEARS
If an error occurs ond the trey does not eject, the problem is most probably that the cd is crammed in the wrong way. So now you need to force eject the trey. This will not do any damage to your device, so even if this is not the problem, you should be able to get out the cd that is stuck.
There is a little hole near the eject button, you need to push a pin into the hole untill you feel there is a resstance. Then gently pull out the trey while holding the pin in the hole.
This should work perfectly. Please rate this.
Best regards
Sep 29, 2009 | Sharp Multi-System Mini Component System...
I tryed to have additonal speaker on my sharp cd-BA 150 player all sudden stop working and gave me an error message "PROTECT" so how do I fix that?
The output amp section for your system is not designed to run more than the speakers that come with it. By adding more, you presented too low an impedence load to the amp and overheated it. This occurred too quickly for the internal protection circuits to kick in to prevent damage to the outputs. This unit will now require that the outputs be replaced. These are not the easiest units to work on, so I would not suggest that you attempt this repair yourself. Expect a parts cost in the $35 range for this repair. Dan
Jun 09, 2009 | Sharp CD-BA150 Shelf System
How to connect sharp cd-ba 1700 to pc?
if your sistem got auxiliar option,you can connect your pc through the earphones output of the pc to the auxiliary inputs on the shelf sistem they are a cable named 3.5mm to rca outputs to fit that connection gfood luck
Feb 03, 2009 | Audio Players & Recorders
i had the same problem. my brother took it apart and found that the belt that opens the tray was snapped. he bought a new one at radio shack and replaced it. but now there's a new error with no code. so thats as far as i can get you. sorry. =)
Dec 05, 2008 | Audio Players & Recorders
Error code 0203
This is a mechanical error. The mechanism is stuck and can not reset to a known condition. Look to see if a CD has slipped nad try to get it back in place. If that is not the case, it will need service as the mechanism is now out of timing.
Dan
Mar 26, 2008 | Sharp CD-BA2600 CD Shelf System
Sharp CD-BA200 MIni Component Stero System
I've been messing with mine because it says no disc and I messed it up so it started saying this error. Unscrew the screws around the top (4 screws) and slide off the top cover. The small black rectangular box that sits over the eye/laser can be removed carefully by compressing the clips. Then the cd tray can be removed. I figured out this error was coming up because I had the tray out of alignment... so try to see if that's the problem with yours... also the eye itself slides (the entire mechanism it's on... slides away from and towards the place where the cd sits to be lifted and read) and it should be as close as possible to the area that lifts the cd. Sorry if this isn't making sense... trying to explain in the best way possible. The tray being out of alignment causes that error though.
Dec 15, 2007 | Sharp CD-BA200 CD Shelf System
87 people viewed this question
 Grubhead
Grubhead
