Question about Toshiba Computers & Internet
Memory card not working
Memory card is not reading the my new lap top
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 71 Answers
Use external usb card reader for that
Posted on Jan 04, 2013
Testimonial: "thankyou, but what is the solution without USP external card reader as its a Brand new computer, the engineer came fumbled something and said its the OS porblem, i think he did not fix the panle properly, therefore now the hings starts to give trouble, the panel started to break at the right side of the lap top. Toshiba has agreed to change the top and bottown panel now..."
2 Suggested Answers
  • 7993 Answers
SOURCE: laptop will not boot with new ram memory card
There is a problem with the RAM: incompatibility, modules not firmly seated.
If you install new modules, try installing one in a slot, boot. If it works insert second module and boot.
If it does not work for 1st module, try changing the slot where module is inserted. For certain computers, if only one slot is occupied, module must be in one particular slot.
If you kept one of the old modules, it may not be compatible with the new ones.
Hope it helps
Posted on Sep 05, 2009
Why is my lap top just intermittently beeping with a black screen
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 07, 2012 | Dell Inspiron M5030 Laptop
Genx pe4ndrive.when I insert in lap top click to open it is displays not formatted.when I clic formatting button it is displayed that i will loose all memory of pen drive it's data.
Try it on an other computer... if that fails, it might have developed bad sectors (spots) reformat and do a scan, which writes and reads all memory locations... might be corrupted and/or broken, but try another computer first to make sure it is not a driver issue.
Dec 13, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My memory card works perfectly in my lap top and in my cellphone, but when i try to use on my camera, it says that "this card cannot be read". What can/should I do?
When you use a memory card, it formats itself, using a single memory card on all three things probably isn't the best idea. What you could do, is get the small sd card for your phone, and get the adapter so you can view the pictures from your phone on the computer. Then get a totally new memory card for your camera they are super cheap. I would suggest getting a 2gb or higher. I hope I helped.
Jun 23, 2011 | Nikon Coolpix S3000 Digital Camera
Well i am going on a trip tomorrow and i put my memory card into the lap top and put all pix on the lap top and then put it back in to the Nikon and i gray screen came up and said that "momory card is writ...
Some memory cards have a small plastic tab on the side of it that can be set to write protect the card. Check your card to make sure the tab didn't get moved accidentally.
Jul 01, 2010 | Nikon Coolpix 4500 Digital Camera
I left my memory stick in my lap top. Dislodged
i guess you just broke the usb.. try to connect on other pcs if still works...hope this helps..
Sep 01, 2009 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Cant down load
hello there...that's right you can get a usb data cable, blue tooth ,or memory card reader to transfer you pictures to your computer....
you can directly print the picture as some of the printers come with card readers built in which is very convinient
consider visiting a mobile accessory shop you will have all the options there
my best pick will be memory card reader if you already have a printer...it is very cheap...and can read multiple cards...so in future if you change your mobile you will not have any problem
like with usb cable (different for different phone)
blue tooth and getting a new printer is a costly affair...blue tooth often have connectivity and software issues
go for memory card reader ...cheap ,reliable ,fast and best of all
Hope this helps
Cheers
May 25, 2009 | Motorola Mobility RAZR V3
Problem with accesing memory card
After you download pictures you must insert card in camera and format the card. See instructions in book.
Oct 28, 2008 | Sony Alpha DSLR-A100 Digital Camera
Memory Card for digital Camera
After inserting the card, go to my computer and see if it shows the memory card inserted. If so, click it and then when it opens, click copy to location and you choose the location, easiest, my documents and then my pictures.
Dec 26, 2007 | Cameras
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
