We have a ESP 7250 the print head carriage shows
We have a ESP 7250 the print head carriage shows jammed but I can't get the ink cases to move. So I can check it
    New Friend:
    Problem Solver:
  • 15 Answers
To resolve this error: Open the printer access door. Disconnect the power adapter from the printer. Gently hold both sides of the carriage, located immediately behind the printhead, and make sure the carriage moves freely. Remove the printhead and ink cartridges. Reinstall the printhead and ink cartridges, making sure each clicks into place. Connect the power adapter to the printer. Turn the printer on. Close the printer access door Hope this helps resolve your problem
Posted on Jan 05, 2013
SOURCE: HP Deskjet 6540
The color cartridge sping was loose. I am in the process of super gluing it into place. Hopefully it will work.
Posted on Mar 24, 2008
myob247
  • 1342 Answers
SOURCE: Error: Carriage jam
Click Here for HP's solution to this problem.
Posted on Jul 26, 2008
komguy
  • 2306 Answers
SOURCE: Printer is not printing colors correctly. Brown
You press the ink button and choose cleaning option and test print to see if colors are correct, clean again if colors are wrong. The spillage won't hurt print quality when it's around the cartridge area. If you are using generic inks they sometimes are not the correct color.
Posted on Feb 08, 2010
pineworks
  • 4041 Answers
SOURCE: "clear carriage jam" message
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
  • 446 Answers
SOURCE: I have a paper jam inside my new ESP 7250 printer.
maybe just a very small piece of paper, look carefully on the paper path
Posted on Jan 29, 2011
Testimonial: "Thanks!!!!"
How to remove print head on a Kodak ESP 5250
If the ink cartridges and printhead are already in the printer, remove them, then reinstall them.
  1. Remove the color and black ink cartridges.
  2. Remove the existing printhead by lifting the latch in the center of the carriage. printhead_removal.jpg p342_0064aa.jpg ESP 3, 5, 7, 9, 3250, 5250, 5210,
    ESP Office 6150, 7250, 9250;
    HERO 7.1, 9.1, OFFICE HERO 6.1 ESP 1.2, 3.2, 3.2s, C110, C310, C315,
    ESP Office 2150, 2170;
    HERO 3.1, 5.1
  3. Close the printer access door.
Oct 21, 2014 | Office Equipment & Supplies
Www kodak com go aiosupport
Several things could cause a printhead jam. Check to make sure the bar is clean and that no pieces of any stick on labels are stuck to the wrong places, next, make sure your cartriges are properly seated, if all else fails, you can see if the print head can move at all or if it seems to be sticking to the steel bar that holds the print head. if the print head is sticking to the bar, DO NOT OIL THE BAR. you can place a drop of lighter fluid on each side of the print head to lube the bar. There is a bronze bushing in the print head and it will absorbe oil and lighter fluid is a very fine cleaner lub. But do remember that it is also very flammable.
Aug 12, 2014 | Kodak ESP 7250 All-in-One Printer
Message says "printhead carriage jam". No indication there is anything wrong.
The print head its self can jam, could be caused by a piece of a label or a cartrige not properly seated, chek those things, if not that, try to shut down the printer and restart. most printers on boot up do a head cleaning. If all else fails, see if you can gently dislodge the print head. A final not for all printers, never ever use oil on the carriage bar, if the head is moving slowly or draging, shut down the printer and put a drop of lighter fluid on each side of the print head and restart the printer, do becareful to only use a drop.
Aug 04, 2014 | Kodak ESP 7250 All-in-One Printer
Print head parked at left, error code 3527
This problem has plagued me for a very long time. The issue is that the printer head is "glued" in the resting position under the guard of the printer, so you can't remove the ink cartridges to clean it. Solution is to (I know this sounds stupid, but it works) turn the printer on the side where the printer cartridges are (if they are stuck on the left side, turn the printer on its side so the cartridges are on the bottom). Turn the printer on, and the cartridges magically start moving! I guess there are some sensors that get tricked out when you tip the printer on its side. If the cartridges are still stuck, click the "ok" button, and before it gets a chance to see if you actually fixed the problem, turn the printer off using the power button. It takes a long time, but you should see the ink trap lower (release the ink cartridges) and the ink cartridges start moving to prepare for shutdown! Grab the cartridges when they move out of their hiding place and don't let them go back until you clean the print head so it doesn't get stuck again. Remove the ink cartridges, then push the grey tab to release the print head. Wipe the bottom of the print head clean with rubbing alcohol (it will have a lot of gooey - sticky ink stuck on the bottom). I used nail polish remover since I didn't have rubbing alcohol available. You can also wipe down the ink pad which is where the ink cartridges were previously jammed to clean up more of the mess and prevent this sort of thing happening again too soon. Good luck!
Dec 27, 2013 | Kodak ESP 7250 All-in-One InkJet Printer
Kodak esp 7250 printhead carriage jam
Mar 09, 2013 | Office Equipment & Supplies
Info printer :E
Any malfunctions its gives error 'E'... Check paper jam, carriage struck, cartridges faulty and service related issues.checking carriage:Switch on the machine check carriage(the unit carrying print heads)moving left & right.. if its not moving, it might be struck in service station(service station located at right end and its allow carriage to rest on it during shut down as well as its cleans the print head nozzles). power the machine pull carriage out gently, don't force it..Clean encoder strip: Encoder is located back side of the carriage and its guides carriage to move properly, if encoder became dirty you will get error message, clean encoder with smooth cotton cloth.
Feb 03, 2012 | HP PSC 1215 All-In-One InkJet Printer
Kodak 7250 print head jam
Jan 20, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
I can not manually move the printer carriage on my HP Photosmart B210e printer
Might be service station jammed.Service station work is to clean the print heads,stores spitting ink init as we as capping the print heads to protect from the nozzle drying..After switching off the machine service station capping the print heads and arrest the carriage assm for protecting the print heads, in this condition carraige assm wont come out until its released by service station. Its required expert to release the service station, if you force to pull it will damages the print heads.. You justify what you can do for this issue...If you are capable do it...But care fully
Jan 09, 2012 | HP OfficeJet Office Equipment & Supplies
Says there is a jam with the ink carriage. I just put new ones in and its telling me there is a jam
If the number 10 cartridges are not properly fitted in the print head then this might give you a "jam" signal. My ink cartridges snap easily into position... if out of position an ink cartridge can block carriage movement...it happened to me.
Jul 01, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Head won't move far enough to the left to get cartridges out
seems a case of carriage jam n needs servicing..
howevr, do it if ur printer is out of warranty and u r a professional..
check for loose/faulty carriage-belt and the drive-assembly..jammed/sticky cleanser-unit (esp the rubber, gears n base)..
also chance of defective/faulty photo/opto-coupler 'sensor(s)'..the diodes and resistors in dis section..
always better to hv professional supervision, contact ur system admin/vendor....
Oct 31, 2009 | Epson Stylus C44UX InkJet Printer
617 people viewed this question
k24674
jasbo
jasbo
