Question about Coffee Makers & Espresso Machines
Unit behind the reset switch has burnt out - Coffee Makers & Espresso Machines
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
Well find your brand and model. Search replacement parts on the web. I really don't know what your wanting to do. Replace or repair?
Posted on Jan 04, 2013
Dryer only runs as long as the start switch is pushed and held. When I let go of switch the dryer stops.
Time for a diagnosis before something gets burnt beyond recovery. If you can fix appliances, there is a tech sheet hidden inside the unit somewhere behind the control panel. If not, an appliance repair tech can get you fixed up the same day if he has parts in his truck.
Feb 19, 2015 | Dryers
Power surge
Yes possibile there's some IC's that are burn inside it and also the power supply can be damage so resetting it will not do anything , if you can take it to a repair center and let them check this unit and fix it.
Good luck........
Aug 09, 2008 | Toshiba 32A43 32" TV
Fan speed switch
the problem will be in the fan resistor a small unit normally screwed into the heater case behind the glove box. The resistors that create the lower speeds will be burnt out leaving only the direct circuit for high fan
Dec 28, 2013 | Toyota Cars & Trucks
Asko D3530. Program LED does not come on. Also nothing happens when I push Set, Menu or Start. Tried button on the left (cirle with a I, looks like a reset button?). Checked plug, GFI and circuit breaker...
Welcome to FixYa.
It sounds like you've got a bad power switch or a wire at the power switch or as you described it... (circle with a I, looks like a reset button?) that's the power button, this will require removing the control panel, but I'd check the power at the dishwasher first though...
You'll need to check behind the kick plate at the bottom as opposed to just checking the GFI and circuit breaker. This is something I've seen fairly often with Asko dishwashers.
**Use caution when checking voltages with a live circuit. Turn off the breaker when servicing the unit otherwise...safety first**
If you have any reservations or aren't completely confident performing these tasks I suggest calling in a pro, sometimes the $100 or so is worth it.
You'll need a volt meter or multimeter to check for voltage as well as to look for burnt up connections at the terminal block/junction, it'll be pretty obvious if present. This will indicate a wire has been loose and burnt due to resistance, simply cutting it back and refastening it securely should solve the problem provided no further damage was done.
Let me know what you find and I'll try to assist you in any manner I can going forward.
Regards,
Macmarkus :)
Jan 28, 2011 | Asko 24 in. D3530FI Built-in Dishwasher
94 Dodge Dakota, Tail & turn lights ok, no brake lights when pedal is pushed.
check fuse first, the brake light switch is on the upper part of the pedal, you have to be a cortorsionist to get at it, good luck
Oct 26, 2009 | 1995 Dodge Dakota
Passenger side heated seat switch lamp burnt out
Its simple. you need to pop up the surrounding area of the shifter unit . everything is in place with clips so you will need something plastic but soft enough to not scratch or crack anything. perhaps a toothbrush handle. find something to get leverage on and pry. it should pop up, exposing the switch. You will notice a tiny circular thing behind the switch. those turn and allow the tiny bulb to come out.
May 30, 2009 | 2005 Honda Accord
Power cord
The unit may be drawing more current than the outlet can withstand. Also check to see if the chord is secured and properly installed. The outlet itself may have a loose wire so check to make sure it's good. Otherwise it could simply be the reset switch is burnt out and will keep tripping no matter what. Replace if neccessary. Hope this helped.
Jul 20, 2008 | Kenmore 75085 Air Conditioner
Have a hampton bay 24000 BTU AC. Smelled burnig behind control panal. Opened it up found what seems to be an overload switch burnt through.. Leads go to capacitor terminal C & Herm. I changed the...
I checked wiring on my other 17,000 BTU Hampton bay AC & noted there was no overload switch wired into capacitor. So i just removed the burnt out overload switch which was causing a ground & blowing breaker. I noted it was not wired in between the compressor circuit but just attached to the compressor terminal & common terminal on capacitor. I guess it is a sacrafise type device that saves the compressor from burning out on overload. Anyway The AC worked fine with the burnt overload switch removed. It has been runnning 2 days now with no problems. I however did replace the capacitor with a new one. You can use either an oval or round capacitor as there is ample room. Just make sure your cap. values match old one. I will probable try & purchase a new overload switch if possable & install it at a later date, for the extra protection.
Angelo V.
Jul 20, 2008 | Hampton Bay Heating & Cooling
I HAVE A FRIGIDAIRE SLIDE IN RANGE AND WE HAD A POWER FAILURE. NOW MY RANGE BLINKS F30 AND I CAN'T GET MY OVEN TO WORK.
there are (2) resetable thermostats in this particular oven, the first is located on the rear of the unit behind the panel ( if standing behind unit its in the upper left hand side of unit. 2 wires leading to the thermostat and a small "buton" to press to reset it. if it doesnt work after resetting that one then the second on eis located under the control panel behind the second burner knob from the right.. to acess this pne youll need to remove the burner knobs::: then loosen and remove the plastic hold down under the knobs, the contriol panel will lift off thenand then remove the 4 \screws holding hte clock assy in position, when thats lifted out of the way( no need to disconnect)you see hte same resettable thermostat moundted on the unit rigth behind that second switch, simply reach in and reset it...TURN POWER OFF PRIOR TO EITHER REPAIR LIVE WIRES!!!!!!!!!!!!!!!!!!!!!!!!!!!
May 07, 2008 | Kitchen Ranges
Coffee Makers & Espresso Machines Logo
14 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
