Question about Dryers
I want to know problem when i switch on my preeti mixie echo chef model my electric power in my home get tripped
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
You may need to add another breaker. But I advise getting a professional to do it according to law codes. You don't need a big fire to destroy your new dryer.
Posted on Jan 04, 2013
Mixi dj is a spam, toolbar, etc...
Go to: tools>extensions>enable/disabel this ad
Jul 20, 2013 | Microsoft Windows XP Home Edition with...
Preethi eco plus mixie not working (first time)
I recently brought(just 2 days back) a Preethi ECO Plus mixie from India.(US made)
It works fine for some days when i use that to grind some soaked
rice it was working fine for some time, suddenly the motor is not running. But I can see the power light switched on in the mixie. But its not working.
I am not sure if there is some service centres for repairing these kind of issues.
I am located @phoenix ,Arizona,usa
please let me know.
Indira
May 13, 2013 | Preethi Nitro Mixer Grinder - 110 Volts...
Preeti mixie stopped working
I know it is kind of late to answer this, but those who are looking anew for a solution to this problem might find this helpful so writing my experience. I also brought a Preethi mixie, 110V from India and in less than two uses of about 5-10min it stopped. I searched everywhere for a solution and even called service center in Chicago (yes, there is one in Chicago, IL) and finding it difficult to go there and get it repaired, I dared to open it.
I am glad I did as I noticed a connector wire (with a plastic seal/insulator) is burnt. It is a simple fix and I cleaned the burnt part and carefully exposed the wire a little bit more and connected it back to the other wire as it is supposed to and put the insulator back in its place. I started the mixer and its working now :)
I have been using it for a month now since I fixed it to make dosa batter, chutneys etc and it is still working. So I think this is the problem most of us had with mixer not working after few minutes of usage and even the overload button not working. Try this and let me know if this solved your problem.
Happy Cooking!
Jan 13, 2012 | Food Mixers
We moved our magic chef frig on the deck-plugged it into an outlet with too many thing running. The breaker tripped.Not the frig light comes on but the frig does not work. Is there a reset button? If so,...
There is no reset button.
Firstly turn the fridge off at the wall switch. Wait 5 minutes then switch the power back on. If the fridge still does not start then you have a problem with either the fridge electrical circuit has a fault or the circuit board fuse has blown.
Apr 01, 2011 | Magic Chef CTB1722 Top Freezer...
Magic Chef refigerator/freezer stopped running
if you said stop running id assume that there is no power?? even with good electrical input..
for that instance, better check.charred cables.. if not there maybe a problem with timer itself..
Nov 05, 2009 | Magic Chef CTB1922 Top Freezer...
REPLACEMENT COST OF MAGIC CHEF ELECTRIC RANGE MODEL 6898XVB
you should be able to buy one for between 400 to 600 dollars new.i would check lowes or home depot to see what they have in stock.
Jan 13, 2009 | Magic Chef CES3760 Electric Kitchen Range
Replacement Power Cord
You can find replacement cords for many counter top appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the pot with you to make sure you are getting the correct cord.
Dec 28, 2008 | Le Chef Electric Shabbos Hot Water...
MAJIC CHEF DOUBLE OVEN NOT WORKING
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Nov 29, 2008 | Magic Chef 9522 Electric Double Oven
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Dryers Logo
41 people viewed this question
Top Dryers Experts
