How can I use my lg 3d tv as netbook pc monitor using agp to hdmi cable
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
Connect your tv to your PC . Turn your pc on and let the os (operating system) boot up. Then find the function key (f1-f12) usually has a rectangle symbol with a line on either side. Example f4. Then hold the function key fn which is located bottom left of key board. And press f4 (if this is your video toggle) it will cycle through original monitor, both original and external monitor, and finally external monitor only. If done again it should reset to original status.
Posted on Jan 04, 2013
Benimur
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
  • 979 Answers
SOURCE: Unable to display HDMI Input
Okay so you have the HDMI cables from both the DVD and the Cable box plugged into the reveiver?
Posted on Feb 28, 2008
  • 668 Answers
SOURCE: TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Posted on Jun 18, 2009
  • 7 Answers
SOURCE: LG 42PX4DV - HDMI Audio / PC Audio IN problem
one quick fix you can try. plug in the HDMI cable, slect a digital audio sound output from the sound settings on your machine, then leave it connected and restart it. It just might work.
Posted on Aug 05, 2009
  • 4234 Answers
SOURCE: my sharp tv is pc ready. I hook everything up and
There are a number of things to check here:
1) Verify that the resolution on the PC is set to a supported level for the TV. Usually the TV will show "no signal" if the resolution is out of range or the message "out of range" will appear.
2) You don't indicate whether you are connecting to a desktop or laptop. If a laptop, you may need to turn on the external monitor. This is done by using the function key and either F5 or F6 (the key should have a picture of a screen on it). Hitting this combination will toggle between the main screen with.without the external monitor.
3) Verify that the TV port is selected correctly (AV1,AV2 etc)
4) You will need a separate cable or the audio regardless of the system type. Also verify that the audio cable is in the corresponding audio input jacks for the video option selected.
If you have completed the above and it still doesn't work, please post the details about the computer being used and the exact cable setup that you have and I'll check into this further.
Thanks,
Dan
Posted on Mar 13, 2010
Lenovo ideapad z570 wont connect via hdmi to lg smart tv
I don't think the system is compatible with the TV it can't read the pad through the HDMI port only the RGB port.
Mar 21, 2013 | LG Electronic LG 42LM6200 42" 3D 1080p...
My tv hdmi ports connedts to only lg products now i was able to connect my playstation to my lg tv and watch 3d movies but last couple days tv says connecting and no signal playstation works with hdmi...
Dirty Connections Dust plays Havok with those connectors go to Radio Shack and pick up a Can of Contact Cleaner Spay both the Jacks and The cables
Dec 30, 2011 | LG 55 55LW5600 3D LCD TV
How do you connect lg optimus to samsung 3d tv via hdmi cable
Switch on the Mobile Internet from the settings->Wireless & Networks->Mobile Network->Data Enabled.[note: Connect the usb cable to the PC. Don't use it as Mass Storage.]
Enable USB Tethering from the settings->Wireless & Networks->Tethering & Portable hotspot->USB Tethering.Now you can browse from PC via Optimus.
Cheers,Mr.Maduraikaran.
Aug 26, 2011 | LG Optimus 3D
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
When i connect my pc to my monitor (LG w2353v-pf) via a HDMI cable the monitor tells me to check signal cable. I know my HDMI cable is fine since i have tested it on my TV. also i know that my computer...
Hi raposo69 ,
I see that you are having an error check signal cable.
Have you tried selecting the correct Input for the LG LCD monitor?
make sure that the Correct Input is selected properly to be able to detect the signal from the HDMI cable that you are using.
The audio will not confuse the video on an HDMI Video will be detected as long as the Input on the LCD monitor is selected.
Audio on the HDMI will only work if the HDMI driver is provided like on a desktop computer you will need to get the driver for the HDMI for Audio and video to come out using an HDMI cable but never will audio conflict to the HDMI video output.
I hope this hepls.
Have a nice day,
mvincentc
Apr 13, 2011 | LG W2353V-PF 23' LCD Monitor
How I can connect my Samsung Home Theatre System ( 7-1 channels AV receiver) using the HDMI V 1.4 3D cables to connect them to to my LG 55 LX 9500 3D HDTV LED TV . The equipments are :( LG Blu Ray...
ideally you would simply add an hdmi source from each device to the surround receiver and send the output to the tv but im thinking your amp may be short on inputs from all devices and if indeed it was this simple you wouldnt be here seeking this info also note you may be able to use the output on the set to gain another signal tranfer but note there can be compatability issues on some sets whether they will decode hdmi in and rca out or optical out like i said some sets ok :) i wish you luck and wishin i had this all in front of me so i could be a greater help any q's drop me a comment here ok :)
Feb 26, 2011 | LG Televison & Video
I have a Samsung N210 plus netbook, how do I connect it to my Sony Bravia TV please? I do not have a HDMI cable just a Monitor cable!
If your TV is the KDL-40S2000 as listed above then you will have a PC monitor socket on the back of your TV (outlined in red):
To connect to your PC:
1. Switch the TV to STANDBY or OFF
2. Connect one end of the monitor cable to your TV and the other to your Netbook
3. Switch on the TV - and startup the Netbook
4. Switch the TV to the PC input mode . . .
Feb 14, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How do i connect acer apire one to lg lcd tv?
In order to connect your netbook to lcd tv your need a VGA or a HDMI cable( if your laptop has a hdmi port). Once you connect the netbook with the lcd tv you nned to use you tv remote to choose the input to pc or pc1 or HDMI depending the lcd tv. if you any futher questions please feel to ask.
Jul 08, 2010 | Acer Aspire One PC Notebook
No signal input when connecting PC to LG TV via HDMI
Do you also have a computer monitor attached to the computer when attempting to use the HDMI?
Mar 29, 2009 | Acer Aspire m5640 PC Desktop
Televison & Video Logo
Top Televison & Video Experts
