Question about Parrot MINIKIT Bluetooth Hands-Free Kit Wireless Headset
My blue parrot headset doesnt turn on
When i press the big button to start it dosent turn on? why!! dose it have a reset button??
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
I'm not sure of this headset. But if you just unpackaged it I would try charging it for a good hour. Then try it.
Posted on Jan 04, 2013
Trying to pair b250 xt with samsung rugby2 lots manual
Make sure you device is in visible mode first. In power off condition of headset, press on button for 30 seconds. When blue lights starts blinking fast then search on device and add it.
Custom Car Grilles
Aug 01, 2012 | Parrot Blue B250xt Bluetooth Wireless...
Blue parrot b250xt when making a call cant hear it ring on parrot . When reciving a call you have to divert to hands free.
Seems like you have an issue that is very common. I had the same issue and phoned tech support (1 800 742 8588). The solution is to reset the headset. It is not printed in the manual 1 switch phone on and pair with headset. 2 when paired (blue light flashing) put the charger on the headset for exactly 10 seconds. 3 remove the charger. 4 the lights should be starting to alternating between red and blue. this means it is resetting. 5 as soon as the light quits to alternate, the headset is reset, and the problem should be solved.
This also fixes the Windows 6.1 audio problem.
Jun 20, 2010 | Parrot CAR PAICK3300 GPS Receiver
Wont audio to headset
The problem with the Blue Parrot headset not getting audio from the phone is a very frustrating one and it took several hours to diagnose the problem. (Especially the Samsung/ Windows side, in my case)
I have a Samsung I760 phone using Windows Mobile 6.1. After pairing, the headset is visible in the PHONE window, as it should. But upon dialling, the audio transfers from headset to phone.
While in a call, you can tap on the menu button and it should bring you to a menu that would allow you to transfer the audio from headset to phone and vice versa. But this action malfunctions in the Blue Parrot headset only. The Blue Eagle headset works fine.
MY SUGGESTIONS:
1) Chuck the hideously expensive blue parrot headset in the trashcan and buy yourself a blue eagle, available at truck stops everywhere
2) Pester the Blue parrot support staff for a replacement, or a solution at 1800 742 8588.
Make sure you understand the manual and especially point 13 dealing with the transfer of audio before you call them.
Other than this, the headset actually works fine.
adampotgieter@yahoo.com
Dec 15, 2009 | VXI Corporation Blueparrott B250-XT...
After i enter my passkey it says connection failure for my h700 blue tooth
On the Blackberry, Go to Options, Bluetooth. Select the blackberry button, Add Device, and search. If search doesn work, try listen. While these are going conduct the following on the Headset:
Close theheadset. Go to the phone and choose discover, or search. Open the headset and pressand hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
If this doesnt work: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
The passkey is 0000, four zeros.
May 23, 2009 | Motorola Mobility H700 Wireless Headset
Nokia 6500 will not pair with Parrot ck3100
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Parrot device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 28, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Pairing CK 3100 first time with HTC touch
6) You will be required to enter in a pass code which is standard ‘0000’, but try '1234' again if that doesn't work
Hope this helps
Chris (ziraffa)
Dec 24, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
I have lost my manuel and have forgotten how to pair my bluetooth, can you help me out?
To connect your headset:
Start with your headset turned off.
Press and hold down the control button.
After 6-10 seconds, the light will flash blue, then it will flash red, then blue.
Release the buton when you see the red/blue.
On your phone (depending on your phone, the commands may be different or even not necessary. Navigate through your phone menu until you see commands similar to):
Enable Bluetooth
Turn Discoverable to "Yes" or "On"
You may also have to "Add Device" in order for your phone to start searching for your headset.
On your phone, select Plantronics 3xxx.
If you are prompted for a Passkey, use 0000 (that's 4 zeros).
It is now ready to use.
Hope this works for you.
Dec 17, 2008 | Plantronics Explorer 340 Wireless Headset
Memory Full
hi
just had the same problem
solution : hold the answer and hangup buttons down for 5 seconds {press red and green and hold}
the parrot kit will then tell you it is erasing memory then it will say ready for pairing turn on your bluetooth on your phone doe a search find and select parrot enter default code 1234 when prompted as a pin and away you go
hope this helps bob
Jun 28, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Parrot memory full
I had same problem too.
I have googled 3 days and found the solution from MULTICAN manual.
•Reset the hands-free kit:
Repeat the following sequence five times:
press the "Volume (-)" button and then the "Volume (+)".
And also F.Y.I.
•Enter the menu:
Press the following sequence twice: [SEEK up] button then the [SEEK down] button.
•Go forward through the menu: Press the "Volume (+)" button.
•Go backwards through the menu: Press the "Volume (-)" button.
•Select a menu option: Press the "Phone" button.
•Cancel a function: Long press of the "Phone" button.
Jan 18, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Parrot MINIKIT Bluetooth Hands-Free Kit Wireless Headset Logo
324 people viewed this question
Top Parrot Radio Communications Experts
Hjalmer Lamminen
Hjalmer Lamminen
Bill Boyd
Are you a Parrot Radio Communication Expert? Answer questions, earn points and help others
