Question about Canon EOS 450D Digital Camera
My EOS 450D camera wont switch on i thought that the battery might be stuffed so i brought a new one charged it and put that in and still it wont switch on
My camera wont switch on i have a new battery for it charged the new battery put that in the camera and it still wont switch on
  • Geofrey Taiki Jan 06, 2013
    Its not the battery as we have tried several fully charged batteries from the camera house store we tried a few different things the guy at the camera house store recommended that it go in for repairs so thats the best thing to do is put it in the shop let them diagonise the problem and fix it and ill be back out doing what i like most doing i have a samsung galaxy phone 3 that will keep be occupied for the moment till i get my camera back from the repair shop thanks guys for your help
markevans
  • 148 Answers
SOURCE: xti wont power up
appears to be a defect and not user serviceable.
sorry for the news.
good luck.
mark.
Posted on Dec 24, 2007
  • 155 Answers
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Posted on Apr 09, 2009
  • 164 Answers
SOURCE: Canon 450D is not being recognised by my computer
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Regards,
Posted on Jul 13, 2009
SOURCE: The built-in flash on my Canon EOS 450D camera won't pop-up
Had the same issue and just tried this....and it worls [PS dont use the littel plastic hotshoe cover as this keeps the microswitch depressed]
If you manually 'help' the flash to open and it doesn't pop; the microswitch under the rails of your hotshoe is probably stuck in the down position as mine was. I used a toothpick top pop it up and it works now!
Posted on Aug 27, 2009
  • 10 Answers
SOURCE: card write protected
Check if the card is truly write protected (check the little slider on the SD card). Its possible it slid into lock position accidentally
Posted on Nov 25, 2009
Testimonial: "very helpful, i overcome the wrtie protected problem. thanks"
What is the latest firmware for canon 450d?
1.1.0 and this site from Canon, you can download the firmware.
Canon EOS REBEL XSi 450D Firmware Download
Only when you have a new lens, not yet supported by your came, I would get the firmware.
Jul 26, 2014 | Canon EOS 450D Digital Camera
I am getting this message on my EOS 450d, (camera's built in flash pop up was obstructed turn the power switch to off and on again). I have done this several times the flash wont pop up - can you please...
Sometimes the pop-up flash on the EOS range of cameras can get stuck. The EOS family have a very tiny micro switch under one blade of the flash hot-shoe.
Get a toothpick and manually pop the switch. It should clear your error, too.
Good Luck.
Mar 28, 2011 | Canon EOS 450D Digital Camera
I got Canon EOS Kiss 450D (Japan). Recently, the problem i encountered is ERR 99. I have read an article that it might be with the body lense "connection" and some might arise from battery...
Canon's error 99 is a catch all for connection problems. You can clean the gold contacts with a pencil eraser by lightly polishing the surface and whip with a lens cloth not tissue. However after reading your description about the battery and charger I would tend to believe you have a battery problem. Before changing the battery see if the camera recognizes it and give a state of charge.
I would proceed with this problem with
Cleaning the lens contact with a new pencil eraser
Clean battery contacts in the camera the pencil eraser can be used her as well
Check state of charge with the battery and make sure it isn't leaking
If all of the above fails I would enter the Canon web site and update the firmware of the camera.
Then recheck the battery.
This should bring you back to a working camera
Jan 20, 2011 | Canon EOS 450D Digital Camera
No display nor will it shoot
SHUTTER IS FAULTY YOU NEED TO REPLACE NEW ONE
Jul 11, 2010 | Canon EOS 450D Digital Camera
Can't switch on the camera
I think the charger of the camera might be your problem maybe you'll have to buy a new charger goodluck:) and please rate this solution...
Jun 06, 2010 | Canon EOS 450D / Digital Rebel XSi Body...
Canon EOS 450d not clicking on AF mode
this may have to do with the lens rather than the camera, try swapping the lens with another one and see if the same problem happens in AF mode with the new, borrowed lens, also remove lens and check that the gold connector between the two are clean carefully wipe with a dry q tip but be careful not to allow dirt to fall into camera body.
Apr 12, 2010 | Canon EOS 450D Digital Camera
My canon EOS 450D battery loses power within 5mins
If it's an original battery, call Canon, if you've only charged it once, I expect the camera is still under warranty. I've had lots of dealings with Canon Photography, the usually give extremely good customer service.
If it's a cheap one you bought of ebay - that's why!
www.yourhandinmine.co.uk
May 16, 2009 | Canon EOS 450D Digital Camera
Instruction manual
hi kindly download the manual from the below website... just clik the below link and it will automatically download....
http://gdlp01.cwss.com/gds/0300000933/EOSRXSi-EOS450D_EN.pdf
thank you have a nice day
May 08, 2009 | Canon EOS 450D Digital Camera
How do I know if Vivitar 285 fryed my camera
camera sync terminal wont work with even canon recommended flash.This can be the way to test your camera got damage.
Apr 14, 2009 | Canon EOS 450D Digital Camera
Canon EOS 450D  Digital Camera Logo
56 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
