Question about Kenmore 44102 Front Load Washer
Drum vibration Washer vibrates on spin cycle - even when empty - much worse when loaded. Sounds like something rubbing the drum on each revolution. Can't see any thing unusual on the inside.
  • ljeanquart Jan 19, 2009
    A could be answer needs more info. Lots of things could be. If it's balancers - are they adjustable - Does something wear that would require adjustment or replacement. Is this a a comman problem with a usual solution?
    Sergeant:
  • 221 Answers
Yes, there is...The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Posted on Jan 19, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, confirm if it is a Kenmore 44102, otherwise post brand and model (front or top loading). Additionally, how long has the unit been in service.
  • If it is fairly new, you would be better off seeking warranty service as the nature of the problem would require mechanical works;
  • If the unit has been in service for some time (warranty has lapsed), then repairs would require mechanical works and basic tools;
  • In cases as you described, the drum could be rubbing on a number of parts but the main culprit could be its support structure, bearing, shockabsorber (or support guide);
  • repairs could be as simple as attaching back a detached component or replacement.
Pls post back result(s). Good luck and Thank you for using FixYa.
    President:
  • 2,110 Answers
If your washer is making a "freight train" like noise in the spin mode, ( loud roaring ), this is often the spin bearing built into the bottom area of the transmission that is worn out. This bearing is part of the transmission and means a new transmission is required. The noise is usually a result of water leaking from the center seal and bearing area onto the transmission. This water washes out the bearing and it gets very noisy in the spin cycle!! Do check the easy stuff before condemning, nail/pin caught in one of the inner basket holes, nothing is caught in the drain pump, the inner wash basket is not loose and wobbling around.
    Genius:
  • 2,920 Answers
Your balancers could be out of sync causing the vibration
  • Kenmore Master
  • 19,396 Answers
First check the balance.
If the balance is OK, then the problem is usually the drum bearing, check if the drum haws excessive play when spinning, give me the model niumber to get part price and diagrams.
On the spin cycle my samsung front load washer wibbles and vibrates badly. I have replaced the shocks but that didn't work. What else could it be?
Check that it is level and that all the water is draining out when the wash cycle is complete. Check that the wash drum and all associated parts are correctly in place and are secure. Check the drum for excessive play, replace defective parts.
Also look for loose objects from clothing that may be jammed out of site but causing centrifugal throwout vibration.
Feb 17, 2015 | Samsung 3.7 cu. ft. High Efficiency Vrt...
Washing machine vibration
I had same problem. It was actually wearing out the rubber gasket on front door. It ended up being the spider on back of drum. They corrode pretty good with the front loaders.
Mar 28, 2014 | LG WM1814CW Front Load Washer
What would the cost be to tighten drum in washer
Sounds like the concrete weight is broken. It stabilises the unit while spinning.If the drum moves inside the tub, the bearing has collapsed
May 09, 2012 | Whirlpool duet Washing Machines
Washing machine is working fine but has started making a real loud noise when spinning doesn't matter what speed or cycle it has always been real quite only had washer 3 years does not knock or seem out of...
As washing machines age some of the bearings and seals can begin to wear. After 3 years this wear my cause some noise but will not harm the operation of the appliance. Occasionally debris may become lodged around the drum. Visually check the drum for any lodged clothing, coins, plastic, etc. If you feel confident enough, remove the cover on the washing machine and check the drain for large debris.
If all else fails, installing an anti-vibration pad can lessen the amount of vibration/noise that you hear. Basically, even a small amount of vibration noise like you are describing can be amplified when it transfers to the floor of your laundry room. Try installing a set of small rubber anti-vibration pads like Silent Feet and you might be pleasantly surprised by the improvement.
If the noise gets worse or changes to a thumping or knocking, call you appliance technician or let me know. That may be the sign of something more serious, but I wouldn't be worried right now.
Feb 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Clothes washer vibration during spin cycles
the vibration and noise is most likely from the drum bearings wearing out to test the bearings try this out,,,
open the door, hold the top of the drum and lift it up, if it has any free lift in it the bearings are going, now spin the drum by hand and you should here the rumble off the bearings
Dec 29, 2009 | GE WPXH214A Front Load Washer
During the spin cycle basket vibrates very badly - very rough
I had a similar problem. During the final high spin and there was POW and the drum went funky eating into the plastic. I opened the back of the washer and look things over,.The belt for spinning was intact. I set the washer on a drain/spin option and watched from the front and back. While watching the pulley on the drum and could tell there was a hiccup as it went around. I pulled the pulley off and put on a new pulley. The new pulley was going in a perfect circle to spin the drum. It's not a hard repair, just need a little muscle to loosen the nut holding the pulley on and the same muscle to tighten the nut as much as possible. Hope this helps.
Nov 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Excessive noise/vibration
Vibration problem occurs on dryer/washers because of bad dampers generally. When drum is loaded, the load is distributed randomly, so its create vibration when drum spin in certain revolution. The dampers are supposed to take this vibration and minimize them.
There are more possibilities like drum dislocation or bended drum etc.
Jun 28, 2009 | Kenmore 73932 Gas Dryer
Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Feb 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
Kenmore 44102 Front Load Washer Logo
106 people viewed this question
Fordexpert
Archaeology
Archaeology
reliableservice
