Question about E-Machines T6528 PC Desktop
T6528 beeps twice wont boot
Wont boot up beeps twice
  • E-Machines Master
  • 5,660 Answers
Suggest you remove the Ram Memory modules, ('Stick'), and clean the gold plated contact pins. Then reinstall.
The beeps you hear are BIOS Beep Codes. The computer's way of telling you something is wrong, and an area to look into for it.
2 short beeps indicate a memory problem.
The eMachines T6528 uses an MSI MS-7207 motherboard.
(Micro Star International)
Otherwise known as the MSI K8NGM2-FID /IL / L,
http://www.msi.com/product/mb/K8NGM2-FID--IL--L.html
Uses DDR Sdram ram memory.
(Either 266MegaHertz, 333MHz, or 400MHz. Which is
PC-2100, PC-2700, and PC3200; respectively)
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
Handle the Ram Memory by the BODY. The Body is everywhere on the ram memory module, Except the gold plated contact pins at the Bottom.
The Body is coated with a see-through protective plastic.
Use a pencil eraser to clean the gold plated contact pins.
If you are using an eraser on the end of a pencil, and not a solid eraser; refrain from letting the metal band touch, the gold plated contact pins.
Rub across all contact pins, (BOTH sides), and up, and down on them. You don't have to use too much pressure.
Once finished use air to remove the eraser dust.
You can use a can of compressed air for computers, if available; or air pressure from your mouth will be sufficient.
(Humans can deliver up to 20 pounds of air pressure)
Reinstall.
BEFORE you reach inside your computer, FOLLOW Anti-Static Precautions.
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static.
Computer ON a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
Use a can, or two of compressed air for computers. You may wish to wear a dust mask also.
For additional questions please post in a Comment.
Regards,
joecoolvette
[If this doesn't 'cure' the problem, we will diagnose further ]
Posted on Jan 04, 2013
Continues two beeps and wont boot
From the time it start beep it means either your ram or video card is not good. My recommendation would be checking to connections of the ram and the any other card you have installed on the motherboards or simply just dis connect them wait a couple seconds and connect them back properly and firmly.
KJR
Jan 10, 2013 | Foxconn Computers & Internet
Beeps twice then pauses and beeps twice again(repeats) and wont boot
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer.
Dec 31, 2012 | Dell Inspiron 530s Desktop Computer
Wont boot up
Enter to your BIOS Setup, check hard drive is detected or not , check for Booting Device Priorities and set First boot device as Your Hard Drive.
Aug 14, 2012 | E-Machines T6528 PC Desktop
T6528, when trying to power up, no video, no beeps, cpu and case fan run at full speed. Tried removing memory, no beep at startup. PC was working fine before, and fans only came on when necessary. Some...
If there was a video error generally you would get beeps that are similar to removing the memory.
when this happens you are looking at a failed CPU or Motherboard. For the system to get to the POST it has to get past the CPU hence you have no beeps.
First thing would be to clear the bios and cmos. use the jumper and remove the battery.
If clearing does not work then you would remove the cpu, turn the system on, then off. then reseat the cpu and try it again (remember heatsink as well never turn a system on without the heatsink on it)
Jun 29, 2011 | E-Machines T6528 PC Desktop
How do to change the boot order in a emachine t6528
When the machine are start to boot press F2 before start windows, That is the setup of the Bios and there you can change the boot order
Dec 29, 2010 | E-Machines T6528 PC Desktop
My T6528 is not booting at all, I tried everything; changing the
Might be your RAM too !
Remove all memory modules and turn ON.
If there are some beeps, than we found the problem!
Replace the Memory module with a new one.
If you have more than one memory module, try to boot with one and then with others, one by one.
If (when) you get normal boot, then tha's it. Replace the broken RAM memory module with antoher.
You may also to try to put your memory module to antother (your friend's machine) to find if it is OK.
Regards
Mar 25, 2009 | E-Machines Computers & Internet
Emachine T6528 problem: My monitor wont boot up went i start the computer!
Easiest solution is to connect your monitor to another PC, if still nothing, then your monitor is toast.
If you are getting no display at all, and you tried a PCI video card and the onboard, most likely it is your monitor.
This is going to sound really dumb, but just incase, check to make sure both cables are snug in the monitor, I get calls daily at work with people telling me their monitor has died, only to find out that the power cord in the rear or the monitor is not completely snug.
Jan 22, 2009 | E-Machines T6528 PC Desktop
E-Machines T6528 PC Desktop Logo
71 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
