Question about Microsoft Forefront TMG Enterprise - Processor License
How to connect tmg and firewall in the same network and how to configure
How can I download purchased items on itunes (error 8003) from behind a Cisco RV220w firewall?
Configure the Cisco to "log everything", and then try the iTunes download. Then, examine the log-files, to see which connections were blocked. Then, configure the firewall to "allow" those TCP-ports.
Apr 23, 2014 | Cisco RV220W RV220W-A-K9-NA Wireless...
Configuration allow to connect the skype services we are using juniper firewall ssg140. How to configure?
Have you got the solution ? If you already have got please, spare few moments and send me the solution by mail at sundesa2000@gmail.com.
Thanks.
Regards
Jan 24, 2013 | Juniper Netscreen Juniper Networks SSG140...
Google talk sign in not open cnnection error
"This error most commonly appears when you have no connection to the internet.
If your internet connection is working, you may have an issue with your firewall or proxy server. First, make sure that your firewall is configured to Allow Google Talk; we've provided instructions for some of the more popular firewall applications below:
A proxy server requiring a proxy username and password could also cause this problem. To configure your proxy:
  1. Open Google Talk.
  2. Click Settings .
  3. Highlight Connection along the left side of the dialogue box.
  4. Select Use the following proxy .
  5. Check the box next to Proxy requires Authentication .
  6. Enter the proxy username and password.
  7. Click OK .
Finally, your network administrator may have disabled Google Talk on your network. If you continue to see this error, please contact your network administrator."
Google Support
Aug 06, 2011 | Google Talk
Get no signal from router
There are many network-related settings that need to be configured on the system for connecting to a wireless network. If even one of these settings have not been configured properly, issues will come up. All users facing problems with the use of wireless networks are advised to check network-related settings such as access points, IP address in use and reconfigure them if they are not properly set. Users are also suggested to check the firewall settings to make sure that the firewall is not blocking network connections.
http://router.iyogi.com/wireless-network/wireless-network-not-working.html
http://www.informationweek.com/news/mobility/802.11x/216403550
Jun 10, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I want to use my d-link router with my new acer laptop but cant connect to the router. Windows says it is a router connection problem. It can locate the router just wont allow me to connect.
1.In Control Panel, click Network and Internet Connections, and then click Network Connections.
2.Right-click the Wireless Network Connection, and then click Properties.
3.On the Wireless Networks tab click Add.
4.In the Wireless network properties dialog box, enter the SSID "(Name of the connection) ex. dlink1234" you configured for your wireless gateway
5.Fill in the rest of the fields, including the necessary authentication and encryption information based on the configuration of your wireless gateway. (WPA-TSK, WPA2-TSK, WPA-AES and WPA2-AES)
6.Click OK and your home network will be added to the list of preferred networks.
if you have a firewall in your laptop try to disable it. example Eset Security antivirus Firewall. Disable the Firewall.
Aug 25, 2010 | D-Link (DI-784) Wireless Router
I have zyxel zywal 35 have two wan port, wan1 connected to t1 line, wan2 connected broadband line , now the firewall configured on active/ passive mode,it was working fine but some times. fire wall lan ip...
This is due to some bad packets on your network. Check the network for any worms/spywares. Also check if the ethernet connections/card donot malfunction.
Jun 19, 2009 | Zyxel ZYWALL 35 Firewall
CONFIGURE CONTENT FILTER IN NETGEAR FVX 538 PRO VPN FIREWALL
For blocking IM service, you need to configure the IPS (Intrusion Prevention Service)
Mar 26, 2009 | NetGear PROSAFE 200 FVX538 (FVX538NA)...
Laptop can't connect to internet
1) Your Network or DSL router may have bad or missing information. Powercycle your router and/or rebuild the configuration in your router.
2) Double-check your cabling to the computer. Make sure you have the correct type of cabling, straight-through CAT 5 or possibly a crossover cable and try another cable or test the cable to make sure its working properly.
3) Check your network card to make sure its configured correctly and working properly. Many times setting the network card to 10Mbps/Full Duplex will solve this issue. To do this, open Control Panel, System, Device Manager. Go to the properties of the Network card, click on the Advanced tab and find the Link Speed and Duplex section. Change it from Auto Detect to 10Mbps/Full Duplex.
4) Check and test your firewall. Your firewall, especially if its a software firewall like ZoneAlarm, Black Ice, Norton Firewall or something else could be blocking the connection. Disable your firewall and test the connection. You may have to resolve the problem by even uninstalling and reinstalling the firewall.
5) Check your IP address assignments and workgroup settings in the computer for accuracy. Statically assign IPs to the computers in your network.
6) Reset your TCP/IP stack by downloading and running WinsockXPFix.exe a Visual Basic program designed to fix corrupted TCP/IP issues, host file problems and a variety of other connectivity issues.
Nov 19, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Microsoft Forefront TMG Enterprise - Processor License Logo
15 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
