Question about Garmin nuvi GPS
Navsure n420i trouble aquiring satellites
Takes about 10 minutes to pick up a gps signal
hydetech
  • 113 Answers
SOURCE: Garmin GPS 45
It is probably one of the following:
1)Old Software
In 1999 the GPS satellites were reset and the new almanac data had to be loaded into the GPS 45 for it to continue to work. It was not uncommon for that model to quicly kill a set of batteries when it is having difficulty acquiring, which would cause it to shut down in order to save the batteries for its internal memory.
I just did a quick search of the Garmin website and it appears they no longer support that model. If you go to their support page and send a request for a software update they can probably e mail it to you. The update is free but to down load it, you need a PC interface cable (RS232 serial port connector) Part Number: 010-10141-00 Suggested Retail Price: $ 38.09.
2)Bad antenna
To rule this one out, borrow an antenna from another Garmin 45 or Garmin 48, or plug the unit into an external antenna and see if the unit still shuts down. The drawback to this method is that you can buy a new GPS that is superior to the one you have for about the same price as an external antenna.
3)Bad batteries
If your batteries are low, the unit will automatically shut off to protect its internal memory. I tried a lot of different batteries in my 45 and I found that Eveready alkaline batteries worked best. Rechargeable nicad batteries don't work very well because they fool the battery meter. Newer models have a setting to specify that you are using rechargeable batteries.
Ultimately the best advice I can give you is buy a new GPS. For less than $150 you can buy a new model that is more accurate, more reliable, stores more waypoints, has a better display, is easier to use, and gives you more valuable information.
Please rate this information as helpful.
Posted on Jan 24, 2008
  • 6 Answers
SOURCE: Kenwood KNA-G510 antenna?
After contacting Kenwood tech support several times, a tech finally came out and said if the unit is under warranty send it back to them and they will swap it since they do not repair it. If the Unit is out of warranty, then contact Garmin. When I contacted Garmin, the tech stated that Kenwood is pulling a fast one instead of standing behind their product. So who actually owns this product Kenwood or Garmin? Both names are on the product, but no one wants to repair it. Anyway to make a long story short there is a new update for this product 3.60 as of Feb 2008, downloaded and the unit works fine. Should resolve this issue.
Posted on Feb 13, 2008
SOURCE: Garmin GPS problem
I have a 276C that has the same problem. Garmin has a unit with this problem and is working on a solution. The problem is that the real time clock loses time when the unit is turned off and disconnected from a power source. As a result when you turn on the unit it thinks the satelites are in a different orbit than where they actually are. The unit will continue trying to aquire forever and not find the satelites. You have to select "New Location" from the menu and select "Autolocate" and the unit will start to look for any satelites in view. The unit should get a fix within 15 minutes. This is a very frustrating problem having to reset it every day. There is a new version of firmware (5.3). I don't know if the problem has been fixed with this release.
Posted on Jul 06, 2008
sharcnet
  • 2130 Answers
SOURCE: I have a Nuvi 200w
While under warranty.... yes.... Make sure it's been registered on their site before calling them and requesting an RMA number.
- Jim
Posted on Sep 17, 2008
SOURCE: Dont Aquire Satellites
Ditto.. even after updating FW...
Posted on Sep 29, 2008
Navsure n420i my screen ribbon is damaged where can i get spare part for it and what does it called ? thanks guys
You can find used GPS devices and screens for most vehicles online for a good deal.
Nov 05, 2013 | Cars & Trucks
Navsure n420i won't load
This is washers & dryers. Try posting in Nav.
Oct 23, 2017 | Washing Machines
What would it do to my navsure n420i car sat nav / radio if i put a 13 amp fuse in if it's a 10 amp radio
The fuse is made to protect a 10amp draw 13 amps will start burning wires you need to follow the specs if your 10amp is blowing then there is a circuit prob.
Jan 18, 2012 | Cars & Trucks
I have a navsure n420i and soon as i try and use it a message comes up saying - application navigation.exe has performed an illegal operation and will be shut down can you tell me why this is please ...
Take the SD card out and put it in your PC, go to the folder called Navigation and replace the Navigation.exe with this one. Hopefully this will work. (The file i am sharing is from my Navisure N420I's Satnav so it should work no issues).
http://hotfile.com/dl/110244854/dd4a70a/Navigation.exe.html
Mar 13, 2011 | GPS
GPS wont aquire a satellite
    Hello there and happy new year
    If Your Unit Cannot Acquire Satellite Signals
  1. For your Garmin GPS unit to acquire the satellite signals it needs to function properly, the unit must be taken outside, away from mountains, tall buildings and heavy foliage where it can get a clear view of the sky. Keep the unit stationary for several minutes while the GPS unit acquires the necessary satellite signals.It may take several minutes for the unit to locate a good solid signal
  2. OK
  3. Hope this is very helpful please keep me posted on this ok?
    Best regards Michael
Jan 01, 2010 | Garmin MAP76 handheldS GPS Receiver
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
N ot able to aquire a satellite signal for two
have you downloaded the "HotFix" software update for the problem from Garmin yet? if not u will need a mini USB cable (avil on ebay for $5) and then register the GPS at this site www.mygarmin.com and select support or downloads and follow instructions..
Oct 01, 2009 | Garmin nuvi 255W GPS Receiver
My tom tom ONe cannot get a valid Satelite Signal just stays wait
If you are indoors then move outdoors to get a signal.
If you are outdoors then move your location by a few yards and sometimes it will suddenly aquire the satellites.
Happens occasionally with my unit. I normally set a route up then start driving and it suddenly starts to work OK.
HTH
Peter
Mar 07, 2009 | Tomtom ONE GPS Receiver
I have a Nuvi 200w that I received last December as a gift. This unit takes forever to aquire a satellite. The "DIFFICULY AQUIRING SATELLITES" message comes on 90% of the times I try to use it....
- Jim
Sep 17, 2008 | Garmin GPS
When i put my Navman icn 320 on sometimes it takes upto 30 to 40 minutes waiting for the GPS signal to come through
Hello adamant,
In order to determine your current location the GPS needs to receive telemetry information from several GPS satellites. In order to do that it needs a clear view of the sky. This should happen fairly quickly, typically within a few minutes, but depending on how and where you are operating the GPS the process could take significantly longer or the GPS might be unable to aquire a satellite lock at all.
Local geography such as mountains, hills, tall buildings and heavy forest can block the GPS's ability to receive satellite telemetry. The same thing can happen if you are trying to operate the unit indoors or inside of a vehicle without an external antenna. That's why most GPS receivers are installed on the dash board of the car: the windshield and side windows provide it the best view of the sky.
It is also possible that there is a problem with the GPS receiver or the antenna. To test it, try using the device outside in a relatively open area with a clear view of the sky in all directions. It should aquire a satellite fix in about five minutes or less.
Best Regards,
Ken
"Go Ahead. Use Us.
Jul 08, 2008 | GPS
GPS Logo
23 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
