Question about Ignition System for Toyota Tacoma
Removal of ignition switch on a 96 tacoma - Ignition System for Toyota Tacoma
  • Toyota Master
  • 14,363 Answers
Here's a link on how to replace the ignition switch.Here's the part.
Posted on Jan 10, 2013
Key stuck on a toyata tacoma
sound like ignition switch keylock cylinder broken.keep trying work key out might come out if not you have to remove ignition switch with keylock cylinder.
Jul 10, 2013 | Cars & Trucks
How to install a ignition switch in 96 tacoma
It shouldn't be too bad, lots of little screws and plastic interior parts, but nothing knuckle busting. I am not familiar with the 1996, but I found you an easy tutorial for a 1994. I'm guessing you can fill in the gaps and figure it out:
http://www.ehow.com/how_6302489_remove-ignition-switch-1994-toyota.html
Get yourself a Haynes or Chilton for that model if you're doing the work yourself, they're definitely worth the $20.
Nov 26, 2011 | 1996 Toyota Tacoma
Where is the Ignition coil located on a 96 tacoma
The device(s) at the end of your spark plug wires are your coil pack(s)
Feb 18, 2011 | 1996 Toyota Tacoma
96 tayota tacoma, 2.7 4 wd, the engine is hard to start when the engine is hot. When cold the engine starts fine.
1. air filter dirty. 2. bad engine ground. 3. fuel filter 4. loose connection in ignition system. 5.faulty idle control system.
Aug 30, 2009 | 1997 Toyota Tacoma
96 Tacoma 4x4 2.7 engine cuts out randomly, like its trying to get air or fuel. just installed cold air intake, full tune up, fuel filter, mass air flow sensor, battery cable, hoses, tps(sensor), and...
dont look for air when the car cuts out its most likley spark or fuel when it cuts out ranomly its usually a sensor or relay that is faulty check fuel pump relay and camshaft or crankshaft sensors but first narrow it down to spark or fuel if possible also if check engine lite is on check codes
Mar 26, 2009 | 1997 Toyota Tacoma
Ignition switch.
This is the method for removing the lock and key switch ,not the electrical portion.
remove the screws from the bottom of the shroud. Remove the lower shroud so you can get a good clear view of the ignition lock. There is a small silver pin (retainer) that is holding the lock in along the bottom of the ignition housing.While applying pressure to the pin with an icepick or similiar tool turn the key clockwise until you feel the pin drop into the lock. At this point you can remove the lock cylinder with a little help of a flatbade screwdriver.
Sep 03, 2008 | 1996 Toyota Tacoma
Need to remove ignition switch
remove shroud
insert key into ignition turn to acc you will see a hole at the underneath of ignition housing with key on push in pin and pull switch out
Jul 24, 2008 | 1996 Toyota Tacoma
Ignition System for Toyota Tacoma Logo
82 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
