HP All In One MS214a is Dead
I bought this unit by auction as faulty thinking I may be able to fix-it..I have checked the power supply and its ok and the green LED is lit where the P/S plugs into the Motherboard..but other than that the unit is dead..SO..I have now removed the outer rear plastic cover and the M/B metal cover....Oh dear ?? what next...this is completely different to working on a normal desktop but I presume the same principals apply...IE disconnecting everything till the motherboard is isolated and then power up looking for any life ...But I am no expert so I would certainly welcome any advice that I can get...Thankyou
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
I know nothing of this laptop. Although I do have a Hp dv9000. Before you get to far I advise drawing "blue prints" and noting where the screws go and also their color and length. For example; I drew a rectangle and drew landmarks. Then used solid dots to represent black screws and circles to represent silver screws. And maybe a slash beside or through them to represent a longer screw. But youtoube has many dissasembley videos, and I'm sure you can find your model.
Posted on Jan 04, 2013
  • Hairy Kiore
    Hairy Kiore Jan 04, 2013
    Hi..Its a desktop all in one not a laptop but thanks for your interest.. I do have the rear off and now trying to get help on what to do next... g
SOURCE: motherboard replacement Fujitsu Siemens Amilo D7850
hi there , just removed that metal plate here, you need to pull the cd rom right out, then right on that opening of the cd rom you will find a screw, also, there are four others on the corners of that metal bit to be removedthen, just lift it up, job done, hope this helps..
Posted on Dec 09, 2008
  • 136 Answers
SOURCE: Computer dead despite working power supply (power and charger LED are off)
Try removing the battery. It might be damaged and overloading the laptop. Also, before you replug the AC cord, press power for at least 5 seconds.
Posted on Nov 02, 2008
ldaala
  • 65 Answers
SOURCE: HP DV9000 dead
i had the same problem as well but mine turned out to be the processor but i had taken it to a pro and he said it was the motherboard or processor but he didnt have either one to try and see so i got a processor on ebay for 30 bucks used and it turned out it was the processor if u are looking to replace the peices one or both ur looking at about 450 bucks apeice for those peices so good luck
Posted on May 26, 2009
  • 81 Answers
SOURCE: Dead motherboard
bad news - an overheated F500 is a really expensive paperweight. All you can really do is try and source a new motherboard and hope the CPU and RAM didn't go the way the board did...
Posted on Jul 21, 2009
parrotheadpc
  • 2600 Answers
SOURCE: the PC doesn't start. led is not blue when power cord plugged
Below is a link to the service and maintenance guide. This will serve as a reference for disassembly. It is free to use, copy and print. It is in PDF format. I would check the voltage at the tip of the adapter to make sure it is putting out the proper voltage. I have seen plenty if failures with the HP laptops at the DC jack area, in most cases these jacks are connected to the motherboard by a cable and plug, which makes them easier to service than the soldered type. Here is your guide........
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01550099/c01550099.pdf
Posted on Jan 13, 2010
How do I get Daewoo to stop red/green red/green and start up?
The fact that it was put up for auction suggests it probably was unrepairable.
Oct 29, 2017 | Televison & Video
Dead FTDX3000
Not sure what you mean by "Crow Bared" power supply... If you blew the fuse you should be ok. If there was smoke, there was damage. If you have the FP-1030A power supply you can hook it up incorrectly and cause permanent damage. Tell me more about what happened. Thanks Chris
Jan 07, 2014 | Radio Communications
I have a IQ816. Purchased recovery discs from HP and reinstalled Windows. Had problems from beginning and noticed that files were being corrupted. MRI diagnostic indicated faulty hard drive. Replaced...
all in one, are no fun to fix. a real DT is vastly more easy
and standardized ... ATX , for example.
cute sure, but hard to work on,
there are no schematics, they are secret. (called proprietary)
last thing HP wants is illegall clones, no?
why not get the full HP.com service manual.
it tells you the PSU voltages. to check.
all must be good.
what if the CD drive is bad, you will get CRC errors reading it.
why not boot to a USB stick
put any live OS on the USB stick. linux or windows 8 or 10 PE, boot disk.
then boot to the stick , omg the computer is ok. just a dead CD drive.
that be like 1st off the bat
all shops keep boot USB sticks, all do.. or diagnosis goes , to H3LL..
BIOS screens all look good,. bios memory check passes.
Bios, shows memory size matches whats there.
try running one memory stick at a time.?
it 2 memory sticks? try both1 at a time.
make sure CPU is not overheating, and fans ok.
if say the OS boot sticks (way windows 8 PE live works)
or any do and a new HDD will not load any OS.
then the SATA port must be dead.
if all above checks out, the PSU is toast.
Power supply unit.
Mar 27, 2017 | HP Touchsmart IQ816 All-in-One Desktop PC...
The power connections are ok; and the cables are ok but the printer has no power, how to fix it?
Hello
Check the fuse in the printer, otherwise power supply may gone faulty, needs repair from HP technician.
Good Luck
Jan 19, 2011 | HP DeskJet F380 All-In-One Printer
Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply: My Dell Dimension 4400 is dead with none of the 4 ...
It seems like it that you have a faulty power supply. Also the motherboard may be damged aswell, But most probably you can fix your PC by changing the power supply.
May 16, 2010 | Dell Dimension 4400 Power Supply ** FREE...
Won't turn on
I had a like problem with a HP printer after I returned from vacation. While mine wound up being dead from a power outage while I was away, make sure the power supplly is firmly connected, also try another outlet, as silly as it sounds. but most likely the power supply failed. You can look for a replacement on a popular auction site and expect to pay up to 10 bucks for a OEM unit.
Jan 30, 2010 | HP Photosmart C7280 Printer
I have a HP Pavillion DV4000 and it does not charge
pls check if it runs ok during power supply AC and also check Battery contacts on both side laptop side and battery contacts see if rust or residue is sticking there try to scratch it out by some rust removing cream or something normally it happens other wise if the adapter supply is ok AC one then ur battery is faulty try replacing it there is a battery checking utility on HP support software try it , i think it will help u cjeck the batt
pls rate me if i fixed it
Feb 27, 2009 | HP Pavilion dv4000 Notebook
Cdp-ce215 sony cd player display dead.
Yes, most likely it is the display. Your best bet is to sell it for parts/as is on craigslist or the likes, and purchase a replacement as a comparable replacement would be very inexpensive. If you have any other questions let me know.
Thanks,
Lee
Sep 02, 2008 | Audio Players & Recorders
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
