Question about Refrigerators
Icefull and deficient light stays on, not making ice
When you select the size of ice and you press start, the machine kicks in and with in seconds the icefull and deficient light comes on. The machine then automaticly stops.
farrakh
SOURCE: the scotsman ice machine makes ice fine, but
i have a machine of scotsman MV 21 how i adjust the qube size
Posted on Jan 12, 2009
TheMobilian
  • 8220 Answers
SOURCE: scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 01, 2009
  • 531 Answers
SOURCE: Ice and Water Dispenser problem GC2224GEKB
check panel board
Posted on Apr 07, 2009
  • 33 Answers
SOURCE: Scotsman Ice Maker CME 256
descale bin level sensors, check for corrsion on wire harness. if does nt work. replace . bin level sensors
Posted on Aug 26, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Posted on Apr 21, 2010
My PT Model IM-600 US ice maker makes cubes but continues to freeze on the ouside of the cube tray blo th cubes from falling into the bucketwhat is wrong.
cubes set too large
Adjusting the Ice Cube Size: 1. Press and hold the "Adjust" button for approximately 3 seconds until the Green Indicator starts blinking, release the button. The unit is now in Ice Adjustment mode. 2a. Press the "CLEAN" button to decrease ice cube size. The Red Indicator will flash as you lower in size and will blink when you have reached the smallest possible setting. 2b. Press the "MODE" button to increase ice cube size. The Yellow Indicator will flash as you increase the size and will blink when you reached the largest possible setting. After 10 seconds without any operation, the unit will return to the previous mode. NOTE: • During the ice adjustment mode, if the "ICE FULL", "ICE MAKING" and "ICE HARVEST" LED's all blink simultaneously, this means setting is at the regular (middle) size. • When the machine is in the cleaning stage or ice full stage, the ice size cannot be adjusted.
Dec 04, 2017 | Refrigerators
Why when ice machine has water,but when press on it shows deficient and will not start .power is on
Since the water comes directly from the house, check the pressure. Otherwise you may have a hole in the water tube. Check for leaks.
Jan 13, 2015 | Refrigerators
How do I get the printer to print automatically using the bypass tray
you can set the bypass tray the size you want then set paper size setting in the printer driver at your PC.
Hold down the [PAPER SIZE ENTER] key more than 5 seconds to
set the selected paper size.
The currently selected paper feed location indicator will blink and the
corresponding paper size (which is currently set) indicator will light
steadily.
All other indicators will go out.
If the machine has two paper trays, use the [TRAY SELECT] key to
select the paper tray for which you wish to change the paper size
setting.
Each time the [TRAY SELECT] key is pressed, a paper tray will be
indicated with a blinking paper feed location indicator.
Use the [ORIGINAL SIZE ENTER] key to select the paper size you want to set.
The indicator of the selected paper size lights up.
Press the [START] key and then the [PAPER SIZE ENTER] key.
To change the paper size setting of another tray, repeat steps
after pressing the [START] key
Make sure that the tray's paper size setting is the same as the tray's
paper size setting in the printer driver. For example, if the tray's paper
size setting is A4R (LT-R), set "Setting Paper Size" to "A4-R".
Jul 01, 2011 | Toshiba E-Studio 161 Copier
Ice machine stopped making ice. The "bucket" that holds the water around the ice making sensors no longer moves when the ice machine is powered on or off, and noise can be heard as if it is try...
I had a similiar problem. The unit would only flash deficient. I removed the rear cover (3 screws along the back top, 3 screws underneath, and the 2 feet), then opened the panel to access the control board and disconnected the temp. sensor. Working great now, but the deficient continues to flash. Hopefully i will be able to find a replacement part.
Jan 05, 2011 | Sunpentown SPT IM-100 Portable Ice Maker,...
I have a Magic Chef Ice Maker Model No. MCIM30TS. My problem is that when I plug it in, nothing happens and the power light is blinking. Is the unit shot? Andrew from New Jersey
Hi, It's supposed to do that. Fill the base with water, then select an ice cube size, then click "start". It should start making ice within 20-30 minutes. The power goes off here all the time and that's how we re-start the machine. The important part is to first select the ice cube size, then click on "start'. I have no idea why it has to be done in that sequence. I have the same model, only I got it two years ago.
Apr 26, 2009 | Refrigerators
Scotsman 500 cm3 ice machine
Jul 17, 2008 | Scotsman Ice Maker 600LB CM3 30inW...
Refrigerators Logo
131 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
