Question about Kenmore Washing Machines
I need a user manual for kenmore elite washer model 110.22982101
I purchased a used kenmore elite washer model 110.22982101 and I need a user manual.
Jimster
  • 240 Answers
SOURCE: What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
Posted on Jun 01, 2008
SOURCE: Kenmore Elite He5t Washer Error F24
If it is not the plug at the bottom is ok and the temp. sensor is ok.Check the plug on the CCU on top mine was not even plugged in. When I plugged it in the washer started working. You have to take the top off to get to it,but it is easy. Three screws on the back top and the top will slide off easily. There is a troubleshooting manual in the front bottom panel on right side of panel. Page 10 troubleshoots the temp. sensor. The book gives you all the troubleshooting codes. The front panel comes off easily by unscrewing three screws on the very bottom of the panel.
Posted on Feb 08, 2009
  • 311 Answers
SOURCE: My Kenmore Elite washer spins to slow cauisng the
If this is occurring mostly on heavier loads your clutch may be slipping. If you take a flathead screwdriver and push down the lid switch so the washer will spin with the lid up, grab the inside of the drum. If you can easily stop the drum its most likely a bad clutch. If you tip the washer back and see oil underneath then its probably your transmission leaking oil onto the the clutch causing it to slip (in which case you need transmission and clutch assy). If you see oil I would probably not bother calling a tech it would be a pretty expensive repair.
IF the problem is with the clutch only it may be worth repairing but to replace the clutch you will have to remove the pump, motor, transmission, and the clutch mounts on top. The other less common possibility could be a bad drive block under the inner tub. hope this helps. _MJ_
Posted on Jan 28, 2010
SOURCE: need a manual for my kenmore elite he3t front load washer
My Kenmore Elite HE3 has been great for many years, and now I have a little problem for the first time.
I can usually press cancel to change the program. This morning, after I selected one program and press cancel, it won't cancel. Lights just blinked. So, I press Start to wash with selected program, but it won't start. It won't start nor cancel no matter what I do.
Should I unplug the unit?
Thank you so much!
Posted on Mar 11, 2010
  • 1937 Answers
SOURCE: Kenmore He3 washer manual required
See the following Sears site for on line (PDF) manuals
http://www.managemylife.com/mmh/owner_manuals/search?query=110.45872400
Posted on Mar 29, 2010
Need to know the exact height of the sears kenmore elite refrigerator model 52704100
You should be able to find it in the manual
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/user-manuals/manual-downloads/Model-59675532400/0583/0161000?modelNumber=59675532400&diagramPageId=&documentId=
Oct 10, 2014 | Kenmore Refrigerators
Need Owner Manuals for Kenmore Elite Washer & Dryer Model # 110.47751800 & 110.97751801
You can download the manuals from here:
Kenmore Washer 47751 (110.47751800)
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0808509.pdf
Kenmore Dryer 97751 (110.97751801)
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0708326.pdf
The manuals are quite large so may take a minute or two to download, depending on your internet download speed. If you have any problem opening or saving the manuals, please let me know. You may need to download and install Adobe Reader to open the file.
http://get.adobe.com/reader/
Regards,
BElectric
Oct 21, 2011 | Kenmore Elite HE4 Electric Dryer
Head over to the manufacture's website. WWW.SEARSPARTSDIRECT.COM
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 15, 2010 | Kenmore Elite 45986 Front Load Washer
How can I get a copy of the User Manual for the Kenmore Elite HE 3? I would like to get a downloadable one if possible?
See the following two sites.
Enter your complete model number AND:
The first site should show diagrams of all the major components in the washer.
The second site is Sears site for downloading PDF versions of their User Manuals.
SEARS PARTS SITE MAY HAVE MANUALS
http://www.searspartsdirect.com/partsdirect/index.action
SEARS ANSWER SITE
http://www.managemyhome.com/
May 03, 2010 | Kenmore Elite HE5t Washer
Bellow for Kenmore Elite front-loader washer
The Bellow should be available at a appliance part store. be sure to call with the model number and serial number, that way if they don't have it they will have time to order it.
Apr 12, 2010 | Kenmore Elite 45986 Front Load Washer
We just purchased a used Kenmore Elite 42832 from a divorced couple that was unable to produce an owners manual. Can you help? Steve & Deb
See the following.
SEARS ANSWER SITE
Enter your full model number and you may be able to download manuals.
Dec 20, 2009 | Kenmore 42822 Front Load Washer
I need a manual for a Kenmore washer, model # 1102708604.
I have now got the manual for the Kenmore Elite washer and dryer coming in by mail. I had gone to the local Sears store and then to the service center close to home. The service center was able to find the manuals and order them for me.
Thanks for your help.
Cecil
Apr 10, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
71 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
