Question about Simplicity 42 Toro Timecutter 20hp Kohler Zero Turn Lawn Mower 2012 Ss4235
When driving backwards or forwards my Toro has a horrible grinding sound plus vibrations coming from lefthand side only.
Dont know model or serial number it does say 18.44Z on decal.
Why wont my toro move, as soon as i try to go forward or backward it shuts of?
Check that your operator present seat isn't disconnected.
Mar 15, 2015 | Toro Garden
I am getting a grinding noise near the top of the front drive shaft
I would love to help you , but you have no usable info on this problem other than the noise.
What year , make, model or engine/trans type???
Could be a front differential problem...
Feb 23, 2015 | Cars & Trucks
Grinding noise, intermitent.
there are many things to cause this problem. torque converter is most likely expected if its 3.0 v6. notorious for these problems. If you don't know where it is located, it is behind the transmission. you will have to drop it and it is a cylinder. another issue that could cause rough vibration is bad motor mounts.
Jun 12, 2013 | 2000 Ford Focus
What drives toro 12-38 toro
Question: Is theToro a hydrostatic drive? If it is check the oil level.
Dec 30, 2012 | Toro Garden
Mower run but wont drive forward or backwards?
check the drive belt also is the release lever pulled the one that allows you to push it
Apr 15, 2012 | Toro Garden
Rear end rattle and clunking sound when put into gear
check unversal on drive shaft. put in neutral and shake drive shaft
Sep 14, 2017 | 1999 GMC Sierra
I bought a self propelled Toro mower and it is hard to pull backwards. I removed the plastic toe guard and that did not help. I also have a White "brand" self propelled and it is easy to pull backwards.
The self propel system uses a type of racheting pinion drive that sometimes gets greased up and wont release like it should.
You would need to remove the wheels and pinions and look at the shaft ends for a key, a ball and a spring. This is the "pawl" that locks the wheels going forward and rachets when the wheels go backwards.
Clean up the parts of all the aluminum colored grease and reoil with something lighter. 3 in 1 would do nicely. Reassemble.
Now the next time you start going backwards and it jams...just push the mower forwards slightly without engaging the drive and see if the unit doesnt free itself.
Good luck and be careful!
Jul 19, 2010 | Toro Garden
I have a toro self propelled lawnmower. Ireplaced
the spider gears are in on the wrong side more less like you put the rear end in backwards
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
Self propel toro mower will not "self propel", nor will it pull backwards
that dont make sense self propel is forward only release handel pull it back could have broke a belt on the pull or wheels are full of grass
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
I have a toro lawn mower it is a little hard to go forward but does go. It doesnt go backwards at all. Can you help me! Joanne
Check the drive belt for flat spots. If it is ok then it is probably an internal transmission problem
Jul 22, 2009 | Toro Lawn Mower With Toro Power Tools
Simplicity 42 Toro Timecutter 20hp Kohler Zero Turn Lawn Mower 2012 Ss4235 Logo
35 people viewed this question
Top Simplicity Garden Experts
Dennis Key
Dennis Key
dannydoesita
Will Mishler
Will Mishler
Are you a Simplicity Garden Expert? Answer questions, earn points and help others
