Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier AC with heat strip Model # 50SS036301 - outside fan runs all the time! I would like the phone # to obtain a trouble shooting manual or the solution. The unit works well on both AC and Heat.
bobicehouse
  • 1524 Answers
SOURCE: Air Conditioner from upstairs neighbors condo makes water sounds
Time for a new unit. End of sentence.
Posted on Apr 26, 2009
  • 10 Answers
SOURCE: AC fan stopped
Sounds just like a seized bearing on the fan motor. They can be repaired but it's usually less to purchase a new motor. Now all you have to do is figure out how to get the motor out. To get you started, you need to partially disassemble the top portion of the condenser cabinet. This will give you access to the fan motor assembly. Which model do you have? That information will be on the nameplate which is on the side where the electrical enters the cabinet. That reminds me, always pull disconnect and trip breaker before starting.
Posted on Jun 19, 2009
flatech
  • 111 Answers
SOURCE: Outside AC unit working, but inside there is no
Depending on what type of Thermostat you have, it is usually as simple as setting a jumper for Electric heat instead of gas.
If you have a digital Thermostat then turn off the power to the Air handler and remove the thermostat. Look closely at the small jumpers and make sure your jumpers are set to elect. and not gas so the fan can run in heat mode.
If you have a standard heat cool mercury switch then same as before with the power and unscrew the thermostat, and where the yellow wire is connected if there is a factory with on the yellow, then move the factory wire to the (A) and put the yellow wire back on the (Y).
Good Luck!
Posted on Nov 14, 2009
  • 767 Answers
SOURCE: Carrier 38CKC042300. oUTSIDE UNIT FAN WAS TURNING
The outside fan may run if the unit is in defrost mode this is normal for most heat pumps it is there way of trying to keep the outside unit from staying iced over so the next time the unit runs it will have air flow through the coil and the ice will not be there to prevent air flow.
Posted on Jan 12, 2010
  • 19 Answers
SOURCE: horrible awful noise coming from carrier heat a/c wall unit!
I watched your video on youtube. Sounds like a seized compressor. Do you know if it is reverse cycle or electric heat?
Posted on Jan 21, 2010
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
My a.c. is in heat mode and its on and off and I switch the thermostat off but the ac still runing on and off
Easy fix is pull dissconnect on ac compressor.Thats the big box outside with fan in it.should have a box next to it where you can pull out handle to cut power.if not check fise box for doubble breaker labled ac.Not a heat pump is it?if it is thenthats a different problem .other easy fix is go into furnace and dissconect wire running to ac.The small one.Finding the cause is pretty advanced trouble shooting
Dec 31, 2010 | Heating & Cooling
Carrier outside unit not starting and is very hot
Either the condenser fan is not working and it has shut down on high pressure... or the compressor is locked up and trying to run and is making the heat...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 13, 2010 | Carrier 38CKC036 Air Conditioner
My Carrier Home Central Air Conditioning Model Number 38CKC036 340 fan out side the house is not working it gives oout a low humming sound and fan doesnt rotate Serial Number 4698E05846 Manufacturer...
If the fan is humming and not running them it has gone bad....it will need to be replaced...not all that difficult a job...most pro's do it in less then an hour...
heatman101
Aug 11, 2010 | Carrier 38CKC036 Air Conditioner
In home fan puts out air thru vents however the model38ckc060370's fan stopped working and no ac flowing through unit to cool house. Is there a simplle trouble shoot for my problem?? The unit is 7 years...
Make sure circuit breaker for the outside unit is on or the fuses are good whichever you have. If they are on you can check the capacitor in the outside unit. The capacitor will be a round or oval can and can be metal or plastic. You can also look at the contactor to see what shape it's in.
May 03, 2010 | Carrier 38CKC060 Air Conditioner
Carrier heat pump (basic model) runs at 0 or below
A basic model heat pump with an air handler with electric strip heat generally will continue to run with a call for heat regardless of the outdoor air temperature unless there was an outdoor thermostat (an accessory) installed. There is still heat in the outdoor even at temperatures of zero and below. Generally, there is a balance point of approx 30-35degF that allows the heat pump to heat your house to 68degF without the need for the electric heaters. Below that, the heat pump can still extract heat from outside and "pump" it into your house; however, it will need help from the electric heaters. In temperatures below the balance point, the heat pump will run non-stop. As the temperature in the house falls approx 1 - 2 degF below the setpoint, the electric heaters will energize. So it is not uncommon for the system to run non-stop with the temperature falling a few degrees below setpoint. The colder the outside temperature, the more often the strip heaters will cycle on/off. If your system is well-maintained and operating at proper performance, it is still cheaper to run your heat pump than it is to run on straight electric heat. If you live in a climate where below zero temperatures are normal during the winter months, you might want to research heat pump options that offer higher COP's and increased performance in colder temperature than the basic contractor's model. Start with initiating communication with a local contractor. You will need to consider initial cost and the pay-back period based on your local energy costs and your specific demands you want your system to meet.
Hope this helps!
Feb 14, 2010 | Carrier 38CKC036 Air Conditioner
Carrier 38CKC042300. oUTSIDE UNIT FAN WAS TURNING REAL SLOW. ac UNIT IS OFF BUT FAN TO OUTSIDE UNIT IS STILL TURNING. sHOULD NOT BE TURNING AT ALL WITH AC UNIT OFF
Jan 12, 2010 | Carrier 38CKC042 Air Conditioner
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Hi- Can not tell if my unites are straight cool / heat or a heat pump.
if you look inside the condenser unit outside,see if you see the big reversing valve,if not it is a straight cool,heat, the heat strip ins in the air handler so you would have to take the side panel off and look for the heat stripe,my the way heat pumps also have a aux.heat stripe just in case it does not get cold enough outside,hope this helps you-mike
Oct 25, 2008 | Carrier 38CKC042 Air Conditioner
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
197 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
