Question about HP LaserJet Office Equipment & Supplies
Logo prints mirror image from the printer hplj cp 2025 in sap
SOURCE: Mirror images only
hopefully you have fixed this problem by now----if not, go to control panel bt clicking start then settings or could be start then control panel. WHAT YOU ARE LOOKING FOR IS THE PRINTERS AND FAXES FOLDER. once you have found that, right click on the HP Officejet Pro L7500 Series (or whatever your printer name is) and choose printing preferences. go to the advance tab. look for mirror image and click on it you will be given a small drop down to toggle it from on to off----choose off and the click on apply and then OK.
Posted on Aug 20, 2008
SOURCE: HP L7580 printer prints mirror image
  • Go to the Printers Menu and select Add Printer
  • Add a Local Printer
  • Create a new port - type: local port
  • For the port name, enter the share of your printer on the remote computer.  For example, if your computer name is superDesktop and the printer share name is megaPrinter, you'd type in \\superDesktop\megaPrinter.
  • Finish the wizard and you're done, printing normally!
Posted on Jan 28, 2009
websnail
  • 419 Answers
SOURCE: Mirror Image printing
This is caused by an early driver version provided with the printer.
Download the latest version from the HP website, unplug your printer from your computer then uninstall your existing driver. Once that's successfully completely install the new driver version.
Unfortunately this doesn't always resolve the problem straight away so you may need to repeat this.
To check if you've resolved the problem:
- Go to START > Printers & Faxes
- Locate your L7780 printer
- right click and choose "printing preferences"
- choose the "Two-Sided (Duplex) printing" printing shortcut
- click on the "Advanced" tab
- look at the setting for "Mirror Image"... If you've succeeded this should now be set to "Off"... If it's "On" you still have a problem.
The problem itself is caused by some duff default settings which seem to stick whenever you've done anything that uses the "Two-Sided (Duplex) printing" Printing shortcut provided in the printing preferences.
In particular I've seen this crop up with PDF files...
The new driver does seem to resolve this but a further work around is to define a new duplex setting that has the correct "Advanced" settings and has "Mirror image" set to Off.
This solution also works for the K5400, L7580, L7680, etc...
Posted on Feb 13, 2009
komguy
  • 2306 Answers
SOURCE: how to print miror image
After you select the image to print the printer dialogue box opens, click on preferences and tell the printer to print a mirror image. It's set in your computer and not at the printer.
Posted on Jun 22, 2009
  • 223 Answers
SOURCE: HP Color LAserjet CP 2025 printer fails to print.
Make sure the printer is connected directly to the outlet. If there is no display there is no use trying anything else as this is a formatter failure and the printer requires service.
Try a nvram:
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
If there is a display,
print out a configuration report
check network settings ipv4addr, check port under driver properties. and make sure the same ip address is selected.
if using usb download a universal print driver and try installing the driver and selecting the usb virtual port
Al
Eliteprintersolutions@gmail.com
Posted on Jul 14, 2010
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
HP colour laser jet CP2025. Prints colour on test sheet but not from pc. It was printing colour until wireless was installed - is there a connection?
Your driver is not sending color data. Either your driver is set to print in geayscale, or you are printing through a monochrome driver to the IP address of the CP 2025
Jun 30, 2011 | HP Laserjet Cp2025n Printer
Clening/mismatch printing for hp clj cp-2025 printer
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Jun 14, 2011 | HP Laserjet Cp2025n Printer
Cyan and Magenta does not print on the right side of the paper. Toner indicator shows three quarter of the cartridge to be full. Yellow and black prints are perfect.
I have worked/ serviced similar Laserjet Color Printer with same issue.
Actually, prints with faded colors or different colors are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. For instance, red color is formed by a mix of yellow and magenta toners. The color is replaced by yellow due the the partial or complete blocking of the image laser beam for
magenta as the mirrors which reflect laser beam get covered with dust and toner (which partially blocks the laser beams). Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer. Note that first magenta goes off, followed by yellow, then cyan and lastly black. This is due to the mirrors placement inside the printer. Magenta is the last one facing upwards at 45 degrees angle and gets most of the dust and goes off first.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
Mar 31, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Problem in hp cp 2025 color laser printer that printer is giving error message "used black cartridge is in use error
This error typically indicates that the cartridge was moved (e.g. previously installed) from another printer to your printer. The error should not affect your ability to print. If you want to clear the error, replace the affected cartridge with a genuine HP replacement.
Aug 10, 2010 | HP laserjet Cp2025dn color Card Printer
Why the logo on SAP report is reversal printed from my printer HP LJ 3050 ?
The SAP device types for specific HP printers use PCL5 fonts in the printer for printing. So the old printer driver can solve this problem.
Nov 05, 2009 | HP Office Equipment & Supplies
Ghosting when using HP CP2025N
Bad drum unit poor fusing or paper type try to print paper type cardstock as type, this increases fuser temp and slows printer for better quality.
-Carl, please let me know if this helps.
Jun 25, 2009 | HP Laserjet Cp2025n Printer
Setting up printer for reverse/mirror printing
I used to use iron on transfers all the time for different things. The setting is usually available whan you attempt to print the image you have different options in properties. Under the advanced tab in printer properties there is something called media type. You can set this to iron on transfer. To locate printer properties in XP for example go to Start>Control Panel>printers>view all printers right click on the printer you intend to use and select properties.
Mar 12, 2009 | Canon Office Equipment & Supplies
Mirror effect on hp 2420 PCL6 (network)
Try downloading the Postscript driver instead of the PCL6 driver. There have been a lot of issues in the PCL driver. You might also try the universal driver. Both are list and can be downloaded from HP's website under the support icon.
Hope that helps you.
Sep 25, 2008 | HP LaserJet 2420 Printer
403 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
