Question about Lands Phones
Phone base on the uniden sse25 model phone constantly beeping about every 5 minutes
    New Friend:
  • 34 Answers
Unplug it then try setting the date and time
Posted on Jan 04, 2013
SOURCE: Phone says "Searching" and will not work.
como activar mute la pertada 2 sin vos
Posted on Jun 24, 2008
SOURCE: Uniden Ex18560 series cordless phone
when I have voice mail messages un-checked, it blinks steady. after erasing, it works right
Posted on Nov 29, 2008
SOURCE: Uniden Cordless Phone Model DSS7855.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Posted on Mar 03, 2009
SOURCE: Register additional handsets on a Uniden phone
On most models you can find an option in the menu for De-register? In that case you would select that option and select to deregister the handset.
TRU88 models you go to the main menu and go to De-register HS select yes to deregister the Handset.
DCT5 and DCT6 models: Press menu on the handset. Go to System Reset and Press select. Go to Deregister HS and press select. Arrow up to yes and press select. Then go back into the menu. Go to system reset and press select. Arrow down to Replacing the base and press select. Arrow up to yes and press select.
DCT7 models: Press and hold "end" and "#" until the system reset menu appears on the display. Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models: Press and hold xfer/del and end until "de-register?" appears. Use the plus+ button to go up to yes and press select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
Posted on Mar 05, 2009
divatif
  • 39 Answers
SOURCE: Base keeps blinking - changed batteries in phone - no change
Reset the base by disconnecting power, press and hold find hs key while reconnecting power.
Posted on Mar 17, 2009
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do I add another handset to d1384?
Apparently,
d1384 page 7 of http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1384om.pdf
Finding the Handset
With the phone in standby, press
FIND on the base. Each handset will beep for 1
minute. To cancel, press
FIND again or press any handset key
Jul 28, 2014 | Uniden Cordless Phone
My uniden xdect sse25 cordless doesn't ring for long enough before diverting to the answer machine I have mobility problems how can i extend the length of the ring
From the handset, press Select/Menu and then press the down arrow to get to Ans Setup. Press Select again. Go down to Ring Time. Then select the number of rings (6, 9, 12 or Toll Saver (TS)). Press Select then press Flash/Exit to exit the menu system. Toll Saver picks up after 2 rings if you have new messages or 4 rings if you don't. This lets you hang up before the answering system picks up if you are using the remote phone access feature.
Note: if you have Voice Mail from your telephone provider, you need to set that to a longer number of rings separately. Consult with your phone company on that option.
The manual for the XDECT SSE25 is available from Uniden here: http://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_SSE25_OM.pdf . See page 19 (23 of the PDF). You will need Adobe Reader to access the manual.
I hope this helps.
Jan 25, 2013 | Uniden Cordless Phone
What does it mean when it said hold find key for 5 sec
There's a button on the base station marked "FIND HS". Pressing this button will cause all the handsets to beep for a minute, so you can find handsets that may have fallen between the cushions on the couch or otherwise gotten lost.
For further assistance, either specify the model of your Uniden DECT 6.0 phone or select it from the list beginning here to download a copy of the manual.
Jun 18, 2012 | Uniden DECT 6.0 Cordless Telephone...
How i can create the phone book for uniden sse25+1
Hi, the instruction manual for this phone can be found at:
http://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT%20SSE25_1_OM.pdf
Phone book information can be found on page 12
May 04, 2011 | Uniden Cell Phones
My binatone triple digial cordless phone keeps saying out of range and beeping every few minutes any ideas it driving me mad
It needs to be re-registered to the base, if I knew which Binatone phone you had I could have advised. Either comment to supply the model name or call 0845 345 9677 (Binatone Helpline).
Dec 10, 2010 | Uniden EXAI 7980 Cordless Phone
Uniden Dect 6.0, the base keeps beeping
You have your answering machine set up to beep when you get a new message. Go through the menu for setting up the answering machine and turn that feature off.
Apr 12, 2009 | Uniden 5.8GHz Dual Cordless Phone
Lands Phones Logo
55 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
