Question about Whirlpool Refrigerators
How do I replace the freezer temperature sensor?
My freezer is maintaining -20F! The thermostat is set on the warmest setting for the freezer. I think the temperature sensor needs replacing. How do I get to it? Where can I get a replacement?
    New Friend:
Search repairclinic.com, they have videos to show you exactly how to do the repairs. i noticed they have videos all over you tube also.
Posted on Jan 04, 2013
SOURCE: GE Profile Arctic Side x Side Refrigerator PSC23MGNA
My GE Profile is 1.5 yrs old and I have the same problem. I came home to find all my food spoiled! It seems many GEs have had this problem, I agree GE should do something, there are expensive units.
Posted on Apr 25, 2008
freetek
  • 5568 Answers
SOURCE: Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Posted on Sep 13, 2008
  • 340 Answers
SOURCE: True TDD1 freezes the beer?
yep can ya turn it off by the thermostat? its likely the thermostat can find one @ appliance parts give them model serial # or caseparts.com. good luck be careful. Tom
Posted on Jun 21, 2009
SOURCE: Samsung Quattro-Cooling RM255LABP Freezer at +20F
orrixcreek i have the same problem. how do you go into the samsung diagnostic? i pressed different buttons at the same time and they're giving me gibberish i dont understand. which specific buttons to press and what exactly do the codes mean? i called samsung and they told me the fridge was probably in "demo mode" that is used on the sales floor and they had me pressed the two left buttons for 6 seconds and a bleep occurred and the LCD went dim. it really didnt fix the problem.
Posted on Jul 20, 2009
woodchuck789
  • 4070 Answers
SOURCE: variance in freezer compartment temperature
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the control board.
Posted on Sep 04, 2009
Which way do I turn the temperature dial on a true 3-door reach-in stainless steel cooler?
Numbered 1-9 - one is the warmest setting, nine is the coldest. For a cooler it should be good on 5 for a freezer 7. If it doesnt work well on those settings the thermostat is usually bad.
Aug 03, 2013 | True Freezer GDM-49RF
Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
May 16, 2012 | Frigidaire Refrigerators
How do i set my temperature on my fridge freezer its a aeg santo ?
Hi
The santo was originally built with a standard thermostat, this is graduated from 1 to 6 where 1 is the warmest setting and 6 is the coldest, normally you would set this to btween 3 and 4 and adjust it slightly to your favourite.
Regards
Gordon
Apr 20, 2011 | Refrigerators
My fridge seems to be working but not cold is on coldest setting fridge part 50F freezer 20F
You probably need to defrost the whole unit, and raise the thermostat temperature
Jul 04, 2010 | GALAXY Microsystems 25.4 cu. ft....
Freezer below temperature. Set to 0F and is at -20F.
If this is just a freezer then the likely problem is a failed thermostat. If it is a combo then check the refrigerator settings and possibly a door leak in the refrigerator. The refrigeration is shared between both sides and to my knowledge never 100% on either side.
Good Luck,
Gilsh
Nov 28, 2009 | Sub-Zero 601R
Refrigerator does not shut off even when set to warmest setting. Both the freezer and fridge compressor will not shut off. is there a master reset for this machine
The only thing that controls the temperature is the thermostat ,I would disconnet one wire of it very careful and if the compresor stops replace the thermostat.
Aug 15, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire 25' chest freezer alarm goes off eventhough it is very cold
The temp sensor for the over temp alarm is probably maifunctioning if you are sure that the temp isnt rising
Dec 27, 2007 | Freezers
Refrigerators Logo
112 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
